Old 02-11-2014, 08:30 PM   #1
Cross
It's the Mad Cow
Cross's Avatar
EcuTek Flash finished but now it shows only a Partial Flash...
So I decided to load the new Racerom features and a change to my tune tonight before I left work. Everything goes as normal, load the tune everything goes as it normally does but when I got to start the car nothing...
So I go to check the tune and it askes me to relicense it as its only a partial flash....
So here I am sitting at work stuck and I cannot reflash my PCM nor revert back to stock... I am just stuck.... The need to reflash a PCM when an issue happens has to have come up before, who has experienced this? I could use some insight.
Cross is offline
Old 02-11-2014, 08:31 PM   #2
jamesm
Select the vehicle ecu manually (not with detect vehicle) and flash again. It'll pop up to confirm the selected rom is correct then flash as normal. Autorecovery
jamesm is offline
Old 02-11-2014, 08:32 PM   #3
jamesm
Also make sure you have the software up to date before loading in the new feature file and flashing, if possible.
jamesm is offline
Old 02-11-2014, 08:32 PM   #4
Cross
It's the Mad Cow
Cross's Avatar
I tried that it asked me for another license....
Cross is offline
Old 02-11-2014, 08:33 PM   #5
Cross
It's the Mad Cow
Cross's Avatar
I checked earlier but I will check again right now.
Everything is up to date.
Cross is offline
Old 02-11-2014, 08:34 PM   #6
jamesm
That's weird it's never asked me for another license before, usually just flashes on. @EcuTek?
jamesm is offline
Old 02-11-2014, 08:38 PM   #7
Cross
It's the Mad Cow
Cross's Avatar
There are the screen shots of each step... it will not reflash....
Cross is offline
Old 02-11-2014, 08:41 PM   #8
Cross
It's the Mad Cow
Cross's Avatar
I tried going back to OFT but that doesn't work because I have to have the stock Rom in place... great I am stuck.
Cross is offline
Old 02-11-2014, 08:50 PM   #9
Cross
It's the Mad Cow
Cross's Avatar
http://www.ft86club.com/forums/showthread.php?t=54438
This user had a very similar problem and says @EcuTek went in through Recovery mode. @jamesm would you happen to know how to get into recovery mode?
Cross is offline
Old 02-11-2014, 08:53 PM   #10
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Contact your master tuner if you haven't already. That would be the quickest way to get a license thrown on there so you can attempt again.
Xero-Limit is offline
Old 02-11-2014, 08:55 PM   #11
Cross
It's the Mad Cow
Cross's Avatar
Yeah he is not answering... and he is not a member here anymore....
Cross is offline
Old 02-11-2014, 09:03 PM   #12
Xero-Limit
Xero-Limit's Avatar
Well that's a problem. Check your PM in about one minute.
Old 02-11-2014, 09:09 PM   #13
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The reason your OFT won't write to the ecu is due to Ecutek's "overwrite protection" which changes the security algorithms so that only Ecutek software can write to the ECU. Not even the dealership can recover your ECU at this point
You'll need to use the ecutek software to flash a ecutek "stock" file to your ECU to restore original factory security algorithms.
Shiv@Openflash is offline
Old 02-11-2014, 09:14 PM   #14
Cross
It's the Mad Cow
Cross's Avatar
Thats what I normally have to o but since I can't flash it at all that leaves me well... stuck.
But a huge thanks to Mike, it looks like he may be able to help me out!!
Cross is offline
Ecutek flash & warranty 3000HP Software Tuning 40 04-06-2015 10:33 AM
Ecutek Corrupt ECU, Bad Flash, Can i reset? gdrider77 Software Tuning 48 07-04-2014 12:25 AM
FA20CLUB ecutek flash mach330 Software Tuning 19 08-09-2013 10:35 AM
DynoComp EcuTek Flash JRollar Engine, Exhaust, Transmission 8 01-16-2013 06:16 PM
FA20 Stg 2 Ecutek flash or no? DC-FRS Engine, Exhaust, Transmission 25 12-25-2012 07:13 AM
