steve99
Old 07-12-2014, 06:49 AM   #1
steve99
ECU LOGGING BRZ GT 86 FRS - what to look for the basic’s
This is a simplified guide to looking at your logs, for tuning guides see RomRaider site
RomRaider – www.romraider.com has some good guides (often WRX orientated though ie boost))
http://www.romraider.com/Documentation/TuningFAQ
For more detailed tune info google " bad noodle tuning guide "
If you post up your datalogs to www.datazap.me they are heaps easier to read and share accounts are free.
see also this display graphing software fron VIT Tuned
http://blog.vittuned.com/viperdata/
and the Openflash data log display software
OpenFlash Datalog Viewer
For Naturally Aspirated Motors
Knock –detonation – pre-ignition
FLKC – Fine learning knock control
FBKC (Knock Correction) – Feed Back Knock control
IAM – Ignition Advance Multiplier
KC Learned - This is NOT knock this value is the knock correction learned ignition advance it is derived from the "Knock Correction Max A" table in rom and multiplied by IAM and subtract FLKC. Do not confuse this parameter with FBKC or Knock Correction .KC Learned is added to the base timing to produce total timing.
If you IAM is less than 1 then you have knock problems, either run better fuel of a less aggressive tune (fueling and ignition).
Note with OFT V4 Petrol tunes the IAM initial is set to 0.7 (not 1 as in other tunes). this means each time car is turned off IAM will revert to 0.7. however if your 93 fuel is good then IAM should climb to 1 after driving car for short time. It may stay around 0.7 on 91 fuels this is ok. If it falls below 0.6 regularly then you may need to mod tune.
Also try changing brands of fuel its amazing the difference in performance of fuel of the same octane rating.
Ideally there should be no knock ie FLKC or FBKC however these motors are a bit knocky around 1500 to 3500 rpm.
Its hard to completely eliminate but anything over about -1 (FBKC or FLKC) on occasions needs to be investigated and corrected if its often enough to drop your IAM. If you drive in a very high gear at low RPM and jump on the throttle its going to knock.
Can be caused by running to lean, to much ignition advance, poor quality fuel.
The Stock tune will often pull -4 degrees on anything but the best quality fuel and result in IAM hovering around 0.7 or less, even of a stock car.
Video explaining IAM operation (DAM is same as IAM)
[ame="https://www.youtube.com/watch?v=k7oa-EFUIfE"]DAM and Fine Knock Learn explanation Subaru, Cobb, Ecutek, ECU - YouTube[/ame]
Knock Correction
To correct knock and more info on interpreting knock parameters see here
http://www.ft86club.com/forums/showthread.php?t=61820
Kodename47 knock correction tool
http://www.ft86club.com/forums/showthread.php?t=74890
Kodename47,s Tuning Tool Thread
http://www.ft86club.com/forums/showthread.php?t=75710
AFR – Air Fuel Ratio
Should follow the values in the Open Loop Fueling Table under load
Rough guide to expected AFR (Naturally aspirated on petrol)
Cruise and idle around 14
Overrun –throttle closed will often read 20
Under load low to mid RPM , AFR around 12-13
Under load high RPM , AFR Mid 12 than tapering to maybe high 11 over 7000 on OFT tunes.
If your tuned for E85 the O2 sensor does not know the difference it just reads stoic so the AFR in logs will still read the same on E85 (unless its rescaled by logging device)
If you have high long term fuel trims then you likely have intake or exhaust leaks or your MAF needs re-scaling due fitting of aftermarket intake. Or much less likely possibly bad sensors or fuel pump.
see here note these cars have an AFR sensor (will detect range of AFR) not the older type 02 sensor that only detects stoic 14.7
[ame="https://www.youtube.com/watch?v=5WnM_NsOtd8"]Secret of Engine Problem Diagnosis- Fuel Trims Pt.1 - YouTube[/ame]
and here
[ame="https://www.youtube.com/watch?v=cARQ0jZZ4Qc"]Secret of Engine Problem Diagnosis- Fuel Trims Pt.2 - YouTube[/ame]
E85 on stock car
http://www.ft86club.com/forums/showthread.php?t=67310
Logging Wideband 02 signal with Tactrix with aftermarket sensor in second 02 position
http://www.ft86club.com/forums/showp...&postcount=133
Rescaling your Front 02 sensor to be more "wideband"
http://www.ft86club.com/forums/showthread.php?t=82875
Fuel Trims – Fueling errors - MAF Scaling
This is the ECU’s attempt to correct for MAF scaling errors Fuel density changes (ethanol content). Fuel trims will also vary with large changes in temperature and altitude; yes your car has an atmospheric pressure sensor as well as temperature sensors.
IAT- Intake Air Temperature
MAF – Mass Air Flow Sensor
STFT – Short Term Fuel Trim
LTFT – Long term Fuel Trim
O2 Sensor = Oxygen Sensor.
