Old 02-11-2013, 06:24 PM   #1
whataboutbob
AutoX-10/10ths every run
APR Performance brake cooling solution
Just saw this on FB:
http://www.facebook.com/photo.php?fb...8605413&type=1
Not a lot of details other than the photo at this point.
Build thread:Here
Old 02-11-2013, 06:55 PM   #2
Synack
Boosted
Synack's Avatar
Drives: Sideways
I'll be buying this if it actually works
Old 02-12-2013, 01:40 PM   #3
KVDB31
KVDB31's Avatar
Drives: 2013 FR-S Asphault
We did some brake ducts on a project car in college, very similar in design to these (on a Mini Cooper GP) and the gains weren't in braking power, but in sustaining it. It helped the brakes cool down between hard braking cycles, which protected from boiling the fluid, and prolonged the brake fade. The fade was the biggest impact - our tests would show the braking getting worse over repeated hard cycles, but this effect improved with cooling ducts.
This is an upgrade that isn't really functional for anything but the track.
However, they look BADASS and I wouldn't make fun of anyone with them on their daily driver just for the looks!
KVDB31 is offline   Reply With Quote
Old 02-12-2013, 01:45 PM   #4
jstn
Drives: '15 Vortech Supercharged
If only brake ducts were STX legal. Not that autocross is really demanding enough to need them I guess.
jstn is offline   Reply With Quote
Old 02-12-2013, 02:21 PM   #5
Synack
Boosted
Synack's Avatar
Drives: Sideways
That's why I want this, brake fade is a bitch.
Old 02-12-2013, 03:05 PM   #6
Racecomp Engineering
It doesn't look like the backing plates are going to do a great job of directing air to the center of the rotor. You want the air to go through the vanes, not just blow in the general direction of the rotor face. A picture of them mounted would help clear that up.
- Andrew
Racecomp Engineering is online now   Reply With Quote
Old 02-12-2013, 03:13 PM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
- Andrew
This. I want to see a pic of them installed. APR makes nice stuff so I'm assuming they know how to do brake ducts
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 03:26 PM   #8
Hanakuso
I wonder if these will fit BBKs such as the Essex kits since those dust shields are smaller then stock.
I wish Essex made a ducting adapter since those are more ideal for air flow to the center. Sprint kit + Sprint air duct adapter + Just the APR front air ducts would probably be the best setup ever
Hanakuso is offline   Reply With Quote
Old 02-13-2013, 03:42 PM   #9
KVDB31
KVDB31's Avatar
- Andrew
Yes, that's a great point as well. We found this to be particularly important during our testing. It needs to get directed into the center of the rotor to make use of the vanes effectively.
Old 02-14-2013, 02:49 PM   #10
whataboutbob
Looks like I was 5 days late on this, other thread here: http://www.ft86club.com/forums/showthread.php?t=28354
Build thread:Here
Old 02-18-2013, 11:06 AM   #11
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Old 02-18-2013, 11:21 AM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Damn looks like it puts air on the inside face of the rotor only
It needs to put it into the center of the rotor. I actually expect better out of APR.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-18-2013, 01:33 PM   #13
jflogerzi
jflogerzi's Avatar
Definitely track use only. I plan to add better pads, steel lines and new fluid when it comes time for a brake change. In normally use, how long will these pads(stock ones) last?
TF Brake Duct Cooling Kit Touge Factory Tracking / Autocross / HPDE / Drifting 77 06-11-2015 07:01 AM
Robispec total cooling solution group buy robispec Groupbuys 103 11-21-2013 12:41 PM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
Carbon Fiber Brake Cooling Duct JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 7 10-25-2012 12:03 AM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
