BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
08-21-2014, 09:23 AM | #15 |
As Alan said, make sure to warm up the engine first before redlining (about 10 minutes of easy driving). Otherwise, should be fine.
At the track, owners are at 4500-7400 rpm for 20-30 minutes at a time. No problems other than heat (oil temps), but that shouldn't be an issue on the street.
2022 BRZ Build 2013 FR-S Build |
08-21-2014, 01:45 PM | #16 |
Drives: 2015 Subaru CWP Series.Blue
Is there not a fuel cut off if you go above 7400 rpms? It's probably not good for the engine to do this very often, but it should at least save your engine
08-21-2014, 01:57 PM | #17 | |
Drives: '13 FRS - STX
Best case is it spins up a bit and nothing bad happens, worst case you get spun bearings, metals machining each other (galling) and bent valves. |
08-21-2014, 01:59 PM | #18 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
No problem as long as your water and oil temps are where they should be, otherwise keep it under 3000rpm IMO.
08-21-2014, 02:30 PM | #19 |
Drives: SWP BRZ
no. don't listen to others say it's fine. engine is not good if you always drive like that and it will likely blow and you need to pay for new engine.
yes. i am joking and you're fine. enjoy. lol |
08-21-2014, 02:51 PM | #20 |
Drives: 2013 raven frs
the only problem i can see is oil blow by. since it is a boxer engine and how the oil sits in it. ive seen people on the forum have breather tanks installed due to this issue.
08-21-2014, 04:10 PM | #21 |
Drive From Home
Drives: BRZ STI Performance
Run a very good engine oil (i.e. Eneos Sustina or TGMO), and change it often. This car has pretty usable torque for daily driving so I don't find myself above 4500rpm often, but at times like merging into traffic then I would take it all the way to redline if I want to.
Very hard to miss a shift with this car's shifter, I have the STI short shifter (-4mm / 10% shorter stroke) and it's even harder to miss a shift no matter the rpm range. If you don't exercise the engine throughout its entire rev range, once it ages the engine will have great difficulty revving into the high range readily (seen it happen to friends' CA Accord and Mk2 Jetta with this problem beyond 100,000km). Last edited by krayzie; 08-21-2014 at 04:23 PM. |
08-21-2014, 09:13 PM | #22 |
Drives: n/a
I've heard from some that driving this car daily due to the low torque/high reving is tiring. What are your guys thoughts?
08-21-2014, 09:27 PM | #23 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Funnest daily driver evar.... and plenty of torque at low rpms (2500-3000). And get one of these: Water temp to 191+F steady and oil temp at 190F+ and you are cleared for takeoff....I really need to get a oil pressure gauge though... Hey Toyota, instead of infotainment crap or that useless analog speedometer, why not put an oil pressure guage in these cars?!?!
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
The Following User Says Thank You to Vracer111 For This Useful Post: | DC2R (08-22-2014) |
08-22-2014, 12:51 AM | #24 |
Drives: 2015 Series.Blue
08-22-2014, 03:46 AM | #25 |
Drives: 4wd zooks
08-22-2014, 10:36 AM | #26 | |
My other car is a GTI, which has the opposite kind of torque curve. You get peak torque by 2000 RPM, and power falls off sharply above 5000 RPM. With an engine like that, there's no need to downshift really, just put your foot down. It's perfect when you want to be lazy and not worry about downshifting to pass, but (in my opinion), it's also not very fun. I prefer daily-driving the FR-S because it makes you work and stay involved. You can't just put your foot down to pass, you need to downshift 1-2 gears. To me, that extra level of involvement makes driving more interesting. Also love hearing my Perrin exhaust as I revmatch downshifts and progress through the tach. But everyone will have a different view. I also hang out on VW forums from time to time, and their chief complaint about cars like the FR-S and Civic SI is the lack of midrange torque and inability to pass without downshifting.
08-22-2014, 10:58 AM | #27 |
Drives: BRZ Pearl White
The only adverse thing that running high revs does is wear the engine a little faster because the pistons travel further and this is only true in the lower gears. If you drive in top gear of course the pistons travel the same distance regardless.
You cannot break this engine unless you downshift into the wrong gear at too high a road speed. The engine cannot overrev using the gas pedal. If you have an automatic you cannot select the wrong gear, yet another advantage of an automatic. In a manual car this engine is so rev happy it is actually easy to select second gear a bit too early on a downshift when you're enjoying the cornering on a bendy road, so be careful. There is no doubt that this engine will stay together well above its designed in rev limit. No engine manufacturer would build a street engine with no reserve of durability. These twins have a dual personality (har, har) in that you can drive around town comfortably and never exceed 5,000 rpm. The torque dip doesn't bother you and all is well. I routinely commute in fifth at 50 km/hr (30 mph) and the engine will pull smoothly cruising at 1,500 rpm so sixth can also be used around town. My usual upshift point around town is 4-4,500 rpm, just as the torque dip is ending. If you are driving hard then you should be above the torque dip almost all the time. There is no need to upshift until the red dot starts flashing which is equivalent to deciding to shift at around 7,000 rpm, which makes a good target rpm to commence your upshift, by the time you are in neutral during the shift the red dot will have flashed. Redline is around 7,400 and this engine is happy to pull to its redline all day every day. However, hitting the redline cuts the engine in and out to hold that maximum permitted rpm, so should be avoided for that reason. It doesn't hurt the engine to bounce the limiter but it really hurts your driving. The engine pulls strongly for such a tiny engine (boxers make useful torque) and you will never really get what you paid for under 5,000 rpm. |
The Following 2 Users Say Thank You to Ubersuber For This Useful Post: | Churnobyl (08-22-2014), illicitstylz (08-22-2014) |
08-22-2014, 06:33 PM | #28 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
License to Drive
classic
Similar Threads | ||||
MSSP PSI for daily driving? | jflogerzi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-17-2014 08:49 PM |
2.5L with lower revs/more torque, or 2.0L with higher revs? | Superhatch | Engine, Exhaust, Transmission | 124 | 08-28-2013 12:20 PM |
AT holding 2nd gear to high revs during a long left turn | EK_Golfer | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 03-01-2013 10:35 AM |
daily driving and heel-toe method | denverizzles | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 08-21-2012 03:51 PM |
AC cuts out at high revs. Cool feature? | Superhatch | BRZ First-Gen (2012+) -- General Topics | 9 | 06-28-2012 02:13 PM |
