Old 07-10-2013, 07:57 PM   #1
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Automatic Transmission Cooler, necessary for autoX and Track?
Is anyone running a ATF cooler kit on here? I am looking at the B&M ATF Super Cooler, http://www.summitracing.com/parts/bmm-70255
I'm also wanting to get my ATF fluids changed out from the OEM ones, to Redline Hightemp ATF. Just seeing if anyone is running a similar set up, and how the AT is holding up.
Probably getting a gauge to check ATF temp as well. Any insight will be helpful!
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 07-10-2013, 08:33 PM   #2
jonbonazza
I doubt they are "needed" but having one definitely couldn't hurt. With that said, what kind of tracking are you planning to do? What class do you plan to compete (or play) in? These choices play heavily into what parts you can or cannot add to your car.
jonbonazza is offline   Reply With Quote
Old 07-11-2013, 01:40 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I don't think what class the person plans to run, will effect whether they want to run trans cooling, unless you want to run stock class.
Old 07-11-2013, 07:03 PM   #4
jonbonazza
I thought for the STX class, there couldn't be any oil cooler or trans coolers?
Old 07-11-2013, 07:13 PM   #5
FRSBRZGT86FAN
Smile
http://www.sff.net/people/dburkhead/prepcompare.htm
http://www.moutons.org/sccasolo/Rule...ring.html#17.1. AUTHORIZED MODIFICATIONS - STS
I'd think you'd have to ask a complete expert on that but "air cooling ducts", but you are correct in the STX class any transmission cooler is not allowed, thanks, but it is allowed on the, Street Prepared, Street Modified, Prepared. These transmissions are pretty bulletproof anyways from what I've seen I'd be more worried about a better radiator and oil cooling if plans on running a class other than STX or stock. These engines run pretty hot and the FA20 has no way of lowering the oil temp stock it just increases unless its off or lower idle situations.
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Automatic Transmission Cooler RYU Engine, Exhaust, Transmission 9 11-14-2013 02:15 PM
Automatic Transmission :( Almighty Bob Southern California 14 11-06-2012 01:13 PM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 03:00 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
