Old 09-25-2014, 09:58 PM   #1
Tenchi
Tenchi's Avatar
Drives: Silver Ignition 6MT 10 series FR-S
Engine knocking after flash
I wAs running e85, ran the the tank empty and then filled up with 93. Let the car run for a few minutes then flashed with my OFT to a 93 octane map. When I went to restart the car bucked and stumbled then after 20 seconds or so started idling down. I watched the fuel trims and they are high around 6-10. In neutral I rev the engine a little and I can hear it knock. Please help!!
Tenchi is offline   Reply With Quote
Old 09-25-2014, 10:04 PM   #2
Tenchi
Tenchi's Avatar
Old 09-25-2014, 10:20 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
I recently went back from E85 to petrol. I didn't get any knock but I had huge fuel trims for a while. But I flashed back to 1.59 as I new my car ran well on it. I am saving the 2.06 tunes for my second tank of petrol.
If you are experiencing knock maybe flash the 91 tune and drive conservatively and moniter you AFR for this tank while it still has some ethanol in the mix.
1974 TA22 Celica
2013 86 GT
Old 09-25-2014, 10:20 PM   #4
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You aren't hearing knock in neutral while revving the engine. That's going to be pretty much impossible. It's likely you are just hearing some exhaust popping as the e85 slowly flushes out of the system. If you just let it idle, it will take several minutes for the E85 in the fuel lines to flush. Instead, I recommend just driving it normally as the extra engine load will speed the process up.
Shiv@Openflash is offline   Reply With Quote
Old 09-25-2014, 10:35 PM   #5
Tenchi
Tenchi's Avatar
Old 09-25-2014, 10:50 PM   #6
Shiv@Openflash
Drives: 2013 FRS
Those positive fuel trims are normal when you are running residual E85 on a pump gas map. No need to worry.
Old 09-25-2014, 10:55 PM   #7
Tenchi
Tenchi's Avatar
Thanks Shiv. I was having a panic attack. She's running smoothly now. Why would ignition adv be around 40?
Old 09-25-2014, 10:58 PM   #8
Shiv@Openflash
Drives: 2013 FRS
Because that is where it is supposed to be when you are revving your engine like that
Old 09-25-2014, 11:01 PM   #9
Tenchi
Tenchi's Avatar
Lol oh poor me. Thanks Shiv.
Old 09-25-2014, 11:24 PM   #10
Shiv@Openflash
Drives: 2013 FRS
No sweat
Old 09-25-2014, 11:50 PM   #11
steve99
Drives: FT86
have a read of the links below theier is a pain free proceedure to swith between e85 and petrol and vice versa
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 08:09 PM
Wheels Knocking kalamitykode Issues | Warranty | Recalls / TSB 1 05-21-2014 05:50 PM
Overpipe knocking? Shaun Perry Northern California 17 03-27-2014 11:31 AM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Knocking on Startup? 636 Issues | Warranty | Recalls / TSB 17 02-03-2014 07:18 AM
