Old 10-17-2014, 12:19 AM   #1
toby714
Drives: whiteout
is there a shorter endlink out there? mcs motion control damper
Update: problem solved continue to post 12 for solution
My whiteline front endlink is too long even at the shortest setting for my motion control suspenion dampers with stock sway bar. does anyone know of any other alternatives? i found this generic whiteline KLC180-195 that can go 190mm.
i get poppng sounds and i assume its the binding of the endlink
I was also thinking maybe i can modify my whiteline one by making cutting the connecting rod or buy a new connecting rod. the problem is figuring out the pitch for the ball joint
toby714 is offline   Reply With Quote
Old 10-17-2014, 01:37 AM   #2
toby714
Drives: whiteout
i also found this if anybody wants to be these a try. from awr
Old 10-17-2014, 02:18 AM   #3
toby714
Drives: whiteout
ill be hitting up mcmasters in santa fe and see if i can get a shorter threaded tube for my whiteline one.
Old 10-17-2014, 09:36 AM   #4
illmattic
illmattic's Avatar
I just run the KLC 180-195. Seems to be fine and my car is pretty low. The only thing is it pop and creaks and stuff like that. Either way tho the front sway bar is coming off next year.
-Flickr-
IG @illmattic86
illmattic is offline   Reply With Quote
Old 10-17-2014, 02:40 PM   #5
s13kid989
Drives: 2013 Whiteout Frs
With MCS coil overs I had my car about an inch lower then stock, and with the regular whiteline endlinks the sway bar was to close to the lower arm. I contacted Whiteline and was told to order part number KLC180-195
s13kid989 is offline   Reply With Quote
The Following User Says Thank You to s13kid989 For This Useful Post:
toby714 (10-17-2014)
Old 10-17-2014, 03:08 PM   #6
CSG Mike
CSG Mike's Avatar
There shouldn't be any pops or creaks. Double check your work.
wparsons (10-17-2014)
Old 10-17-2014, 03:10 PM   #7
illmattic
illmattic's Avatar
I've checked it multiple times. Its just the way it is.
-Flickr-
IG @illmattic86
Old 10-17-2014, 03:17 PM   #8
CSG Mike
CSG Mike's Avatar
I'm sorry, but I don't find that acceptable for any high end suspension. I've been working with high end suspension setups for years now, and anytime there's creaks and popping, there is binding or abnormal wear and tear somewhere.
Take a diagnostic step and "paint" all the suspect areas with a chalk pen, drive around the block (replicate the noise), and revisit.
Have the dampers dynoed to verify it is not the damper itself.
We've done multiple MCS/JRZ/SRC/AST setups, and none of them make noise.
Old 10-17-2014, 04:15 PM   #9
toby714
Drives: whiteout
im taking out my whiteline endlinks because it's too long and adding a lot of preload to the sway bars. i woll get back to you guys when i sort this out
Old 10-17-2014, 04:35 PM   #10
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by toby714 View Post
My whiteline front endlink is too long even at the shortest setting for my motion control suspenion dampers with stock sway bar. does anyone know of any other alternatives? i found this generic whiteline KLC180-195 that can go 190mm. my last resort is cutting and welding my factory front endlinks. I plan to track with my setup.
I have a set of those Whiteline endlinks that I'm not using anymore if you're interested in picking up a used set
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 10-17-2014, 06:03 PM   #11
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I bought some cut to length end links. Saved me a bunch of time.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
CSG Mike (10-17-2014), sroby (04-22-2020)
Old 10-17-2014, 07:33 PM   #12
toby714
Drives: whiteout
i knew it was the endlinks and here it is contacting the inner wells.
as you can see in the picture, the whiteline endlinks sit a tad higher
i went ahead and got a milwaukee saw and cut a decent portion off. whoever is considering hacking away at their endlinks should do so at their own risk. i'm not responsible for any injurys or deaths lol
took it for a test drive just earliar and now its fine!
The Following User Says Thank You to toby714 For This Useful Post:
B T (07-10-2018)
Old 10-17-2014, 07:43 PM   #13
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
plus you got some weight reduction in there too
Old 10-19-2014, 07:28 PM   #14
Wepeel
Drives: '13 BRZ Ltd
What I posted in another thread:
Originally Posted by Wepeel View Post
The BRZ-specific Whiteline ones that come with their front bar are KLC-179. These are spec'd to range from 200-250mm in length. At their shortest setting, I still had contact issues with the WL front adjustable bar and the control arm on coilovers when running the bar on full stiff (a lot of coils bring the control arm closer to the swaybar). Whiteline has another generic endlink, KLC180-195, that is similar but can go shorter, 190-215mm is the spec, and these work perfectly.
Odi at Feal suspension also includes a shortened, OEM-style endlink with his 441 coilovers. It is non adjustable, and is 190mm in length. Odi does sell these without the coilover kit if you email him.
The Whiteline KLC180-195 or the Feal one would probably work well in your situation.
http://www.ft86club.com/forums/showthread.php?t=61472
Wepeel is offline   Reply With Quote
The Following 2 Users Say Thank You to Wepeel For This Useful Post:
B T (07-10-2018), Mad1723 (08-31-2018)
Motion Control Suspension coilovers xwd Tracking / Autocross / HPDE / Drifting 27 02-21-2015 10:24 PM
motion control suspension(mcs) spring length toby714 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-21-2014 11:42 AM
Motion Control Suspension andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-30-2014 10:55 PM
WTB: Shorter exhaust hangers FrSnake Want-To-Buy Requests 0 12-30-2013 09:25 PM
Motion Control Suspension Singles---SCCA Stock legal are done! Sam Strano Tracking / Autocross / HPDE / Drifting 25 01-16-2013 02:42 PM
