Old 02-22-2013, 05:33 PM   #1
xwd
Motion Control Suspension coilovers
So MCS has gotten all the parts in to build the first run of coilovers for the FR-S and BRZ. MCS are basically the guys from Moton USA who started MCS when AST bought Moton.
I purchased a set of the double-adjustable remote canister versions and picked them up yesterday afternoon since I am only about 10 minutes from MCS. I had given them a take-off suspension so they assembled a stock-class compatible setup for me. They measured and located the spring perches at the correct location compared to stock, but I will double check them as well.
I'm going to try and get them on the car this weekend sometime. These should work well both on the street and autocross/track/etc. Last years STU winning M3 was using the same setup and the car is his daily driver.
Also these will work with a standard 2.25/2.5" spring, they have standard lower perches and MCS has made adapters to use the springs with a Subaru tophat.
Pictures!
Front Strut
Billet lower perch for stock front spring
Rear Shock
Billet lower perch for stock rear spring
Rear drybreak fitting.
Compression adjuster on canister
Hardware
The Following 5 Users Say Thank You to xwd For This Useful Post:
Anthonytpt (11-13-2013), Black Tire (02-22-2013), CounterSpace Garage (02-25-2013), RWD_only (02-23-2013), Scooby South (02-22-2013)
Old 02-22-2013, 05:41 PM   #2
jamal
jamal's Avatar
Drives: Legacy GT
Neat spring perches.
I'm pretty sure you do have to de-pressurize the shock to disconnect those dry-breaks though. You do with the JRZ ones anyway.
jamal is offline   Reply With Quote
Old 02-22-2013, 05:45 PM   #3
xwd
I will check with them. Could just make it easier to run the line versus unscrewing the fittings on the shock and canister.
Old 02-22-2013, 06:02 PM   #4
ayau
Drives: Some rust bucket
Sexy.
Old 02-22-2013, 06:03 PM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
MCS is bad ass.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-22-2013, 06:09 PM   #6
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
pricey ... but very nice..
Bill
Scooby South is offline   Reply With Quote
Old 02-22-2013, 06:28 PM   #7
apexaddict
You will have to depressurize them. It's not hard to fill them back up again, though, all you really need is a rental tank and line from your local Airgas and a filling tool. I recommend hanging on to these things as you can tune the performance of the shock with gas pressure (and in Stock, I'd crank the pressure up to get the faux spring effect).
Filling tool:
http://performanceshock.com/index.ph...roducts_id=682
DO NOT, under any circumstances, try to disassemble the fittings on the shock and/or canister, ESPECIALLY if they are still under pressure. That is why the dry-breaks are there. You will ruin your shocks in more ways than you can imagine if you try to do that.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 02-22-2013, 06:31 PM   #8
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
WOW these look SWEET.. OEM Springs?
How's the clearance gonna affect wider wheels with that collar?
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 02-22-2013, 08:08 PM   #9
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
SWEET.
Looks good
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 02-22-2013, 08:13 PM   #10
xwd
The stock perches are just as wide so it shouldn't be an issue. I'm using 245/40/17 A6s with +42 rims and there should be plenty of clearance.
Old 02-25-2013, 08:46 PM   #11
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Lookin' GOOD! Hopefully my package will be on the doorstep tomorrow or Weds...
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 03-08-2013, 07:04 PM   #12
xwd
I've had them installed for a little over a week now, they are working very well on the street and I have my first event with them Sunday so hopefully I can get the dialed in.
Some astute observers may have noticed the front strut hole is slotted, MCS did this for those who wanted more camber out of the setup without using camber plates. The issue is I'm using these in stock class and slotting the holes is illegal. While MCS got everything else right with regards to the stock class rules, they made an oversight with the hole which I alerted them to right after I received them.
Within a day they had engineered a solution in the way of an insert which fits inside the slotted 16mm diameter hole which places a 14mm hole in the exact same location as stock, with the insert in the "stock" orientation. Within about a week they had them machined and in my hand, and today I installed them.
I can't say enough good things about working with them and how quickly things were resolved. In the future they will likely include the inserts with all sets, and are now thinking of producing this offset insert as well as one with the hole in the middle, so if you happen to work on the suspension you can always get it back to the exact same spot. I've used slotted struts before and usually just made a mark on the strut, but this would make things a little easier.
Stock strut to firewall bars make a good place to mount the canisters
The Following 2 Users Say Thank You to xwd For This Useful Post:
CSG Mike (03-08-2013), juliog (10-17-2014)
Old 03-08-2013, 07:45 PM   #13
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Any worries in having your remote canisters so close to a heat source?
iLuveKetchup is offline   Reply With Quote
Old 03-08-2013, 08:30 PM   #14
xwd
Not really. It's the same place some others like the Eibach MultiPros mount. The driver side is nowhere near any heat really, the passenger side is above the exhaust and heats up a little more but not much. I checked the nitrogen pressure before and after driving the car pretty hard and saw no difference.
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 02:56 PM
Motion Control Suspension Singles---SCCA Stock legal are done! Sam Strano Tracking / Autocross / HPDE / Drifting 25 01-16-2013 02:42 PM
Deft Motion | Suspension Specials Deft Motion Brakes, Suspension, Chassis 4 07-12-2012 02:48 PM