STFT – will vary widely under differing load conditions this is normal and throttle application
LTFT – is the average of STFT over time should be around +/- 3% of less if you have scaled your MAF sensor, if scaling not done may be around +/- 8% on stock car.
If you have changed your intake and not scaled MAF it maybe 10% or more this is not good if it’s more than 10%.
High fuel tims are corrected by doing Closed Loop MAF scaling
Also during wide open throttle runs your AFR should be close to the values in the Open Loop Fuel table in your tune. This table holds the AFR the ecu is targeting at each rpm/load point. In your logs this value is called Commanded AFR. The commanded AFR should follow your actual AFR measured by the O2 sensor under widecopen throttle. If it does not follow commanded AFR within around 5% then your Open Loop MAF scaling is off and needs correction.
If you have high fuel trims and you don’t have an exhaust leak near O2 sensor or a intake/vacuum leak after MAF sensor then you need to scale your MAF sensor
See here for further info and MAF Scaling
http://www.ft86club.com/forums/showthread.php?t=64790
further info on Fuel trims see PDF article at end of this post
Coolant Temps
Should generally be around 90 C once car warmed up, if its getting over 105 C then start to become concerned
Oil Temps
Generally run a bit higher than Coolant temps but if they get over 120 C start to become concerned and investigate.
Will get to these levels on hot days if your giving it heaps, look at oil coolers if your seeing these sorts of temps regularly.
Good video on oil pressures and temps
[ame="http://m.youtube.com/watch?v=cDfFJ5s6IDg"]YouTube[/ame]
Throttle Position
You will often see you throttle percentage at less than 100% in your logs even though you have pedal nailed to the floor. This is because its a drive by wire throttle and its logging the throttle plate position not the accelerator pedal position.
OFT (open flash tablet) generally logs WOT (wide open throttle) around 95%
Ecutek arround 80%
You may also see the throttle percent taper off at high RPM this is normal and ECU adjusting throttle plate angle.
ECU (engine control unit) will also back off throttle if you loose traction with the traction control or stability control active
Resetting ECU
Don’t just reset your ECU trying to correct problems it won’t fix it.
Interpret the logs; investigate the DTC or CEL codes then correct the hardware problems or correct the tuning problems.
DTC – Diagnostic Trouble Codes
CEL- Check Engine light.
ECU Info - See here for more info
http://www.ft86club.com/forums/showthread.php?t=68328
There are lots of other parameters that can be logged such as Cam timing, Injector pulse widths, fuel rail pressures DI/PI ratios but these are beyond the scope of this simple guide.
Stock ROM (tune) update
If your Dealer will not update you to latest ROM see below and do it your self for a small investment in money and time, the stock ROM's are attached to post.
Tactrix- Ecu Flash Information and stock ROM's
http://www.ft86club.com/forums/showthread.php?t=62332
Hope this is useful
If you have any suggested additions let me know.
Last edited by steve99; 04-13-2018 at 09:46 PM. Reason: Added info on KCLearned parameter
The Following 50 Users Say Thank You to steve99 For This Useful Post:
2much (04-03-2015), 86ft.lb (08-03-2014), acj47 (11-06-2014), Akuma-ZN6 (12-07-2017), andrew5826 (07-13-2014), Astroboy (08-23-2014), axelo (11-07-2014), BAMF86 (06-22-2016), BatStig (07-01-2015), BirdTRD (09-26-2015), Boofneenee (07-23-2014), BRZ Fanboi (09-10-2015), Cephas (11-20-2020), Cesium Rainbow (07-28-2019), chas3wba0 (07-21-2014), Darkparadox911 (06-09-2015), diodelphi (11-05-2014), DonkeyKonga (11-04-2014), dubaar (06-30-2015), EffaressNOOB (08-04-2016), Fast_Freddy (11-05-2014), flippy (09-19-2014), G-awesome (04-04-2016), Garrett@Openflash (11-05-2014), golfyankee2121 (07-11-2015), H1C (10-03-2018), keen as (11-06-2014), Koa (12-18-2014), korhun (11-29-2019), Lord09 (08-26-2015), moK (07-16-2014), NepeanFR-S (09-14-2017), NotSoJDM (02-05-2016), number1Tango (01-25-2016), Ralle109 (09-12-2016), series420 (06-20-2021), solidONE (06-13-2016), Sportsguy83 (08-04-2014), swarb (04-03-2015), Tbor (04-11-2016), Teseo (06-30-2015), TofuJoe (09-24-2016), tracerit (03-14-2015), Tromatic (08-03-2014), Trunksse (07-18-2015), TruRace (02-19-2015), Valentino (06-02-2015), Wayno (03-12-2015), XCO (08-08-2015), _gt86_user (07-16-2015)
Old 07-13-2014, 02:00 PM   #2
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
(y)
andrew5826 is offline   Reply With Quote
Old 08-02-2014, 09:38 PM   #3
Brinks
Brinks's Avatar
@steve99 thanks again for the info, Was going to go out and data log. What is the best way to do it? 2nd gear pulls plus some around town driving? I know you can only do one log at a time but whats the duration?
