Old 08-13-2014, 03:16 PM   #15
goshem
goshem's Avatar
Drives: 16' WRX
Is the tightening nut the top bolt or the bottom bolt? I only managed to tighten the bottom one because the top one has a weird bolt pattern
goshem is offline   Reply With Quote
Old 08-13-2014, 05:09 PM   #16
wbradley
Sarcastic SOB
wbradley's Avatar
bottom, where the air is probably leaking. Spray soapy water on it while the engine runs to see where air is leaking.
Old 08-13-2014, 09:33 PM   #17
Turdinator
Señor Member
Turdinator's Avatar
alright, so I tightened all the hose clamps up and I found the culprit.
anyone know how to fix this? I'm pretty sure it's between the bolts that's leaking, I hear a whizzing sound there and when I close it with my fingers it goes away.
Any chance of a better photo of the fitting?
It is leaking vacuum so this may not work.
1974 TA22 Celica
2013 86 GT
Old 08-19-2014, 03:06 PM   #18
goshem
goshem's Avatar
Drives: 16' WRX
Hmm actually I figured it out! I just had to tighten that blue bolt and it stopped leaking! Thanks a bunch!
The Following User Says Thank You to goshem For This Useful Post:
Turdinator (08-19-2014)
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 07:17 AM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 12:53 PM
Slip+CEL = Bank1 running lean? Trashed675 Issues | Warranty | Recalls / TSB 11 03-28-2013 10:53 PM
Dealership Installed Wrong Spoiler Snowblind Scion FR-S / Toyota 86 GT86 General Forum 57 02-15-2013 05:57 PM
