Old 06-14-2014, 06:50 PM   #1
jflogerzi
jflogerzi's Avatar
MSSP PSI for daily driving?
Anyone running these tires, what are you using? Also can anyone point me to a decent small portable (for use at the track and home) battery powered air compressor to add air into tires?
Old 06-14-2014, 07:00 PM   #2
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
everytime i buy a new set of tires my tire guy always tell me to pump it according to the PSI on your door sticker, then keep an eye out on the tire thread wear after 1000km/miles, if too much of inner tire is worn then that means too much air, if too much edges worn then not enough air.
chenshuo is offline   Reply With Quote
Old 06-14-2014, 07:38 PM   #3
wparsons
wparsons's Avatar
Slight correction, if the center is wearing more there's too much air. The inner edge wearing is from camber. If both outer edges are wearing more than the center then there's too little air.
flickr
Old 06-14-2014, 08:29 PM   #4
14BRZ
14BRZ's Avatar
Drives: 2014 BRZ, 08 CBR600RR
Draw a line across your tires with chalk and move the car back and forth a few times. This determines your contact patch. Add/remove air if needed
14BRZ is offline   Reply With Quote
Old 06-16-2014, 03:59 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would stick with the OEM tire pressures. I would get a cigarette lighter adapter compressor with the longest cable you can find. I keep a cheap Slime one from Walmart in my truck.
Old 06-16-2014, 04:07 PM   #6
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
start with whats on the door... drive it... add two pounds... drive it... see if its better or worse... if worse... drop back to stock... drive it... drop 2 lbs... see how that does... i'm at 40 all around on stock tires right now...
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 06-17-2014, 12:12 AM   #7
Pete156
I like to eat!
I run 38psi F&R on all my PSSs. Wear appears symmetrical with both sets (225s and 255s) on the 86. Keeping them there!
Pete156 is offline   Reply With Quote
Old 06-17-2014, 01:14 PM   #8
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I keep mine around 36psi and am almost to the wear bars but there is no more than 1/32 difference anywhere. I'm just about to hit 30k on these, so I'm pretty happy with how they wear. Rotations done around 8-10k miles in between.
This is also lowered on RCE Yellows with camber bolts in front for just about -1 degree.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 06-17-2014, 02:22 PM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Lots of high PSI for the MPGs in this thread.
Old 06-17-2014, 08:49 PM   #10
jflogerzi
jflogerzi's Avatar
Thanks for the reply guys. Gonna do some experiments.
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Invidia N1 Catback for daily driving? Unidentified Engine, Exhaust, Transmission 44 02-28-2018 09:18 PM
Aftermarket Wheels for Daily Driving BG.Ghost8 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-20-2014 01:33 PM
Rocket Bunny for daily driving? tha7osavage Cosmetic Modification (Interior/Exterior/Lighting) 44 06-11-2013 02:22 PM
daily driving and heel-toe method denverizzles Scion FR-S / Toyota 86 GT86 General Forum 13 08-21-2012 03:51 PM
Comfort and daily driving - Should I go with a sports coupe? Undecided Off-Topic Lounge [WARNING: NO POLITICS] 22 03-01-2012 02:17 AM