Brinks is offline   Reply With Quote
Old 08-02-2014, 09:49 PM   #4
steve99
OFT holds about 1 hour of log data
Generally its best to log a 2000-redline pull in 2 gear or 3rd gear is better if you have a suitable area to do it as this is similar to a dyno pull and the log will be over a longer period, 2dn gear is a bit short.
If you doing MAF scaling you will need to do steady throttle easy driving log over about 30 minutes at varying rpm and loads.
H1C (10-03-2018)
Old 08-04-2014, 05:33 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
With regards to WOT driving, the higher the gear you use, the better the resolution of data.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
H1C (10-03-2018)
Old 11-05-2014, 12:09 AM   #6
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
@steve99 I have been reading all your post about the OFT
I have a question about knock correction and have a log to post tomorrow. Left my OFT cord at work.
Current set up: K&N drop in filter, Cat-back, lightweight crank pulley ()
OFT stage 2 UL E85
I was running a log tonight and watching the graph and realized I was pulling upwards to 5 or 6 degrees in the KC Learned, which is the highest I have seen in my car, since normally it stays at 0 and very rarely ventures up to 3.
Most of the higher numbers 4-6 where in the 1800 to 3000 rpm rev range but I was still getting 2-4 above 3k rpms, all the while my IAM stayed at 1.
Is it just a bad batch of fuel? My light came on, drove 25 miles to pump. Put in two gallons of gas and brimmed it with E85.
are my KC learned numbers a concern? I am still reading and learning about tuning and data logging and the OFT.
GotBRZ1691 is offline   Reply With Quote
Old 11-05-2014, 03:19 AM   #7
steve99
OFT stage 2 UL E85
Dont sweat mate KC Learned is not knock. its the amount of timing the ecu has available to it to correct knock via IAM/flkc at any particulat rpm/load, you have to compare your measured KC learned to the values in the Knock correction max A table at each rpm/loadcpoint to determine if you have knock its much easier to look at IAM FBKC and FLKC.
You need to look at FBKC(knock correction) and FLKC fine learning knock correction and your IAM.
If your IAM=1 and stays at one your knock is probably not to bad.
Then look at the amounts of Knock Correction FBKC and FLKC if they are less than one degree correction occasionally then all is ok
GotBRZ1691 (11-05-2014)
Old 11-05-2014, 08:32 AM   #8
nunonuna
nunonuna's Avatar
@steve99,
I recently got catted UEL header from ft86sf & am trying on stg 2 now. When I did 3rd gear pull for data log, it seems fine as IAM, FBKC and FLKC stays 1 and 0, but I tried 4th gear pull and the flkc look like up&down. Would you mind take a look? Shiv told me stg 2 may work better on mine because I have all other mods of exhaust. If this log shows any warning, I guess I have to go back to stg 1.
http://www.datazap.me/u/fa20frs/1104...zoom=3561-3691
nunonuna is offline   Reply With Quote
Old 11-05-2014, 09:05 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by nunonuna View Post
@steve99,
Compare engine load between runs. You also don't seem to be logging ignition timing, you can ditch KC learn parameters.
As for FLKC, you pay attention to where it drops as an indication to where the knock retard is actually happening. Higher gears will produce more load on the engine, if the car is mapped for 3rd gear pulls it's possible that 4th/5th gear will knock. Depending on your feelings, you could let the ECU do its stuff and have more power in the lower gears, or trade off a little to make all gears run without retarding any timing.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-05-2014, 12:06 PM   #10
GotBRZ1691
GotBRZ1691's Avatar
Awesome thanks mate I will get my log up in that thread shortly. So presumable i just have to change the data logging channels that I am monitoring and I can add FBKC and FLKC to the list.
Old 11-05-2014, 12:09 PM   #11
diodelphi
diodelphi's Avatar
Drives: 86
thanks so steve
diodelphi is offline   Reply With Quote
Old 11-05-2014, 04:57 PM   #12
steve99
@steve99,
+1 on what @Kodename47 said, plus try different brands if gass before you pull any timing some are better than others even with same octane rating.
tracerit (04-03-2015)
Old 04-03-2015, 06:30 PM   #13
Vroomin86
Drives: 2015 Fire
I just got mine and don't know what to do with it other than flashing it over to stage 1 octane 93 (stock car for now) lol .
Any other cool/tricks to do with it before moving on to stage 2 EL?
Vroomin86 is offline   Reply With Quote
Old 04-03-2015, 07:49 PM   #14
steve99
read the tune tweaks link below
Ecutek logging Andreas83 Software Tuning 3 07-09-2018 11:57 PM
OP2 logging discussion AdrianG Software Tuning 37 10-06-2017 02:41 PM
BRZ Basic SQ Build hellyvin Electronics | Audio | NAV | Infotainment 13 07-22-2014 01:25 AM
IAT logging, what are you guys seeing? BRZPDX Forced Induction 3 03-02-2014 02:59 PM
