Old 02-12-2014, 10:56 PM   #1
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Transmission fluid change from dealership?
So, I've seen numerous posts about changing your transmission fluid as soon as possible. I'm still under warranty so I thought of making an appointment at my local Toyota/Scion dealership for changing my tranny fluid.
I'm a little on the fence about this because I've also seen people running into problems caused by the mechanics at the dealership. What do you guys think?
Jolaessss is offline   Reply With Quote
Old 02-13-2014, 01:15 AM   #2
humfrz
Do you have a MT or AT .. ??
Assuming a MT, is it shifting smoothly .. ??
If not, you may wish to consider an alternative fluid (to the Toyota stuff).
As far as having the dealership change the fluid, it's a fairly straight forward procedure. Drain the old fluid out through the only plug on the bottom, replace drain plug, add fluid through the filler hole, till it won't take anymore, replace the plug. Only two moving parts, so, as long as they don't cross thread the plugs ..... you're good to go.
humfrz
Old 02-13-2014, 01:19 AM   #3
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
humfrz
Isn't that to replace the oil?
Can't find any diy tranny fluid change
Carlitoz3 is offline   Reply With Quote
Old 02-13-2014, 01:26 AM   #4
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
humfrz
MT, I wouldn't say smoothly. Every now and then I grind into gear, especially into 3rd.
Old 02-13-2014, 02:19 AM   #5
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
they most likely won't do it i already tried a bunch of times and my dad had an extremely big job there and they still wouldn't do it, plus i probably wouldn't use the toyota junk id go with motul 300
sweetfrs is offline   Reply With Quote
Old 02-13-2014, 02:27 AM   #6
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
i looked into changing the fluid myself but you need a fluid pump, which i do not have lol
Old 02-13-2014, 02:47 AM   #7
JB86'd
JB86'd's Avatar
Drives: JAWS
Not if you use Motul.....
Old 02-13-2014, 09:49 AM   #8
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I believe he meant on the transmission.
There are 2, I believe 10mm hex head (I could be wrong on the size) plugs that are on the drivers side of the manual transmission casing. One is towards the rear of the case and very low and the other is more forward and higher up. Front to fill and rear to drain.
Ideally you would want to have the car on ramps or something so that it is sitting fairly flat to do the drain and fill. Its really no more difficult than changing the engine oil, other than its a little more cramped.
Ranatsu is offline   Reply With Quote
Old 02-13-2014, 10:35 AM   #9
humfrz
hmmmm.......I thought the OP WAS interested in a transmission oil change ....
humfrz
Old 02-13-2014, 10:36 AM   #10
Doctor Who
Equinsu Ocha
Doctor Who's Avatar
Drives: SWP BRZ Limited
I just had my diff and trans fluid changed to Motul. Night and day difference.
Doctor Who is offline   Reply With Quote
Old 02-13-2014, 10:40 AM   #11
humfrz
Well, if you do feel it is necessary to change the transmission oil and either the dealership won't do it ..... or you don't trust them to do it correctly, I'm sure a local automotive shop would be up to the task ...
humfrz
Jolaessss (02-13-2014)
Old 02-13-2014, 11:57 AM   #12
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
The general consensus on the form would say it's a good idea to do a fluid change on the transmission. Many people have been having issues with shifting, gear noise, etc. The majority of the time changing fluids will help.
These are the main brands most people use on the form:
-Motul
-AMSOIL
-Pentosin
-Red Line
Also, you might want to check out MTEC's new shifter springs. I just bought some myself but haven't used them yet. I hear they are pretty nice!
http://www.mtecind.com/diy/scion-frs...pring-install/
shiro is offline   Reply With Quote
Old 02-13-2014, 04:19 PM   #13
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Why is that
Old 02-13-2014, 04:39 PM   #14
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
You don't need a pump whatever oil you use. Just buy a funnel, and about 3 ft of hose to fit on the end of the funnel, and that is small enough diameter to fit through the filler hole. Pass through the engine bay from the top and into the filler hole then pour the oil in.
Oil pumps are a PITA and never seem to work well.
Sent via Tapatalk.
jonboy99 is offline   Reply With Quote
The Following 2 Users Say Thank You to jonboy99 For This Useful Post:
Jolaessss (02-13-2014), SirBrass (02-13-2014)
fluid, transmission, transmission fluid
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Change your manual transmission fluid ASAP!!! Kostamojen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 383 12-12-2016 09:29 AM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
