Old 08-12-2014, 10:15 PM   #463
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by clintavo View Post
Has anyone else noticed hesitation/ bogging at 1500 rpm when floored?
I realize this is a somewhat rare scenario, but I have run into it twice:
Loafing around a parking lot in 2nd gear, suddenly to get out of someone's way.
Starting from a stop uphill.
It is repeatable; floor it at 1500 rpm and it completely bogs. It never happened with 1.3 or 1.6
BTW the throttle calibration seems much smoother in this tune : )
Thanks Shiv!
I am assuming you must have an auto. I read somewhere that modifying the snorkel can lose power below 2000rpm. Take a log of the car doing it and check what has changed on 2.0 from the earlier tunes in that RPM and load range. Then you can change those areas back to the old values and see if it improves.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
clintavo (08-13-2014)
Old 08-12-2014, 10:31 PM   #464
OCIASTI
NA
OCIASTI's Avatar
Drives: 04 STI, 14 BRZ
Hi guys, and girls. I have 92 octane with e10(10% ethanol). What is that equivalent to? What map should I run, 91 or 93?
OCIASTI is offline   Reply With Quote
Old 08-12-2014, 10:41 PM   #465
s2d4
s2d4's Avatar
91
The Following User Says Thank You to s2d4 For This Useful Post:
OCIASTI (08-12-2014)
Old 08-12-2014, 10:58 PM   #466
OCIASTI
NA
OCIASTI's Avatar
Originally Posted by s2d4 View Post
91
Does everyone agree? Should I save some dollars on 91 octane and go with 91 map, or should I go with 92 octane with 91 map.
Old 08-12-2014, 10:59 PM   #467
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
map > octane = no ok
map < octane = ok
Sent from my SM-N900P
CamryDS is offline   Reply With Quote
The Following User Says Thank You to CamryDS For This Useful Post:
Old 08-12-2014, 11:18 PM   #468
mightyt73
Drives: 2013 Subaru BRZ, 2007 V6 Mustang
I was getting some knock on the 93 map with 93 octane. I would say go with the 91 map, I'm using it now and it's fine.
mightyt73 is offline   Reply With Quote
The Following User Says Thank You to mightyt73 For This Useful Post:
Old 08-13-2014, 12:32 AM   #469
Fleischwagen
Drives: 2013 BRZ, 1979 Scirocco 16v
Hey guys, running 1.10 of the manager, attempting to upload the 2.03 beta files to my tablet but it keeps displaying a 0x68 error. I've tried uploading 1 at time, no dice. The manager reads my tablet fine, just won't upload any new files to the unit (I have 2 on there, not including the stock file currently)
Fleischwagen is offline   Reply With Quote
Old 08-13-2014, 01:10 AM   #470
steve99
Drives: FT86
have a read of the OFT TIPS link below
If your on windows 8 make sure you have installed win 8 patch from openflash site
Try deleting all the old tunes, then load up the new ones, no need to delete your original stock ROM though .
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Fleischwagen (08-13-2014), lucid215 (08-13-2014)
Old 08-13-2014, 01:46 AM   #471
fuse614
fuse614's Avatar
Drives: 2014 FRS Whiteout
Anyone know if im running too lean? I just did a short 10 minute drive on side streets.. http://www.datazap.me/u/fuse614/shor...log=0&data=1-9
2014 Whiteout FRS Snowflake - Mods: Borla UEL, OFT, Nameless Axleback
fuse614 is offline   Reply With Quote
Old 08-13-2014, 02:17 AM   #472
steve99
Drives: FT86
hard to tell from that log you need to do a full throttle run 3rd gear 2000 rpm to redline.
Have a read of the links below on logging
Old 08-13-2014, 03:45 AM   #473
clintavo
Manual.
It is more than just a loss of power. I can hold it floored for a couple seconds (as long as I dare) with zero acceleration.
I am still figuring out how to upload a log into datazap, but for now does this LTFT ect look abnormal?
Thanks!
clintavo is offline   Reply With Quote
The Following User Says Thank You to clintavo For This Useful Post:
Lytheum (08-13-2014)
Old 08-13-2014, 04:08 AM   #474
steve99
Drives: FT86
Manual.
Thanks!
Watch the throttle position when you depress throttle should follow your movements closely and quickly. Its possible you have fault with car. You can see it even with engine off as long as ignition on.
Old 08-13-2014, 04:39 AM   #475
clintavo
I just tried it out, and it performed as it should. It was worth a shot, thanks.
Old 08-13-2014, 05:09 AM   #476
troek
troek's Avatar
Drives: 2012 Toyota 86
-10 ignition advance seems a little strange
troek is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
