Old 08-15-2014, 01:07 AM   #1
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Easy Third Brake Light Solution
Removed the annoying third brake light today and installed a new high mount one!
The light we installed comes with the housing and everything...it's ready to go. It's made by Classic Design Concepts for a Ford Mustang, called a High Mount Third Brake Light. I ordered one hoping it would fit, figuring I could return it uninstalled if the fit didn't work. It fits in the BRZ perfectly IMO!
It comes with 3M tape on it already, and attaches to the rear window. Overall, the installation was pretty easy. Here's what we did:
1. Disconnect the third brake light wire (accessible from the trunk) and remove the rear deck.
We did NOT follow the DIY for removing the rear deck, which says to remove all the adjacent trim panels. Instead, we followed the simpler instructions I found here in his Step 1: http://www.ft86club.com/forums/showthread.php?t=14159
Basically, remove the four black clips exposed once you lower the rear seats. Then, carefully, I fit my hand right under the rear deck where the white clips are, and pushed the deck up, while my friend pitched the clips we could see from underneath with a pair of pliers (I'm not sure if this is necessary). (Sticking a panel clip tool in there might be even safer.) We started with the two white clips near the center of the deck before moving to the clips on the side (there are 4 white clips in total on the deck). The deck comes out without having to remove the other panels...just be careful not to bend it too much.
2. Drill the plastic rivets out that hold the stock third brake light to the rear deck...then open the stock brake light and unhook the stock wires from the LEDs. This thread was very helpful throughout the process, and has good pics for this step: http://www.ft86club.com/forums/showthread.php?t=61533
3. With your preferred method, connect the stock third brake light wires to the wires from the new High Mount Light.
The green stock wire is powered and connects to the red wire on the new light. The white stock wire is ground and connects to the black wire on the new light. Once attached, you can just plug the stock wire harness back in.
4. Test that the light works!
5. Clean window with alcohol solution, then affix new light to window.
Not a great pic...we put the new light basically up against the headliner, but not tucked under. Tucking under the headliner might work, but the housing is raised slightly where the wire passes out of it. We chose to mount right outside the headliner to avoid damaging the headliner.
6. Feed/Tuck the wire inside the pillar on the passenger side.
We removed two clips on the headliner...the wire was passed behind the clip on the passenger side...then down the pillar on that side. We put some wrap around the wire connectors under the rear deck, just to avoid any potential future rattles.
Here is how the light looks installed (through my 30% tint):
Light off in this pic:
Here is a pic showing the view from the rear view mirror...as you can see the new light housing is not invisible, but is a huge improvement IMO:
The light does not shine at all into the cabin.
7. Cover the holes in the rear deck, and reinstall.
For a quick fix, I got some black sticky-back felt from Michaels. The color is a close match:
You could potentially wrap the whole deck, but honestly I think it looks fine.
That's it. Let me know if you have any questions...sorry for the crap pics.
Phaedrus29 is offline   Reply With Quote
Old 08-15-2014, 01:22 AM   #2
DarkestBuddha
Drives: BRZ limited GBS
nice
here the link for other ppl http://www.americanmuscle.com/highmo...ight-9909.html
http://shop.classicdesignconcepts.co...-light-1999-14
only $50
DarkestBuddha is offline   Reply With Quote
Old 08-15-2014, 01:34 AM   #3
Phaedrus29
Phaedrus29's Avatar
Originally Posted by DarkestBuddha View Post
Ya I forgot to mention the price. I ordered from American Muscle but the light is available from many vendors. American Muscle had the light in stock and it arrived super quick.
Old 08-15-2014, 02:34 AM   #4
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
Very useful thread! I will probably do this when I get around to it!
Old 08-15-2014, 09:16 AM   #5
Iddoit2er
Drives: S
Nice, but will there be any problem affixing 3m tape to tint down the road?
Iddoit2er is offline   Reply With Quote
Old 08-15-2014, 02:00 PM   #6
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
curious if this would work with a roof spoiler.
Chen is offline   Reply With Quote
Old 08-15-2014, 04:26 PM   #7
Phaedrus29
Phaedrus29's Avatar
Took a better pic showing the look from the rear view mirror:
And another showing the light on/installed:
Old 08-15-2014, 05:01 PM   #8
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
Yep, adding this to my wishlist. Thanks for taking the risk and letting us know it turned out so well!
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 08-15-2014, 05:09 PM   #9
8R6
8R6's Avatar
Drives: FRS
thanks for finding the part! i need to do this soon. at first i thought i could deal with the stock 3rd brake light but everyday that passes, it annoys me more and more. lol
8R6 is offline   Reply With Quote
Old 08-15-2014, 05:26 PM   #10
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Awesome! Thanks man. Was about to make my own but for $50 bucks Ill be buying this!
GotBRZ1691 is offline   Reply With Quote
Old 08-17-2014, 01:43 AM   #11
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
you are the man OP. next on the list of to-do
86-tundra is offline   Reply With Quote
Old 08-19-2014, 05:54 PM   #12
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Love how easy to do, OEM looking, and cheap this is. Can't wait to do this!
xxBrun0xx is offline   Reply With Quote
Old 08-19-2014, 05:57 PM   #13
Phaedrus29
Phaedrus29's Avatar
Just a quick note that I realized I didn't reinstall my rear deck correctly...it wasn't as low as it should be and was raised up in the center. I figured out the cause was that there is a part of the plastic under the stock third brake light that is supposed to poke into the trunk and hook on the metal. I tried to take a picture:
The circle part (which is toward the rear of the car) pokes into the trunk and hooks on the metal. So just look out for this when you are reinstalling the deck. Here was the older pic again with the deck messed up:
Here's an updated pic of the rear view with the deck fixed:
I'm not sure you can tell from the pics, but the new view is even better.
Old 09-13-2014, 07:18 PM   #14
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
So glad I found this! I like it. But more info on that '68!
Found it for a decent price where I get a lot of my pony parts: http://www.cjponyparts.com/catalog/p...t/BL7/id/3114/
I'll be adding this to my next order.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
What's the official solution to bypassing the VSS + e-brake sensor for videos? [Cyanide] Electronics | Audio | NAV | Infotainment 37 05-05-2015 01:51 AM
3rd brake light rattle easy fix xITSxTHExPOPEx Electronics | Audio | NAV | Infotainment 2 12-14-2014 06:14 PM
Solution for easy changes to rear camber and toe (street and track use) dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-11-2014 05:28 PM
APR Performance brake cooling solution whataboutbob Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-18-2013 01:33 PM
Cheap, easy brake mod! CBR600RR Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2012 07:39 PM
