Old 08-16-2014, 04:06 PM   #15
GA_Dave
Drives: 2014 Dark Gray Metallic BRZ Limited
In these engines it is not so easy to just remove the spark plugs to blow out the water.
You have to lift the engine to pull the plugs.
It would be easier to pull the DI injectors than the plugs.
Either way, I'm sure they guy's at Rev Works have what they need to fix it and rebuild the motor
GA_Dave is offline   Reply With Quote
Old 08-16-2014, 04:52 PM   #16
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I sucked water when I had my Integra GS-R with an AEM CAI. Once my motor cut off I almost cried. Someone helped me push it off the road and I then had it towed home. The next day I removed the spark plugs and cranked out all the water then let it air out for a few hours. Put new spark plugs in and it fired up without any issue. Fortunately my motor was only idling when it took in water so I didn't bend/snap a rod. It ran strong and was stolen a year or two later.
At what RPM were you at when you sucked water? Did you see any oil or coolant leaking out? Or a hole in your block?
B-R-Z is offline   Reply With Quote
Old 08-16-2014, 11:45 PM   #17
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
LS2 will fix that
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 08-16-2014, 11:54 PM   #18
Fastbrew
Drives: 2014 Pearl White BRZ
One time in CO I drove my jeep across a river. I wandered slightly off the "path" and ended up in a hole. The water was flowing through the drivers door and out the passengers door. My German Shepherd was in the back seat looking at me like "WTF?".
So, some friendly folks towed me out and the thing was hosed. We hung out for a little bit and then I had them tow me back through the river. Once on the road - I had them keep towing me while I was in 1st gear for about 3 miles. Then, the engine turned over and off I went. I never had it looked at our anything. It ran until I traded it in at a dealer 3 years later. That's why my other vehicle is a Wrangler
Fastbrew is offline   Reply With Quote
Old 08-17-2014, 06:42 AM   #19
steve99
Drives: FT86
As others have said a new engine installed and guaranteed by subaru for $500 is a no brainer, if you can score the old engine even better but if its been genuinly hydrolocked it may have done a lot of subtle damage and stressed components even the block, not sure i would want to rebuild it for boost.
Guys seem to be running more than 6 pounds boost on stock motors sucessfully seem to be able to run 10-12 fairly reliably, if you run more than that your going to need more than motor upgrade. to handle the power reliably.
Old 08-17-2014, 02:14 PM   #20
GA_Dave
I have no idea what RPM I was at. I parked the car after driving through a rainstorm, then it wouldn't start the next day. So if it really is hydrolocked, it happened while the starting motor was turning it over. There was no oil or coolant leaks, and certainly no hole in the block
Old 08-17-2014, 03:04 PM   #21
Luis_GT
You told the dealership you thought you hydrolocked the engine??
Old 08-17-2014, 04:05 PM   #22
DJCarbine
Thupercharged
DJCarbine's Avatar
So wait, did the engine die during the rainstorm, or did you park the car with a running engine and shut it down then it wouldn't start later...
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 08-17-2014, 04:31 PM   #23
B-R-Z
B-R-Z's Avatar
If it were me, I'd take the car home and do what I did to mine. Chances are you only fouled the spark plugs and have water in your cylinders. I think people that destroy their motors with a hydrolock are not idling and are up to 2000+ in RPMs. You were only cranking to start your car so there was not any power at the crank to really destroy anything.
Old 08-24-2014, 02:02 AM   #24
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Pat.Thornton View Post
Sounds like it's time for a 2jz swap
Rain + FA20 = hydrolock
Old 08-24-2014, 02:37 AM   #25
Nissota
Nissota's Avatar
Drives: Subaru BRZ, Nissan 240sx
Which CAI did you have on?
Nissota
2013 Subaru BRZ DD
1997 Toyota Supra MKIV
1990 Nissan 240sx
www.revvolution.com
Nissota is offline   Reply With Quote
Old 08-24-2014, 12:08 PM   #26
RFB
RFB's Avatar
Drives: FRS
As a member of a crazy 4x4 club,with scuba divers as members we had a lot of drowned motors as a result of deep water crossings.
We always stopped and let the engines cool before crossing lakes and rivers and kept revs low to avoid cracking a head if the motor sucked water.
In all cases of water intake into a cold low reving motor no permanent damage was done (we acted immediately).
After pulling the oil drain plug, allowing the pure water to drain, then letting a bit of the malted milkshake to drain, add some fresh oil, pull the plugs (or injectors for the diesels) crank, (avoid the bullet like jets of water from the plug holes), wire dryer and quick start (ether), then watch the steam from your exhaust until full oil change.
Did that with 2 of my own off road trucks, and helped many others do the same.
We had hose snorkels on our diffs, trannies, and transfer cases so all oils in the car should be changed as those areas could have sucked water past pinion seals etc. if the car was hot.
CERBERUS
RFB is offline   Reply With Quote
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 02:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 08:12 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
