#29 | |
Drives: Silver Ignition Gundam
#30 |
Drives: 2013 FRS
#31 | |
When I put on the original 3rd brake light, it was off centered by like half an inch. Bugged the hell out of me. Ended up taking it all off. Stripping down the original tape to plastic which took forever. Then measured and measured until it was centered and taped it masking tape for perfect alignment. Stuck it on with 1/2 in tape and realized how ugly it looked through the window. Stripped again and did it with 1/4 inch tape, and got the idea to wrap the inside with carbon fiber vinyl. Put it on, then realized the window got dirty again...stripped it off one last time, cleaned the window and put it back on... now i'm happy.
#32 | |
Drives: 2013 FRS
at least it's perfect now lol
#33 | |
Drives: 2013 Subaru BRZ
"Relatively Easy Solution"
#34 | |
#35 |
Drives: 2013 Subaru BRZ limited
Thanks OP, mine came out great! good find!
#36 |
Elite Recognized Geek
Drives: 2014 DGM BRZ Limited
Got the CDC brake light installed over the weekend (along with the Beatsonic sharkfin). Grainy smartphone pics to follow:
![]() ![]() I'm quite pleased with how it turned out. It took me about three hours total, including a run to Autozone (for a panel removal tool) and another to Michael's (for the adhesive felt to patch the rear deck). Thanks again @Phaedrus29 for paving the way!
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+ |
#37 |
Quick question. Just found this thread. How's this solution holding up to over 8 months of being stuck up there? Falling off or separating at all? This looks SOOOO much better than the spaceship 3rd brake light it came with. GREAT Find!! Thanks for the DIY.
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
#38 |
Drives: 2015 Halo FRS Automatic
I did this September 2014 and it has not come loose at all. I did use a heat gun to warm up the plastic, then held it firmly against the window with a rag until cool on both sides so that it perfectly lines up with the curve of my window. Great mod and inexpensive.
#39 | |
#40 |
Thanks fellas!! Think l'ma do this VERY soon!!
#41 |
#42 |
Drives: SWP BRZ Limited Manual. 2014
I wish there was an easier way to remove the rear brake light.
I am way too stupid and clumsy for this by myself!
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|] |
| What's the official solution to bypassing the VSS + e-brake sensor for videos? | [Cyanide] | Electronics | Audio | NAV | Infotainment | 37 | 05-05-2015 01:51 AM |
| 3rd brake light rattle easy fix | xITSxTHExPOPEx | Electronics | Audio | NAV | Infotainment | 2 | 12-14-2014 06:14 PM |
| Solution for easy changes to rear camber and toe (street and track use) | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-11-2014 05:28 PM |
| APR Performance brake cooling solution | whataboutbob | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-18-2013 01:33 PM |
| Cheap, easy brake mod! | CBR600RR | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 09-19-2012 07:39 PM |
