Old 02-13-2014, 04:39 PM   #15
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
transmission fluid change diy:
http://www.ft86club.com/forums/showthread.php?t=19218
The dealership wouldn't change mine before the service interval and said that using different oil would void my warranty which is bs because motul gear meets the same standards as the oem fluid. Had it done by a local shop that specializes in subarus since I didn't have jack stands at the time. Next time I will do it myself
Also definitely get the mtec shifter springs. Those I installed myself and now that I have them and changed the fluid the shifter is way better
AllStar0419 is offline   Reply With Quote
Old 02-13-2014, 05:41 PM   #16
JB86'd
JB86'd's Avatar
Drives: JAWS
Originally Posted by Jolaessss View Post
Why is that
Because it has a built in spout. I just did my tranny/diff with no pump.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Jolaessss (02-13-2014)
Old 02-13-2014, 10:49 PM   #17
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Originally Posted by jonboy99 View Post
You don't need a pump whatever oil you use. Just buy a funnel, and about 3 ft of hose to fit on the end of the funnel, and that is small enough diameter to fit through the filler hole. Pass through the engine bay from the top and into the filler hole then pour the oil in.
Oil pumps are a PITA and never seem to work well.
Sent via Tapatalk.
GENIUS!!!!! hahahaha thanks! looks like i just turned my "TO DO" list into a "TO DOne" list! hahaha i might just buy a beer bong!!
Jolaessss is offline   Reply With Quote
Old 02-16-2014, 11:09 AM   #18
frs10
Drives: tezla
so does it matter if its AT or MT to change these fluids at different intervals?
frs10 is offline   Reply With Quote
Old 02-16-2014, 11:27 AM   #19
MyRx
MyRx's Avatar
i looked into changing the fluid myself but you need a fluid pump, which i do not have lol
I'll help you do it or else I'll do it myself haha. It's cake. Motul bottles have attached 3-4" tubes on their caps, so I saved a couple incase I choose another brand, that doesn't have the attached tubes.
I've done a few NorCal's and I'm looking to do a couple more soon. You should see the build up of crud on the magnetic drain plugs. It's a lot less after the 3rd change. As for dealer issues, just tell them NOT to change it.
Yes. Contact the dealer or someone obligated to fuss with an AT.
Old 02-21-2014, 11:55 AM   #20
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Suction guns work well and only cost $15.
Scenic Driver is offline   Reply With Quote
Old 10-15-2014, 12:52 AM   #21
yaguphire
Drives: white-out FR-S
Those who have MT notice any differences in shifting after trans oil change?
yaguphire is offline   Reply With Quote
fluid, transmission, transmission fluid
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Change your manual transmission fluid ASAP!!! Kostamojen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 383 12-12-2016 09:29 AM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
