#15 |
Drives: 2013 FRS- Hot Lava
Call Toyota corporate, you shouldn't have to cover this.
Honestly I give this to everyone: always try to work with multiple dealerships when you get answers like this. All dealers are not created equal. |
#16 |
in orbe terrum non visi
Drives: violent
Yes but warranty coverage is decided by the regional manager so going to another dealer in the same area won't help. Southeast denied my syncros claim because the tech sent pictures of my turbo in to him. Very illegal and I'm fighting it now. A different dealer said that's crazy and told me to sue the other dealer.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#17 | |
Drives: Whiteout FRS
ok got the ignition coils, where is #2 and #3 located? Sent from my iPhone using Tapatalk |
#18 |
Drives: The silvertrooper 10 series
2 is the drivers side closest to the front of the car, 3 is passenger side closest to the firewall
| The Following User Says Thank You to 86SPEED For This Useful Post: | vestal52 (10-11-2014) |
#19 | |
Drives: Asphalt FR-S
Powertrain coverage is 5 years or 60,000 miles. The ignition coils are not considered powertrain items and are only listed for coverage for 3 years/36k. They'd be covered by a customer's extended service agreement, or a customer's wallet. |
| The Following User Says Thank You to fledonfoot For This Useful Post: | Sportsguy83 (10-10-2014) |
#20 |
I Love custom Turbo kits
Drives: Limited BRZ
Sneaky bastards...
#21 |
I see it a lot at work with ignition coils on the early 3.5L V6's on the camry and Avalon - they're known for chewing through coils.
Your general rule of thumb for a powertrain component is an "internally lubricated part", or anything mechanical that supplies it with oil. http://www.toyotacertified.com/ebroc...atinum_vsa.pdf Basically, if you look at that link, anything listed in black is covered by the 5/60 powertrain warranty. Anything listed in red is covered 3/36 -- OR if the customer purchased a Platinum VSA/extended warranty, give or take a few exceptions. If you doubt the dealer knows for sure if something is covered, buried deep in the DealerDaily resource we use is a giant list of EVERY powertrain (5/60) covered part. You can have your dealer run the first five digits of the failed part against this list to verify coverage. If we submit the claim to Toyota for reimbursement, and the part does not have a matching 5 digit prefix, the claim is bounced immediately and we are left on the hook for the repair. |
#22 |
#23 | |
Drives: SWP BRZ
#24 | |
Drives: 2013 GBS BRZ Limited
You modified a part of the car that caused a different part to fail prematurely. The turbo clearly increases HP which the syncros need to absorb. THEN they have the evidence that you drive more aggressively than the stock powerplant is intended for. Let me guess - you also have an aftermarket clutch? |
#25 |
Drives: VW GTI
Should not the coils be covered under the 100K emission coverage required by law?
#26 | |
Here's a page out of my warranty handbook at work - this shows coverage for Toyota/Scion products under the emissions warranty. Parts listed 8/80 are your "long term" or "high cost" components. ![]() CA requires long term coverage to 150K on some parts if the car is PZEV certified. The twins are not. |
#27 | |||
Drives: 2015 Series.Blue
Syncros have nothing to do with power. Quote:
Syncros have nothing to do with power or the clutch... The actual gear teeth, yes, but not the syncros. Quote:
Negative, as they're not considered "emissions" devices. |
#28 | |
However the manufacturer would correctly claim that boosting the car would be detrimental to every single piece of the drive train & rotating assembly down to the valve stems. Last edited by stugray; 10-15-2014 at 10:15 AM. |
| CEL P0351 Ignition Coil "A" Primary Control Circuit/Open | romin | Engine, Exhaust, Transmission | 468 | 11-26-2021 04:05 PM |
| Ignition Coil C replacing - need assistance | Synack | Issues | Warranty | Recalls / TSB | 8 | 09-09-2014 03:35 PM |
| Im buying coil overs within the next 2 days i need help deciding what coil overs | Anthony7515 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 06-30-2014 08:47 AM |
| P0354 Ignition Coil Malfunction Trending | Gords_zenith | Issues | Warranty | Recalls / TSB | 8 | 05-15-2014 01:41 PM |
| Coil pack part numbers? | feldy | Engine, Exhaust, Transmission | 6 | 03-11-2014 11:31 AM |
