| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2014 Grey BRZ Limited
Effects of driving at high revs daily
I got a brz recently up from a honda fit.
I'm not too disappointed with the acceleration like most, however now that im out of break-in i find it hard not to go above 4k rpm. Around 4.5k the car really picks up. My question is how much damage am I doing bringing it up to 6-6.5 to shift frequently? Its hard to keep the revs low with 151 lb/torque. |
Your wallet will be lighter and your smile will be wider.
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
As far as I know the car was designed to be used in its entire rev range. Unless you're constantly bouncing off the rev limiter, you should be okay.
Keep your oil changed at regular intervals and you should be fine. |
#4 | |
Drives: Subaru BRZ Limited
Thanks for the feedback. I think i'll take your advice. Should have stayed with the fit if i'm going to be boring
Noob
Drives: FR-S Mammogram
No problem with that, so long as you aren't redlining all the time. Some will argue it is even better longevity-wise, as it exercises the full RPM range. Many cars that were "grandma'd" seem to have issues much later on in life (>100k miles) if they were never used in the higher revs.
Drives: 2014 Pearl White BRZ
Crikey - let her rip mate.
Done
Drives: WRB BRZ
rev it up till the vtec kicks in, somewhere around 8.5k.
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I shift around 4-5k rpm normally, but when I'm actively accelerating I'll take her up past 6k. Just too much fun not to! But if you're not accelerating with urgency, no need to shift late and cruise at high rpms.
Only issue I could see is a mis-shift. If you're up at 6500 rpm and shift to the next gear up but hit the gear below instead by mistake, you're going to redline the engine and possibly cause damage. Not sure when this would happen though. You're not exactly going to get it close to first gear from second at those speeds, third to fourth is a no-miss, and 4th gear at 6500 rpm probably won't happen often. |
#10 |
Drives: Subaru BRZ (6027xx) Premium Manual
Ain't nothing wrong with a little grinding once in a while.
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
#11 |
Drives: 2014 BRZ
6K? You haven't even hit the torque peak. Wind it to redline as often as you like. No harm.
#12 |
#13 |
Drives: 2014 WRB Bravo Romeo Zulu
It's weird, I've been testing my mileage (km's) per tank and I see little to no difference with driving conservatively vs high revving. So I just choose the latter because this car is way more fun.
#14 |
Drives: 4wd zooks
The FA20 is designed to rev , but no engine survives high revving during warm up.
Just warm it up first and try not to lose the license to drive! |
| MSSP PSI for daily driving? | jflogerzi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-17-2014 08:49 PM |
| 2.5L with lower revs/more torque, or 2.0L with higher revs? | Superhatch | Engine, Exhaust, Transmission | 124 | 08-28-2013 12:20 PM |
| AT holding 2nd gear to high revs during a long left turn | EK_Golfer | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 03-01-2013 10:35 AM |
| daily driving and heel-toe method | denverizzles | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 08-21-2012 03:51 PM |
| AC cuts out at high revs. Cool feature? | Superhatch | BRZ First-Gen (2012+) — General Topics | 9 | 06-28-2012 02:13 PM |
