Old 09-29-2014, 06:22 PM   #15
sirsol66
Drives: 2013 FRS- Hot Lava
Call Toyota corporate, you shouldn't have to cover this.
Honestly I give this to everyone: always try to work with multiple dealerships when you get answers like this. All dealers are not created equal.
sirsol66 is offline   Reply With Quote
Old 09-29-2014, 06:26 PM   #16
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Yes but warranty coverage is decided by the regional manager so going to another dealer in the same area won't help. Southeast denied my syncros claim because the tech sent pictures of my turbo in to him. Very illegal and I'm fighting it now. A different dealer said that's crazy and told me to sue the other dealer.
Old 10-10-2014, 03:05 PM   #17
vestal52
vestal52's Avatar
Drives: Whiteout FRS
Originally Posted by fteightysix View Post
Ummm.. you have to remove the coil pack to get to the plug.. like i said before, its a 10mm bolt holding the packs down.. i was able to remove the coil pack and the plugs without lifting the engine. total time less then an hour to remove and replace all plugs and coil packs
ok got the ignition coils, where is #2 and #3 located?
vestal52 is offline   Reply With Quote
Old 10-10-2014, 08:19 PM   #18
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
2 is the drivers side closest to the front of the car, 3 is passenger side closest to the firewall
86SPEED is offline   Reply With Quote
The Following User Says Thank You to 86SPEED For This Useful Post:
vestal52 (10-11-2014)
Old 10-10-2014, 10:39 PM   #19
fledonfoot
Drives: Asphalt FR-S
Powertrain warranty is 5 years 50K miles. The dealer HAS to cover that.
Nope, they don't.
Powertrain coverage is 5 years or 60,000 miles. The ignition coils are not considered powertrain items and are only listed for coverage for 3 years/36k.
They'd be covered by a customer's extended service agreement, or a customer's wallet.
fledonfoot is offline   Reply With Quote
The Following User Says Thank You to fledonfoot For This Useful Post:
Sportsguy83 (10-10-2014)
Old 10-10-2014, 10:41 PM   #20
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Sneaky bastards...
Old 10-10-2014, 11:01 PM   #21
fledonfoot
Sneaky bastards...
I see it a lot at work with ignition coils on the early 3.5L V6's on the camry and Avalon - they're known for chewing through coils.
Your general rule of thumb for a powertrain component is an "internally lubricated part", or anything mechanical that supplies it with oil.
http://www.toyotacertified.com/ebroc...atinum_vsa.pdf
Basically, if you look at that link, anything listed in black is covered by the 5/60 powertrain warranty. Anything listed in red is covered 3/36 -- OR if the customer purchased a Platinum VSA/extended warranty, give or take a few exceptions.
If you doubt the dealer knows for sure if something is covered, buried deep in the DealerDaily resource we use is a giant list of EVERY powertrain (5/60) covered part. You can have your dealer run the first five digits of the failed part against this list to verify coverage. If we submit the claim to Toyota for reimbursement, and the part does not have a matching 5 digit prefix, the claim is bounced immediately and we are left on the hook for the repair.
Old 10-11-2014, 02:51 PM   #22
vestal52
vestal52's Avatar
thank you so much for the help bro, I really appreciate it.
I'll make sure my next vendor purchase is from you!
Old 10-13-2014, 11:28 AM   #23
mmor101
Drives: SWP BRZ
You add power to a vehicle and the syncros wear yet you still want them to fix the problem?
mmor101 is offline   Reply With Quote
Old 10-13-2014, 12:06 PM   #24
stugray
Drives: 2013 GBS BRZ Limited
No NOT even close to illegal. And in fact you fall into the category that the Mag-Moss act specifically addresses.
You modified a part of the car that caused a different part to fail prematurely.
The turbo clearly increases HP which the syncros need to absorb.
THEN they have the evidence that you drive more aggressively than the stock powerplant is intended for.
Let me guess - you also have an aftermarket clutch?
Old 10-13-2014, 07:31 PM   #25
dbletap
Drives: VW GTI
Should not the coils be covered under the 100K emission coverage required by law?
dbletap is offline   Reply With Quote
Old 10-14-2014, 08:58 AM   #26
fledonfoot
Coils are covered 3/36 or 3/50 in California - they are not long term emissions components. Federal coverage on the "high cost" or "long term" components are 8/80
Here's a page out of my warranty handbook at work - this shows coverage for Toyota/Scion products under the emissions warranty. Parts listed 8/80 are your "long term" or "high cost" components.
CA requires long term coverage to 150K on some parts if the car is PZEV certified. The twins are not.
Old 10-14-2014, 08:48 PM   #27
Poodles
Drives: 2015 Series.Blue
Syncros have nothing to do with power.
Syncros have nothing to do with power or the clutch... The actual gear teeth, yes, but not the syncros.
Negative, as they're not considered "emissions" devices.
Old 10-15-2014, 12:11 AM   #28
stugray
Not directly if you shift correctly.
However the manufacturer would correctly claim that boosting the car would be detrimental to every single piece of the drive train & rotating assembly down to the valve stems.
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 04:05 PM
Ignition Coil C replacing - need assistance Synack Issues | Warranty | Recalls / TSB 8 09-09-2014 03:35 PM
Im buying coil overs within the next 2 days i need help deciding what coil overs Anthony7515 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-30-2014 08:47 AM
P0354 Ignition Coil Malfunction Trending Gords_zenith Issues | Warranty | Recalls / TSB 8 05-15-2014 01:41 PM
Coil pack part numbers? feldy Engine, Exhaust, Transmission 6 03-11-2014 11:31 AM
