Old 10-26-2014, 03:12 PM   #99
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Originally Posted by the new guy View Post
Excellent thread and work here @Sithspawn. It's practically convinced me to look into a cooler and logging the temps as I had no idea they'd get that high. In your track testing, how long would you say it took between sessions for the temps to return to normal?
My pleasure. It is uncommon for anyone to do this level of research and data logging, much less share the data. Even the company I used to work for didn't bother, but boy did they sell a lot of transmission coolers. Personally, I'd rather know exactly what is going on by doing the testing and ensuring that target performance is actually met. Who would have known that the airflow modifications we did made such a significant difference unless we tried and verified the modifications actually worked.
The track testing I did was not a full road course and as such, is more comparable to an auto-X course. The difference between the track I went to and an auto-X course, however, is that time between runs is much shorter. In the auto-X days that I have done, it was a good solid 30 minutes between 50 second runs due to the sheer number of people at the event.
The nice thing about the airflow mods is that when you are on a road course, you are moving much quicker and you are getting better air flow through the cooler. The other nice thing about an HPDE event is the cool down lap. With this setup, you simply won't have temperature issues because you'll actually be getting the temps back down before you even pull into the pits (provided you actually take it easy on your cool down lap). In addition, the HPDE's that I have attended have about an hour to 1.5 hour break between 20 minute sessions. Compare that to the 9 - 10 minute break we had at Adams and the transmission will have plenty of opportunity to cool down between sessions.
Sithspawn is offline   Reply With Quote
Old 12-10-2014, 06:01 PM   #100
Campo
Campo's Avatar
Drives:
subbing so I can come back and read this.
big time thanks to @Sithspawn in just the first page that I've read so far!
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
Old 12-12-2014, 08:43 PM   #101
Max FRS
Drives: 2015 Halo FRS Automatic
Question, I have a Mishimoto replacement radiator, do our Automatic Transmissions use the radiator for cooling? I think my new radiator does not have cooler connections. I know most automatics use the radiator for cooling. I want to add a transmission oil cooler and love the work everyone has done and added to these posts. My plan was to add my transmission cooler when I replaced my radiator this spring. Thanks for any insight and education. Max
Max FRS is offline   Reply With Quote
Old 12-12-2014, 08:47 PM   #102
Stark Performance
Drives: 2014 FR-S
The transmission in this car has a separate heat exchanger and does not tie in directly to the factory radiator. Your radiator upgrade is 100% compatible with an automatic car. Our cooler kit ties into the factory transmission cooling loop to provide additional cooling.
On a separate note, the cooler that @Sithspawn wrote about here is our cooler kit. Here is the link to our ad in the classifieds section: http://www.ft86club.com/forums/showthread.php?t=78267
Stark Performance is offline   Reply With Quote
Old 12-13-2014, 06:34 PM   #103
Max FRS
Thanks for the information. Now I need to know how to order one of your coolers?
Max
Old 12-14-2014, 12:08 PM   #104
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Sub
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
Old 12-14-2014, 05:55 PM   #105
Stark Performance
Drives: 2014 FR-S
Max
My pleasure. I can be reached at mike@starkperformanceparts.com for order processing and technical support.
Old 02-12-2015, 11:16 AM   #106
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Reviving this thread! Just did my take on an AT cooler. Went with a bar and plate type and mounted it on top of the crash beam. I'll try if this works, if not, I'll go with the traditional air cooler and stick it out front.
More info here.
Tye300 is offline   Reply With Quote
Old 03-20-2015, 04:52 PM   #107
Campo
Campo's Avatar
Drives:
More info here.
Hey boss, how is this working for you so far?
I'm looking at the Jackson Racing oil cooler and thought about making a Setrab tranny cooler to match it, but I like this idea too.
Tapatalk - because smoke signals would be too easy.
