Old 09-08-2014, 10:10 AM   #687
ML
ML's Avatar
Drives: 13 White MT FR-S
anyone else get a really loud backfire if you rev out 1st and then push in the clutch to put it into 2nd? I get this all the time since putting the 2.0 maps on.
The Following User Says Thank You to ML For This Useful Post:
lucid215 (09-08-2014)
Old 09-08-2014, 10:35 AM   #688
lucid215
are you running catless? i get the same but im also running catless headers and front pipe. its nothing to worry about. its a little back fire from running with no cats. also @steve99 thanks for pointing out the maf scaling. car runs a lot better now and the a/f is pretty much dead on and where it needs to be. thanks again
lucid215 is offline   Reply With Quote
Old 09-08-2014, 10:48 AM   #689
Venator
Venator's Avatar
Drives: Asphalt FR-S
I run 2.0 OTS and a catless UEL with no backfiring at all.
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 09-08-2014, 05:45 PM   #690
DC2R
Drives: 2014 Scion FR-S
It's scaling really needed if you just have a drop in?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 09-08-2014, 05:52 PM   #691
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Until you datalog both open and closed loop how do any of us really know?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-08-2014, 05:55 PM   #692
steve99
Drives: FT86
not requird for drop in filters
required if you change position of maf sensor, diameter of tube maf sits in or something that altrs flow around maf sensor
Old 09-08-2014, 05:56 PM   #693
lucid215
from what i understand is you only really need to scale in you change out the whole intake. im running the afe/takeda intake so i needed to rescale it. when changing the maf tube is when you need to
Old 09-08-2014, 05:56 PM   #694
lucid215
haha you beat me to it
The Following User Says Thank You to lucid215 For This Useful Post:
steve99 (09-08-2014)
Old 09-08-2014, 06:34 PM   #695
DC2R
Thanks everyone! You guys are great!
The Following User Says Thank You to DC2R For This Useful Post:
Old 09-08-2014, 07:36 PM   #696
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by clintavo View Post
Has anyone else noticed hesitation/ bogging at 1500 rpm when floored?
I realize this is a somewhat rare scenario, but I have run into it twice:
Loafing around a parking lot in 2nd gear, suddenly to get out of someone's way.
Starting from a stop uphill.
It is repeatable; floor it at 1500 rpm and it completely bogs. It never happened with 1.3 or 1.6
BTW the throttle calibration seems much smoother in this tune : )
Thanks Shiv!
YES. Been noticing this as well on Stage 1 91oct, only when I try to do a moderate launch from stop in 1st. Never noticed it before flashing 2.0
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
zdr93523 (09-17-2014)
Old 09-08-2014, 08:40 PM   #697
Turdinator
Señor Member
Turdinator's Avatar
Needed? No.
Would it be benificial? Probably yes.
1974 TA22 Celica
2013 86 GT
Old 09-09-2014, 02:00 AM   #698
clintavo
I never got a log to load properly to Datazap. Instead, I went back to the 1.6 tune
clintavo is offline   Reply With Quote
Old 09-09-2014, 02:07 AM   #699
clintavo
double post
Old 09-09-2014, 11:20 PM   #700
lucid215
heres a little cruising log i did. to me it looks good. only thing i see is around 2800-2900 rpms i will run a tad rich under light throttle and load. what do you think?
http://www.datazap.me/u/lucid215/cru...log=0&data=1-7
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
