Old 11-19-2014, 09:18 PM   #785
jk86freek
jk86freek's Avatar
Drives: fr-s
Hi Shiv
Problem 1. (i want to save my Present original file) I don't know why i tried to connect my oft with openflash manager i keep having this error
http://postimg.org/image/x9bjjl1ej/
Problem 2 ( I connect my oft tried to update ) i got this error???
http://postimg.org/image/y049pd3rv/
is it because with ecu type?? ZA1JD00G??
jk86freek is offline   Reply With Quote
Old 11-19-2014, 10:36 PM   #786
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Just bought an Openflash Tablet. Should arrive in the mail soon.
Question.
What would be the best tune to run for the following setup and what sort of results should I expect over stock in terms of HP and TQ gains? I'm not expecting huge gains, my main goal is to eliminate the torque dip.
6Spd. Manual using 98 RON Australian Fuel (Essentially the same as US 93)
MODS
AFE Takeda Intake
Tomei UEL Header
Invidia Q300 Catback
Wise is offline   Reply With Quote
Old 11-20-2014, 12:04 AM   #787
phrosty
Question.
MODS
AFE Takeda Intake
Tomei UEL Header
If your header is catless, stage 2 is what you're after. Might also want to look at steve99's thread on AU petrol which seems like it can be be pretty horrible.
phrosty is offline   Reply With Quote
Old 11-20-2014, 05:20 PM   #788
Wise
Circle Work Clerk
Thanks mate. Will check out.
Old 11-20-2014, 05:25 PM   #789
Wise
Circle Work Clerk
Originally Posted by 86socal View Post
Is anyone running the tomei uel with oft?
I will be soon. Installing Tomei UEL header in the next few weeks and my OFT is in the mail.
Old 11-20-2014, 06:22 PM   #790
Turdinator
Señor Member
Turdinator's Avatar
Question.
MODS
AFE Takeda Intake
Tomei UEL Header
Start with the UEL stage 2 and you may need to scale your MAF and tweak the ignition timing for best results.
EDIT: Or run E85
1974 TA22 Celica
2013 86 GT
Old 11-20-2014, 07:04 PM   #791
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
UEL stage 2 91 on 93 gas is a healthier tune at the expense 2-3 top end HP (from what I've been told)
B-R-Z is offline   Reply With Quote
Old 11-21-2014, 04:31 PM   #792
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Current setup:
FT86SF Catted UEL Header
TRD Cold Air Intake
TRD Catback Exhaust
Running OFT Stg. 2 per local shop and Shiv's recommendation. It looks like some folks are saying the data logs can look a bit odd on Stg. 2 and maybe I need to dial back to Stg. 1.
Any insight on this?
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 11-21-2014, 05:20 PM   #793
Malt
Drives: 2015 WRX
Originally Posted by Re~Mix View Post
Current setup:
TRD Cold Air Intake
TRD Catback Exhaust
You should post your data logs so we can look at them to tell if its running safely or not. Anything else is just guessing at this point.
Malt is offline   Reply With Quote
Old 11-21-2014, 07:32 PM   #794
Re~Mix
Re~Mix's Avatar
Will do, new to this tuning gig.
15' 228i MSport
Old 11-21-2014, 08:07 PM   #795
nunonuna
nunonuna's Avatar
This will help you understand what to look for~(Thanks to @steve99)
http://www.ft86club.com/forums/showthread.php?t=69871
Make sure you go to "configure data channel" and choose useful channels before you try logging. Many people including me did logging with channels selected as default for the first time so had to log it again.
nunonuna is offline   Reply With Quote
Old 11-22-2014, 04:05 PM   #796
kidgogeta
Drives: FRS
just installed the OFT for the first time, only mods I've got is the grimmspeed intake and srt headerback running the 93 oct tune. First time i ran it through had a pause around 4000 rpm with significant change in the noise coming from engine, just wondering if its normal?
kidgogeta is offline   Reply With Quote
Old 11-22-2014, 04:33 PM   #797
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I don't think the pause is normal, but the noise at 4000 is normal and caused by the more aggressive valve timing. (from what I have read)
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 11-22-2014, 07:07 PM   #798
kidgogeta
Drives: FRS
Thanks kinda agrees with what I''ve been reading, the car only had the pause the first time wot now its just the vvt
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
