Old 09-26-2014, 07:16 PM   #1
vestal52
vestal52's Avatar
Drives: Whiteout FRS
ignition coil pack #2 and #3, dealer won't cover
ok so I have 43,500 miles on my car, I bring car in to see if it's covered but apparently not and I will be charged upwards of up to 800 dollars to replace.
told that it's covered up to 36,000 miles only! so I'm really annoyed now.. I've bought cars always at Toyota I just wish they could have a good will just this once but it's a dealer, what am I to expect..
so now I have to pay for the diagnostics which I had already told them the codes right before.. a 5 year old could do it.. and they tell me what I had already told them
great..
is there anything I could do? I thought engine problems were covered up to 60,000 miles
vestal52 is offline   Reply With Quote
Old 09-26-2014, 07:18 PM   #2
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
buy them yourself for 120$ each then replace them yourself.. just 1 10mm bolt on each coil pack.. very easy to do
86SPEED is offline   Reply With Quote
Old 09-26-2014, 07:19 PM   #3
vestal52
vestal52's Avatar
oh where is it for 120? dealer parts was charging me 150
Old 09-26-2014, 07:27 PM   #4
86SPEED
86SPEED's Avatar
http://parts.subaru.com/p/Subaru__BR...2433AA650.html
subaru parts are the same as scion parts
Old 09-26-2014, 07:29 PM   #5
vestal52
vestal52's Avatar
cool, thanks bro
Old 09-26-2014, 07:34 PM   #6
celica73
$80
https://www.subarugenuineparts.com/
Old 09-26-2014, 07:35 PM   #7
86SPEED
86SPEED's Avatar
Originally Posted by celica73 View Post
that was the website i was originally looking for.. i knew i seen them somewhere for 80.. luckily i only needed plugs
-Thomas
Old 09-26-2014, 07:35 PM   #8
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I was under the impression that they were impossible to get to without lifting the engine 5"+?
Decay107 is offline   Reply With Quote
Old 09-26-2014, 07:37 PM   #9
vestal52
vestal52's Avatar
oh so they're not as easy to get to as said?
where is #2 and #3 located?
Old 09-26-2014, 10:19 PM   #10
86SPEED
86SPEED's Avatar
i replaced all the plugs without lifting the engine.. you dont need to.. remove the injector covers and thats it.. 14mm deep socket, 3" extension
The Following 3 Users Say Thank You to 86SPEED For This Useful Post:
Decay107 (09-27-2014), Sportsguy83 (09-29-2014), vestal52 (10-11-2014)
Old 09-27-2014, 12:02 AM   #11
vestal52
vestal52's Avatar
plugs.. same thing as the coil pack?
Old 09-29-2014, 03:18 PM   #12
86SPEED
86SPEED's Avatar
Ummm.. you have to remove the coil pack to get to the plug.. like i said before, its a 10mm bolt holding the packs down.. i was able to remove the coil pack and the plugs without lifting the engine. total time less then an hour to remove and replace all plugs and coil packs
The Following 2 Users Say Thank You to 86SPEED For This Useful Post:
CK_Bladesmith (09-29-2014), vestal52 (10-11-2014)
Old 09-29-2014, 03:43 PM   #13
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Powertrain warranty is 5 years 50K miles. The dealer HAS to cover that.
Old 09-29-2014, 03:58 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Your dealer is incompetent and you also didn't know your own warranty coverage. FYI it's in the Warranty booklet with the Owner's manual:
http://www.scion.com/cars/FR-S2014/warranty/
-alex
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 04:05 PM
Ignition Coil C replacing - need assistance Synack Issues | Warranty | Recalls / TSB 8 09-09-2014 03:35 PM
Im buying coil overs within the next 2 days i need help deciding what coil overs Anthony7515 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-30-2014 08:47 AM
P0354 Ignition Coil Malfunction Trending Gords_zenith Issues | Warranty | Recalls / TSB 8 05-15-2014 01:41 PM
Coil pack part numbers? feldy Engine, Exhaust, Transmission 6 03-11-2014 11:31 AM
