Old 04-16-2014, 03:28 PM   #225
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
I just saw this.
Do you want me to answer with facts or opinions as to why we chose one over the other?
Zero issues. How's this? We've blown up stock engines in less miles than we've put on with the SC.
Both facts and opinions if you don't mind.
That's good to hear and reassuring, and funny/sad that it's a more reliable setup for you guys than the stock motors you lost
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following User Says Thank You to smbstyle For This Useful Post:
zeppy (05-18-2014)
Old 04-16-2014, 03:47 PM   #226
CSG Mike
CSG Mike's Avatar
PM'd
smbstyle (04-16-2014)
Old 07-18-2014, 01:53 AM   #227
DriftEm
DriftEm's Avatar
Originally Posted by Sellout View Post
Now you get what you should expect. If you drive like an ass through Mira Mesa with your twin screw kit you're not going to be seeing 35mpg.
I guess you talking about me, sorry I scared you. I'll be gentle next time
DriftEm is offline   Reply With Quote
Old 07-18-2014, 08:26 AM   #228
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
I was wondering if you would notice that... I haven't actually seen your car, I have a buddy that works down near the Sorrento Valley end of Mira Mesa Blvd and he's mentioned it to me.
I drive like an ass through Mira Mesa too
Sellout is offline   Reply With Quote
Old 08-30-2014, 12:48 AM   #229
Yui-Chan
Drives: Toyota
I like this post and thread. Very inspirational to get the JR kit. I like especially as it was done on a completely stock car and also raises the concern of heat soak within FI kits.
I was interested in the Innovate kit too. But after reading more about it and how the IC works, it seems a bit more complicated in its design. I never knew it was fluid to air cooled. I definitely don't want additional fluids and a radiator just to cool it. Seems like added complication. Its easy prefer air to air like ICing like on traditional turbos. The design in general seems restrictve as well, being a cooling plate right inside the plenum against the air flows path. Lastly, the actual SC is right on top of the block, which I'm sure will account for added heat soak compared to something not directly on top.
What's the psi anyways of the standard JR kit?
I assume your 245whp is using the stock pulley/psi too.
Do the other pulleys work on it?
Yui-Chan is offline   Reply With Quote
Old 08-30-2014, 01:44 AM   #230
CSG Mike
CSG Mike's Avatar
Psi will vary with conditions, but you'll see anywhere from 7-11 psi. 245whp is on CA 91 with an otherwise completely stock car with stock pulley.
There are no aftermarket pulleys or optional pulleys available for the JRSC at this time.
Old 08-30-2014, 02:43 PM   #231
Yui-Chan
Drives: Toyota
7-11psi is a huge variance (that's like double). I never had that much variance on my old turbo cars with climate condition changes or run time... unless a pipe, IC fitting or wastegate broke, came loose or leaked.
Is Drift Office also using the standard pulley?? I saw their dyno video and it says "10 psi pulley". Idk if that means the standard pulley it came with or they changed it (since they mentioned it in the title in bold, it sounded like they changed it).
As for 245Whp, especially considering thats on a complete stock car, carb tune, stock exh, this is quite impressive and is what I am after.
My goal is to have a "decent" powered sportscar. Meaning, not the same power to weight as a miata or civic si lol. I'm not looking for something super powerful like a muscle car or a magazine super build. I just want something that's actually decent and not pathetically slow and can actually have "sportscar" power compared to other current modern sportscar offerings (similar power as stock s2k, genesis, z, base mustang, and so on). And seeing how 245whp is pretty much what Caymans and 996 base models are putting down to the wheels, this makes a a modest 245whp more than sufficient in this little car.
From what I've seen: base Caymans put down 210-230whp, Cayman S and base 996s put down 240-260whp, and base 991s put down around 300whp. Making the 86 with a JRSC very similar to those in terms of power (and also 200-300lbs lighter).
Yes, I'm a little obsessed with those Porsches haha. I can't get one though. Too expensive, major parts and maintanence costs cost as much as a JRSC kit lol and too many common major engine problems.
The Following User Says Thank You to Yui-Chan For This Useful Post:
chaoskaze (08-30-2014)
Old 09-01-2014, 01:01 AM   #232
Yui-Chan
Drives: Toyota
Here's a question:
If using the CARB factory tune...and let's say you wanted to add a catback exh in the future, will this pose any problems with the EV and MAF readings to nessecitate and require getting a new tune? Also, will adding just a catback gain significant power improvement with the sc? If yes, how much? (Or are significant gains mostly from headers?)
I know and I've already read that removing any cats and using a catless header/fp, that you will need a retune and the CARB factory tune won't work...just wondering if it's the same thing when using just a catback exhaust (with stock catted header and stock fp).
Ty
Old 09-01-2014, 01:05 AM   #233
CSG Mike
CSG Mike's Avatar
Here's a question:
Ty
No, a catback will not affect the tune. No, a catback will not yield any power, no matter what people (or vendors and maufacturers) tell you, if you have the stock cars. The major restriction when you have the cats, is the cats themselves.
If you have construction reducing traffic to 2 lanes on a 6 lane highway, it will go the same speed as having construction reducing traffic to 2 lanes on a 8 lane highway.
Chad86 (01-01-2015), Yui-Chan (09-01-2014)
Old 09-01-2014, 01:33 AM   #234
Yui-Chan
Drives: Toyota
Cool. I like it quiet anyway. Though the thought of lighter weight was more of the reason I wanted one. But, I'll keep it stock.
Old 09-01-2014, 02:04 AM   #235
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If the frs feels slow, you're in the wrong gear.
Old 09-01-2014, 02:14 AM   #236
CSG Mike
CSG Mike's Avatar
I'm always in the wrong gear then....
Brinks (09-02-2014)
Old 09-01-2014, 03:00 AM   #237
Sellout
Mr. Cranky Pants
Sellout's Avatar
LOL. Sure, it couldn't possibly be that the car is actually just slow.
Damn near ANYTHING with a V6 is faster, but hey this car is plenty fast. You damn kids just don't know how good you have it...
Old 09-01-2014, 03:29 PM   #238
dolo
dolo's Avatar
Drives: '13 10 Series FRS
I just saw this.
I'm pretty curious as well, pm me when you get a chance.
-Evan
dolo is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Drift-Office : Jackson Racing Supercharger Installed! (Tune Tommorow!) Drift-Office Forced Induction 164 06-20-2014 12:43 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
