View Poll Results: What transmission fluid are you using?
Dealer Fluid 35 27.13%
Motul 300 75W90 39 30.23%
Redline MT-90 75W90 14 10.85%
Amsoil MTG 75W90 13 10.08%
Pentosin MTF2 75W80 28 21.71%
Voters: 129. You may not vote on this poll
Old 02-22-2013, 01:07 PM   #1
Chillz
Drives: Asphalt FR-S & S14
Just wondering what MT transmission fluid most people here are using. Let me know if you want me to add any other options.
Chillz is offline   Reply With Quote
Old 03-08-2013, 07:55 AM   #2
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
We've had phenomenal service from Motul Gear 300 over the years and have switched over to that as our standard Trans and Diffy fluid for both the BRZ and the Subaru Platforms.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 03-08-2013, 07:29 PM   #3
Hanakuso
Many here switched to Motul including myself. Once it's warmed up it's definitely smoother, but sometimes when it's cold it's almost impossible to downshift from 3rd to 2nd.
Hanakuso is offline   Reply With Quote
Old 03-08-2013, 07:34 PM   #4
OrbitalEllipses
Drives: Attitude
I shouldn't have to double clutch to downshift when cold...is pentosin the only thing that helps COLD?
Old 03-08-2013, 07:48 PM   #5
superpilun
Drives: 1986 MR2
Redline MT-85 is supposed to be similar to Pentosin with regards to shift quality when cold. Still waiting to see if anyone has tried it.
superpilun is offline   Reply With Quote
Old 03-08-2013, 08:13 PM   #6
AZP Installs
We use this in NY/NJ where it's cold all winter. No such issues on any of our cars here and we've installed Motul Gear 300 in a lot of transmissions over the years.
-Mike Paisan
Old 03-08-2013, 08:34 PM   #7
Hanakuso
Double clutching doesn't help. Even when I'm at a stop sometimes it won't go into 2nd, even tho 1st goes in.
Old 03-08-2013, 08:46 PM   #8
AZP Installs
I would have it looked at while it's still under warranty. Or change the fluid to stock and see if that makes a difference.
-Mike Paisan
Old 03-08-2013, 09:19 PM   #9
Hanakuso
-Mike Paisan
Do you happen to know what is the factory fluid?
I'm pretty sure it's the Motul fluid. It never had this problem when I was on stock fluid. I ordered a lab kit and I'm planning on changing soon.
There's always the chance I over or under filled but I've done trans fluid quite a few times.
Old 03-08-2013, 10:40 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Torco mtf here
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-08-2013, 11:39 PM   #11
OrbitalEllipses
Drives: Attitude
I can't get into 2nd from 3rd unless I double clutch...so either you live somewhere colder or your box is screwier.
@AZP Installs I take it you were talking about Motul Gear 300?
Old 03-09-2013, 01:17 AM   #12
Hanakuso
Actually tonight I tried to replicate the problem and it does go in when I double clutch. It's not cold here, I live in SoCal. Actually tonight was freezing. 55F
Old 03-09-2013, 01:29 AM   #13
OrbitalEllipses
Drives: Attitude
Old 03-09-2013, 07:55 AM   #14
AZP Installs
You would need to get it from a dealer, I'm not sure what it is, even if you could get it outside of a dealer, it could be a different blend for "public" consumption.
-Mike Paisan
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 02:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
