Old 10-15-2014, 01:02 AM   #71
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I just ordered these:
PWR 280x150x19mm with 3/8" fittings
http://www.ebay.com.au/itm/111476265154
3m (18 ft) of 3/8" hose
http://www.ebay.com.au/itm/160794687728
I think I'll fit the cooler and hoses then go to a transmission shop to make the final connection and maybe flush with new OEM ATF.
I've done a couple of track days and a few skid pans where I've ended up facing backwards and stalled about 10-15 times.
Old 10-15-2014, 02:22 AM   #72
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Would this work? http://www.ebay.com/itm/High-Perform...173e95&vxp=mtr
I have a vortech and I have already placed my oil cooler in front of my intercooler. If I add an AT cooler, I do not want to block more of the IC. Would a 7 row make a difference in cooling? Should I just add another 13 row AT cooler? Fog light area is a no go because of the IC piping.
Tye300 is offline   Reply With Quote
Old 10-15-2014, 08:31 AM   #73
snidd111
snidd111's Avatar
Drives: Scion FR-S
That would help some but you'd have to deal with some heat soak from the IC if you mount it all together. You sure the IC piping is blocking the whole fog light area?
You could also look into the kits like cusco and try mounting it in the back.
snidd111 is offline   Reply With Quote
Old 10-15-2014, 02:30 PM   #74
Tye300
Tye300's Avatar
Yeah. Aside from the IC piping, I also have foglights so I can't mount it there. I'm also looking into this, http://www.ebay.com/itm/261304519274...%3AMEBIDX%3AIT
I measured the space in front of the radiator and the crash beam, and think this would fit. I can mount it on top of the crash beam itself, just under the snorkel. The problem is, would a tube and fin cooler be less efficient than a bar and plate cooler? This location would also get less airflow than where the bar and plate cooler would be. Just how big of a compromise would it be is the question.
Old 10-15-2014, 02:34 PM   #75
snidd111
snidd111's Avatar
Drives: Scion FR-S
I've seen those. There was also some discussion here about tube and fin vs bar and plate and it being more a matter of preference and fitment. That looks like it would fit, but I share your concern about the lack of direct air flow.
You'd be getting a lot more heat soak in stop and go and may reduce air flow for your snorkel a bit.
Did you look at the design behind the cusco cooler? Could do a DIY for that. There's another made in Japan that's rear mounted but with a metal shield and air funnel. Can't remember the brand. It's in these forums somewhere.
Old 10-15-2014, 02:44 PM   #76
Tye300
Tye300's Avatar
Yeah I saw the one with the metal ducting but that one is a diff cooler. Thanks for the cusco suggestion, I think that would work. I'll look into that location. Do you think that area has more airflow than the crash beam area?
Old 10-15-2014, 02:51 PM   #77
snidd111
snidd111's Avatar
Drives: Scion FR-S
Then up above the crash beam I think it may be a better choice. But just thought about if you live in a snow region. Would need to make sure you mount it well.
Old 10-15-2014, 02:59 PM   #78
Tye300
Tye300's Avatar
Thanks for the input. Haha no snow for us over here. I think the tube and fin cooler would be the cleanest and easiest install.
Old 10-15-2014, 03:03 PM   #79
snidd111
snidd111's Avatar
Drives: Scion FR-S
Agree with you there. Could it be upside down on the crash beam maybe? Then it could still get some more direct air flow
Old 10-15-2014, 03:19 PM   #80
Tye300
Tye300's Avatar
Never saw that. Will check in the morning! Thanks for another good idea!
Old 10-16-2014, 03:25 AM   #81
Wayno
Wayno's Avatar
When you add a cooler, do you add the same oil volume as the cooler + extra hoses?
Or do you add no extra oil?
When it's cold, does the oil from the cooler and lines drain into the oil pan or stay where it is?
Old 10-16-2014, 08:59 AM   #82
snidd111
snidd111's Avatar
Drives: Scion FR-S
You need to add more fluid to account for the extra volume. The fluid in the hoses won't drain back on its own but that's the same problem with or without the added cooler. That's why you sometimes do a flush vs a drain and fill
Old 10-16-2014, 10:38 AM   #83
Wayno
Wayno's Avatar
That's good that it doesn't drain, I would imagine all that fluid draining back and flooding the box would be bad.
Old 10-24-2014, 02:04 AM   #84
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Excellent thread and work here @Sithspawn. It's practically convinced me to look into a cooler and logging the temps as I had no idea they'd get that high. In your track testing, how long would you say it took between sessions for the temps to return to normal?
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Automatic Transmission Cooler RYU Engine, Exhaust, Transmission 9 11-14-2013 02:15 PM
Automatic Transmission Cooler KGFRS86 Engine, Exhaust, Transmission 14 08-26-2013 08:55 PM
Automatic Transmission Cooler, necessary for autoX and Track? BRZPDX Engine, Exhaust, Transmission 4 07-11-2013 07:13 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
