turbo FT-86
Drives: ft-86
Map Sensor Hookup?
i want someone to help on how to hookup a map sensor for the BRZ for turbo application?
| The Following User Says Thank You to ft86-UAE For This Useful Post: | ericvanderwoodsen (02-14-2013) |
#2 |
Boostin'
Drives: FRS-T
Lift up small plastic cover on intake manifold take sensor out and replace with omni for honda k series motor. But in all honesty, if you have to ask this, i would not attempt to do this myself! Just sayin
| The Following User Says Thank You to Silverdub For This Useful Post: | ft86-UAE (10-13-2012) |
#3 |
Drives: Ones with Big Turbos
If your asking about wiring up a gm 3 bar or something like that you'll need the Oem wiring diagram for the car and you can get the wiring for the map from google, but I would stick with a plug and play.
| The Following User Says Thank You to ANTI_LAG For This Useful Post: | ft86-UAE (10-13-2012) |
#4 | |
FRS Rear Mount Turbo
Drives: 2013 FR-S Raven, Rear Turbo
3 bar will work fine too. Just because you need help with a map sensor does not mean you are not capable of building an awesome turbo setup. I wondered about the same thing when I did my rear turbo FRS. I just was not educated yet on the map sensor, now I know and so will you when your done. People will be asking you how to do things. Press on, live and learn. |
| The Following 8 Users Say Thank You to Roadstercycle For This Useful Post: | bakerr6 (04-25-2014), ericvanderwoodsen (02-14-2013), ft86-UAE (10-13-2012), jamesm (11-23-2013), nix (10-15-2012), normancw (04-26-2014), SocalMonsta (05-19-2015), Strife26 (01-08-2018) |
#5 |
turbo FT-86
Drives: ft-86
Thanks a lot for the Help
#6 | |
We will be having a thead on here soon where we list all the parts we have for the turbo community and we will have these. Dave |
#7 |
turbo FT-86
Drives: ft-86
i have fitted a Yamaha 2 bar map sensor (jet sky). and we are running fine now. Thanks.
#8 |
Drives: 2006 Subaru Liberty EZ30 S/charged
Go the Jetski parts - good work
Toyota 86 test driver
#9 |
Drives: 2012 Toyota 86 GT (Black) :)
In fitting one of these is a full retune required immediately to rescale the map etc? Or can it be done as prep for a turbo install?
#10 |
BIG Dreamer =D
Just* from what i have read on here ( never done) when installing a new sensor you need a ROM to go with it?… correct me if wrong, but i was just reading the FI threads with this topic also…but I'm assuming its the calibrations for the new sensor to make everything happy again lol
#11 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
New Map = you need a new tune
#12 |
P3 external boost sensor
Does anyone know how to hook up the P3 external boost sensor? I was not awared of the Omni plug n play.So I bought the external sensor since the gauge vendor sells. them.
http://www.p3cars.com/add-ons-and-ac...-boost-sensor/ The analog sensor would hook up to the vacuum boost tap on the manifold. I assume cuttings will be done? |
#13 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Howardwei (04-25-2014) |
#14 |
Yea I just have trouble with the wiring part. My jr kit has a pcv somewhere in that vacuum line from the manifold. I assume you just install the whole T joint with sensor upstream of that pcv?
| Is P0108 (MAP sensor) common ? | regal | Issues | Warranty | Recalls / TSB | 0 | 10-06-2012 12:21 PM |
| Understanding the BRZ/FR-S/86 Occupant Detection Sensor | Turbowned | Issues | Warranty | Recalls / TSB | 13 | 08-27-2012 10:58 PM |
| Bad MAF Sensor | paulieblaze | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-23-2012 10:34 PM |
| How to fool airbag sensor? | track_warrior | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-12-2012 11:46 PM |
| Stock O2 Sensor | d1ck | Engine, Exhaust, Transmission | 1 | 07-11-2012 07:16 AM |
