Old 09-13-2014, 08:09 PM   #15
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by 2point0 View Post
So glad I found this! I like it. But more info on that '68!
Found it for a decent price where I get a lot of my pony parts: http://www.cjponyparts.com/catalog/p...t/BL7/id/3114/
I'll be adding this to my next order.
I actually originally placed my order with CJ Pony Parts, but got a message that it was backordered there...American Muscle had it in stock. Maybe CJ has stocked the part by now.
It's a '68 convertible...my friend rebuilt the engine for me and basically put the car together. The engine (289) was originally out of a '67 that my parents owned. My friend threw a 5 speed transmission in there and I recently had the rear gears changed which really woke up the car...it originally had a 3 speed. Here's a quick pic but I should definitely take more:
Phaedrus29 is offline   Reply With Quote
Old 09-14-2014, 12:09 AM   #16
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Nice! My '67 is an original 3spd and I also now have a 5spd (T-5). Just got a new fuel tank, need to order some lines next.
Nice pair of cars you've got there.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 09-14-2014, 01:11 PM   #17
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
This looks like a great way to get rid of the annoying rattle from the rear deck if you have subs...
Sellout is offline   Reply With Quote
Old 09-14-2014, 11:17 PM   #18
Herndon
Herndon's Avatar
Drives: 2014 SWP BRZ
just put my order in for from cjponyparts. Thinking of having the deck wrapped in alcantara while its off.
Herndon is offline   Reply With Quote
Old 09-15-2014, 03:35 AM   #19
IgnitionGundam
IgnitionGundam's Avatar
Drives: Silver Ignition Gundam
Thank you bro. I've been waiting for this solution for awhile!
IgnitionGundam is offline   Reply With Quote
Old 09-16-2014, 01:51 AM   #20
Tjbugs1
Tjbugs1's Avatar
Drives: Subaru BRZ
So back to tint for a minute, anyone who is tinted try this yet? OP you are awesome, looks very nice!
Edit: OP I don't know how I missed that you have tint. How did the 3M go for you?
Originally Posted by My Wife
Wait, where does the key go? WAIT, WHERE IS THE KEY?
Tjbugs1 is offline   Reply With Quote
Old 09-16-2014, 03:15 AM   #21
Phaedrus29
Phaedrus29's Avatar
The 3M worked fine on the tint. There are a couple small spots that looks like they might be air pockets or something where the tape isn't fully seated/flush (or where perhaps the tint pulled up a bit...I'm really not sure). The issue was there right away...it's not something that developed over time. It's really very minor/small...I can try to take some pics.
Regarding the tint, I did worry somewhat about what will happen when I need to replace a bulb in the brake light...but perhaps it will be a non-issue.
Still smiling every time I look out of my rear window.
The Following User Says Thank You to Phaedrus29 For This Useful Post:
Tjbugs1 (09-20-2014)
Old 09-16-2014, 07:44 AM   #22
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
so far so good on my car as well, and it is tinted. I have the same concern if I ever need to pull it off, as I'm pretty sure the tint will come off with the 3M. Hopefully these are good LEDs that will last.
I don't have any pictures up after I did it, but looks identical to the OP's pictures, except on a Raven FR-S.
malave7567 is offline   Reply With Quote
The Following User Says Thank You to malave7567 For This Useful Post:
Old 09-16-2014, 12:17 PM   #23
Phaedrus29
Phaedrus29's Avatar
Glad to hear someone else has done this and likes it, but you know what they say about not having pics. Snap some quick ones!
Are you having any issue with the 3M being fully flush all the way around? I just have two small spots in the corners where it isn't quite 100%, but it's not terrible by any means. I suspect it has more to do with my installation than anything else.
Old 09-16-2014, 12:56 PM   #24
malave7567
malave7567's Avatar
Unfortunately for me, I stuck it on there a little bit off center. Should have woken the wife up to offer a second hand when installing. Have left it alone for now because I'm pretty sure that when it finally gets loose, it will pull tint with it.
Old 09-16-2014, 02:38 PM   #25
wheelhaus
wheelhaus's Avatar
FYI I made a similar mod from carbon fiber if anyone is interested, thread is here.
Old 09-17-2014, 11:37 AM   #26
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
you could probably try removing it with a heat gun. if the tint comes off at all, you could separate it with the heat gun and then reapply.
86-tundra is offline   Reply With Quote
Old 09-17-2014, 12:47 PM   #27
Phaedrus29
Phaedrus29's Avatar
Looks fine in the pic...but yes, I make sure to have the wifey around for any install like this.
Here are some very crappy pics I shot yesterday of the minor issue I have (there's another spot like this on the other side):
It really looks to me like it's an issue with my tint...and I THINK it wasn't like that before the brake light install...I'm not really sure how that happened (maybe from all the pressure I was applying to the window when pushing on the new brake light???). It's really very minor, but unfortunately that's under/inside the new third brake light so I can really access it easily to smooth out the tint.
Doesn't really bother me, but I just wanted to share the issue.
Old 09-17-2014, 01:11 PM   #28
malave7567
malave7567's Avatar
I haven't seen anything like you've shown in your pic. I will keep my eye on it though. It has stood up to Houston heat and humidity well.
As for my light, it might not be completely way off, but more than enough to make me notice it (especially when you see it on, as I did once I had a helper press brakes for me). I'm just leaving it as it is until I have time to maybe get at it with a heat gun like trevorovert suggested. Would have to go to a friend's house to borrow their garage so I have a power outlet nearby, lol. The joys of apartment life...
What's the official solution to bypassing the VSS + e-brake sensor for videos? [Cyanide] Electronics | Audio | NAV | Infotainment 37 05-05-2015 01:51 AM
3rd brake light rattle easy fix xITSxTHExPOPEx Electronics | Audio | NAV | Infotainment 2 12-14-2014 06:14 PM
Solution for easy changes to rear camber and toe (street and track use) dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-11-2014 05:28 PM
APR Performance brake cooling solution whataboutbob Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-18-2013 01:33 PM
Cheap, easy brake mod! CBR600RR Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2012 07:39 PM
