Old 06-25-2014, 01:01 AM   #1
Anthony7515
brz owner
Drives: 2013 Subaru brz white
Im buying coil overs within the next 2 days i need help deciding what coil overs
Im buying coil overs within the next 2 days i need help deciding what coil overs to go with I'm looking for something under 1200$ and that will be stiffer and handle pretty nice I'm going turbo within the next 2 weeks and need to upgrade my wheels and am not sure what coil overs to get i came across st coil overs for 450$ they have 5k miles on them and are in good condition, should i grab those or buy a different coil over
Anthony7515 is offline   Reply With Quote
Old 06-25-2014, 03:24 AM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Thats a really long sentance.
Yeah id take those ST's so you can save your cash for the turbo. If you dont like how the ST ride, then get some Bilstein B14's.
Dont automatically jump to BC racing or Tein basis. There are comparable options with much better quality behind them.
Old 06-25-2014, 12:00 PM   #3
Dezoris
Dezoris's Avatar
For under 1k you are only going to get a drop, nothing that will perform better than OEM. Better off saving the money and just doing springs for now and saving money for a real damper setup.
Old 06-25-2014, 12:12 PM   #4
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
ST or Parts Shop MAX (Pro coilover...they have a good price on LCAs too). Turn In Concepts was talking about a coilover they carry that's in the lower price bracket as well, I just don't recall the name. Some acronym, most likely.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 06-25-2014, 12:15 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
are you gonna be installing them yourself? and doing alignment yourself?
that would factor into your cost
please don't bother with bottom of the barrel stuff, you'll only live to regret it
or worse, lie to yourself and think you're actually on a good setup.
Old 06-25-2014, 12:35 PM   #6
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Curious why your purchase has to be in next 2 days and you need help deciding.
Don't put deadlines on purchase times. Put more time into the decision making process and getting help from others.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 06-25-2014, 02:23 PM   #7
Anthony7515
brz owner
I'm getting my car turboed next week and on stock tires and wheels it won't cut it lol especially that I'm going for 400-450whp I came across st coilovers at a really good price 450$ shipped have 5k miles on them was seeing if it's smart to go with those for a few months then upgrade to fortune 500's.. Or of I should just get springs for the mean while and my friend would be installing it for 75$
Old 06-25-2014, 02:23 PM   #8
Anthony7515
brz owner
not sure if u need to tune a basic Coilover it's just height adjustable and my friend would install them for me
Old 06-25-2014, 02:28 PM   #9
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
"not sure" are not words you want to use when describing changing the thing that keeps your wheels attached to your car and is generally responsible for comfort and control of your vehicle.
Old 06-25-2014, 02:28 PM   #10
FR-S Matt
I originally started with Tarmac 0's which were decent. I learned my lesson about quality coilovers when I spent the money on the V3's. 0 regrets and love the ride.
Anthony, I don't understand how you are going turbo on your car when you lowball every thread in the for sale section. Just stating from what I have seen....
Old 06-25-2014, 02:47 PM   #11
FloridaBRZ
Drives: 2013 Subaru BRZ Limited 6sp DGM
Are coilovers even worth it for a DD that isn't going to get tracked? I want a comfortable drop and aggressive stance. I was looking at tein flex or the Cusco spec zero. But like I said, I didn't know if those choices would be wasted on a non tracked car.
FloridaBRZ is offline   Reply With Quote
Old 06-25-2014, 02:57 PM   #12
gramicci101
Off Topic
It depends on what you mean by comfortable and aggressive. If you're looking to drop around an inch, springs are fine. Swift, RCE, Eibach, etc... make springs for that. If you need moar low, then coils and lower geometry LCAs are the way to go. If you need to be able to park it on the ground for shows and whatnot, but still drive effectively, then air ride is the way to go.
Old 06-25-2014, 02:58 PM   #13
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
there is no such thing as a comfortable drop that is aggressive
any sort of drop means decreasing the damper's travel, forcing it to work harder, and increasing harshness.
it may feel alright over smooth roads, but not when you start driving on bad pavement.
comfort comes first and foremost from travel, the more space a spring has to compress before it doesn't, the more comfortable it will be, because when a wheel hits an irregularity in the road, it has to move to absorb it. If it has no where to move, it will move the chassis, and that's where your ass comes in.
dropping the car decreases that travel, so more of the shock will go through the chassis and into your ass
that's just the way things are.
so if you want lower and retain comfort, you need to purchase a setup where you get increased damper travel while going lower.
Old 06-25-2014, 03:01 PM   #14
FloridaBRZ
So would either of the two coilovers I was thinking about fit the bill?
Im buying coil overs within the next 2 days i need help deciding what coil overs to Anthony7515 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-27-2014 01:00 PM
ISC N1 coil overs assbox Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-25-2014 01:20 PM
Stance Coil overs or BC coil overs ? tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 11-26-2013 04:13 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 09:12 PM
