SoCal Asphalt FR-S Owner
Drives: 13' Asphalt FR-S
Automatic Transmission Cooler
Hi Everyone,
Now that the summer months are here (have been, almost over, I know), I'm questioning if I want to take my Stock A/T FR-S to the track here in SoCal. I know I was fine in the winter, but the summers in the middle of the Cali desert can be quite hot. I was looking at AT Transmission Coolers, and I found this guy: http://bmracing.com/?wpsc-product=au...ated-11x6x1-12 I think I found one other person on the forum using this kind of cooler... It seems really affordable at $75 so I'm considering purchasing one regardless of track usage, as I figure it can't hurt. Any con's to buying one of those and installing it? ![]() Thank you in advance everyone!
Drives: 2010 VW GTI 2-Door (APR Stage II)
*interest piqued*
Michael Reyes
2010 GTI 2dr MT CSG APR Stage II, SPM V1 IC, R8 Coils, K&N Drop-In, 42DD Race DP, Magnaflow CBE, CM FX300, S3 Short Shifter w/ 42DD/VM Bushings, Autotech Insert, StopTech Street Pads, Neuspeed Sport Springs/RSB/RSe12 Wheels, ED LED Tails |
Drives: 85 corolla gts
I will be installing one for someone in couple of weeks or so when we install there turbo kit. Did you monitor your fluid temps at all during your winter sessions? For my customers application I felt it was needed along with the other typicall cooling mods.
#4 | |
Are you installing one from that specific brand or is it a different auto cooler?
We are using the B&M cooler kit part number 70264 I believe. We will also be using a similar sized oil cooler. Our initial goal will be to side mount them in a v configuration and make ducting for them. We have yet to test fit this idea so it is not set in stone. Once the turbo kit arrives we will be getting started on it and I can report back on it.
#6 | |
Drives: Silver AT Limited
interested in this trans cooler
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
interested and sub'd.
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
uosɹǝdʎɐl ʇɹǝdxǝ
the oem cooler
So the car already comes with an engine coolant to trans fluid cooler. Would the air to fluid cooler this thread is about replace or be in addition to what's there?
#10 | |
Drives: Scion FR-S
I only ask as I've known several people who have ended up with bad experiences, longterm, on affordable aftermarket trans coolers. Sub'd for any more info on this and thanks for bringing up a point I'd be contemplating.
#11 | |
uosɹǝdʎɐl ʇɹǝdxǝ
I've tried but have been unsuccessful in finding a PID for the transmission temp. I'm 100% sure there is one but none of the six is so I've found for other TOYOTA products have worked.
#12 |
Drives: Scion FR-S
I thought it was listed in the huge thread for the Torque App PIDS?
#13 |
uosɹǝdʎɐl ʇɹǝdxǝ
I looked and looked for a working one and couldn't find it to my frustration. It's been three months since I tried it so I could go looking in thread again. Maybe I should start a thread just about this....
#14 |
Drives: Scion FR-S
I appreciate the effort. It's one of the few things I like being cognizant of on a daily basis. Trans temp, oil temp, AFR, KR and advance are all I care much about. Having to use the laptop to see the former is a pain in the ass, though the few times I have, I haven't seen anything worrisome. Anyone in the ridiculously hot regions want to chime in on trans temps they've seen with the auto? I'm very curious if this WILL be on the "must do" list next to the engine oil cooler.
| Automatic Transmission | devinclfalcons | Engine, Exhaust, Transmission | 60 | 04-29-2014 09:42 PM |
| Automatic Transmission Cooler | RYU | Engine, Exhaust, Transmission | 9 | 11-14-2013 02:15 PM |
| Automatic Transmission Cooler, necessary for autoX and Track? | BRZPDX | Engine, Exhaust, Transmission | 4 | 07-11-2013 07:13 PM |
| Automatic Transmission :( | Almighty Bob | Southern California | 14 | 11-06-2012 01:13 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
