Old 04-25-2014, 07:17 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Howardwei View Post
Yea I just have trouble with the wiring part. My jr kit has a pcv somewhere in that vacuum line from the manifold. I assume you just install the whole T joint with sensor upstream of that pcv?
What your JR kit has is a check valve to prevent the crankcase from being pressurized. You need to place the T prior to the check valve and closer to the back of the intake manifold. As for wiring, my guess is you have a power, ground, and the wire actually sending the 0 to 5V signal to the gauge.
Old 04-25-2014, 11:32 PM   #16
Howardwei
The p3 vent gauge has a auxiliary port for external boost sensor in the driver cabin. Just don't know how the wire from the actual sensor itself could be connect to in the engine bay that would correspond to one of the place where the aux wire inside the cabin need to go.
Howardwei is offline   Reply With Quote
Old 04-26-2014, 04:53 AM   #17
HRTROB
HRTROB's Avatar
Drives: Toyota 86
There is a round hole covered by a plug in the firewall right below the brake fluid reservoir. You just have to remove the plug then you can use that hole to pass the wire from the boost sensor to your gauge
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
Howardwei (04-27-2014)
Old 04-27-2014, 02:09 AM   #18
Howardwei
Ah I see. and the auxkillary on the side of cabin from the sensor. do you just tap it into one of the plugs covered by trim near the clutch?
Old 11-12-2014, 08:57 AM   #19
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
This might sound stupid to some, but can I plug in say an omni 4 bar sensor if the car was already tuned with the same brand 3 bar sensor?
Fizz is offline   Reply With Quote
Old 11-12-2014, 09:10 AM   #20
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
No, need to change two simple values in the tune for it to work properly.
Voltage and offset IIRC. It's a very simple change in the tune.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Fizz (11-12-2014)
Old 01-08-2015, 03:27 PM   #21
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Guys whats the deal with the map sensor naming, now they have a brz frs map sensor, is this still the same piece as the k motor map?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 01-08-2015, 03:53 PM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
As long as it looks like your OEM one, then buy it.
Old 01-08-2015, 03:56 PM   #23
yomny
yomny's Avatar
lol thats the issue, most sites dont have an accurate picture, even FT86speedfactory has a weird pic for whats supposed to be our sensor. I'm sure this isn't an issues, i'm sure them as well as rallysportdirect have the correct part listed.
Is P0108 (MAP sensor) common ? regal Issues | Warranty | Recalls / TSB 0 10-06-2012 12:21 PM
Understanding the BRZ/FR-S/86 Occupant Detection Sensor Turbowned Issues | Warranty | Recalls / TSB 13 08-27-2012 10:58 PM
Bad MAF Sensor paulieblaze Scion FR-S / Toyota 86 GT86 General Forum 3 08-23-2012 10:34 PM
How to fool airbag sensor? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 3 07-12-2012 11:46 PM
Stock O2 Sensor d1ck Engine, Exhaust, Transmission 1 07-11-2012 07:16 AM
