| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: 2013 FR-S Asphalt
transmission fluid change diy:
http://www.ft86club.com/forums/showthread.php?t=19218 The dealership wouldn't change mine before the service interval and said that using different oil would void my warranty which is bs because motul gear meets the same standards as the oem fluid. Had it done by a local shop that specializes in subarus since I didn't have jack stands at the time. Next time I will do it myself Also definitely get the mtec shifter springs. Those I installed myself and now that I have them and changed the fluid the shifter is way better |
#16 |
Drives: JAWS
Because it has a built in spout. I just did my tranny/diff with no pump.
#17 | |
Drives: SWP FR-S
#18 |
Drives: tezla
so does it matter if its AT or MT to change these fluids at different intervals?
#19 | |
I've done a few NorCal's and I'm looking to do a couple more soon. You should see the build up of crud on the magnetic drain plugs. It's a lot less after the 3rd change. As for dealer issues, just tell them NOT to change it. Yes. Contact the dealer or someone obligated to fuss with an AT.
#20 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
Suction guns work well and only cost $15.
#21 |
Drives: white-out FR-S
Those who have MT notice any differences in shifting after trans oil change?
| Tags |
| fluid, transmission, transmission fluid |
| DIY - Transmission / Diff Fluid Change Reference Guide | F1point4 | DIY (Do-It-Yourself) Guides | 295 | 05-13-2023 02:34 AM |
| Automatic Transmission Fluid Change | jmaryt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 169 | 08-26-2018 07:55 PM |
| Change your manual transmission fluid ASAP!!! | Kostamojen | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 383 | 12-12-2016 09:29 AM |
| What transmission fluid are you using? | Chillz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 04-06-2013 10:45 PM |
| Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