~Raoul Duke
Old 03-20-2015, 10:01 PM   #108
Tye300
Tye300's Avatar
Here's my review from my build thread.
http://www.ft86club.com/forums/showp...&postcount=380
Since I installed the cooler my tranny temps have not exceeded 90degC during daily driving. The tranny temps mimic the engine oil temp which also uses an oil cooler. Works just fine for me! HTH!
Old 08-20-2015, 06:54 PM   #109
Weapon86
Weapon86's Avatar
Drives: 2014 Scion FRS monogram series
Hey guys, so i just wanted to share what i came up with. This is the diagram of what ill be doing for my trans fluid cooler. I added a fan to the setrab core since there is a intercooler pipe obstructing the air flow to the spot where i want the cooler to be at. Im also planning to delete the windshield washer reservoir to make the lines shorter and make the install much easier.
I havent started with my install yet as im still waiting for other bits and pieces to come in. I would say this is a little more expensive route compare to just getting a ready made kit but you can customize what parts you want for the kit and i had fun researching about the parts i needed for it. lol
here's the list of the parts i got for this project:
Setrab series 1 25row oil cooler
Setrab Mount Kit
Setrab Thermo Switch
Setrab Fan
Mocal fittings 90degree angle(2x) 6AN
Derale Inline Thermostat
High Temp Teflon Hose 3/8
Barb fittings 3/8
Koso Temp Monitor/Sensor
Tee (for temp sensor)
3/8 to 1/8 Adapter
Heat Sleeves
[IMG][/IMG]
Weapon86 is offline   Reply With Quote
Old 08-21-2015, 12:08 AM   #110
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Setrab Mount Kit
Setrab Fan
Barb fittings 3/8
3/8 to 1/8 Adapter
Heat Sleeves
[IMG][/IMG]
Having a thermostat makes no sense.
- Do you know for sure that the transmission can operate with a blocked oil line?
- The heat exchanger is primarily for raising the ATF temperature as quickly as possible at start up. You're not allowing it to happen by blocking the oil line.
- Tstat is across 2 lines.
Old 08-21-2015, 04:30 AM   #111
Weapon86
Weapon86's Avatar
actually it does. IF your oil cooler core is efficient enough to cool down your oil, you wont be able to keep the oil on the preferred operating temperature. unless my car is a dedicated track car then i guess not having a thermostat would be more beneficial. the thermostat opens up at 180F. so if my temp is still below 180F, it wont allow the ATF to run thru the setrab core. instead, it re-routes it back straight to the heat exchanger. so i dont see anything on my diagram that would block the oil line and stop the ATF to circulate.
Derale Fluid Control Thermostats are highly recommended for both engines and transmissions. As the fluid temperatures exceed 180°F the thermostatic valve closes, allowing 95% flow through the oil cooler. At temps below 180°F the valve is open, with 90% of the oil bypassing the cooler. The remaining 10% of the oil flows through the cooler, maintaining constant system pressure, preventing air pockets and eliminating cold oil shock.
Features:
Bypasses cooler at 180°F
Provides quicker warm-up temps
Perfect for cold weather climates
Can be rotated 180° to switch flow direction
Flows up to 20 Gallons per minute
Rated up to 200psi
Ultra bright finish
New Billet style design
Old 08-21-2015, 09:28 AM   #112
Campo
Campo's Avatar
Drives:
I'm going from memory because I'm not in front of my own research this second, but did you compare the pressure deltas of the series 1, 6, and 9 Setrab cores? I seem to recall there was good reason to not use the series 1.
Just double check before you buy that one and I'll go back through my data to verify.
~Raoul Duke
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Automatic Transmission Cooler RYU Engine, Exhaust, Transmission 9 11-14-2013 02:15 PM
Automatic Transmission Cooler KGFRS86 Engine, Exhaust, Transmission 14 08-26-2013 08:55 PM
Automatic Transmission Cooler, necessary for autoX and Track? BRZPDX Engine, Exhaust, Transmission 4 07-11-2013 07:13 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
