Old 08-08-2014, 03:16 PM   #15
vgi
Drives: frs
Originally Posted by Freeman View Post
I'll be upgrading to a C38 at some point in the future. I'm not able to figure this out myself at the moment, but roughly what PSI would I see if I had the C38 blower set up to max out at 7,400 rpms? I know that's a horrible way to look at it. I should be more concerned with CFM, but I'm just curious.
13 and change
vgi is offline   Reply With Quote
Old 08-08-2014, 03:30 PM   #16
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by vgi View Post
13 and change
You're probably correct. I'll have to dust off the old text books and grab the compressor map tonight.
Freeman is offline   Reply With Quote
Old 08-08-2014, 03:49 PM   #17
vgi
Drives: frs
probably. if i remember correctly and my conversion from MAP is right
Old 08-08-2014, 04:27 PM   #18
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Id love to see a 3rd party dyno sheet with 315 on 91 oct
Old 08-08-2014, 05:12 PM   #19
vgi
Drives: frs
i'd love to see a log for that tune to check how much it's knocking
Old 08-08-2014, 08:24 PM   #20
Jcl
Drives: 2014 BRZ
Can I run the 2.5bar map sensor you provided with the 70mm pulley?
Jcl is offline   Reply With Quote
Old 08-11-2014, 10:02 PM   #21
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by Jaden View Post
I notice that you are running the same boost levels for 91 and E85 so is the difference in output due to timing settings? i.e. you're using more advanced timing for the E85 on those tunes?
Jaden
That is correct. On top of already adding 25%+ across the table for fuel when switching to E85, you're able to add quite a bit of timing which allows for the increase in power without having to worry about knock.
Around the 13psi figure. The figures within the graph are taken to nearly the same redline as the initial, base kit.
The testing on our dyno was not knocking although we're not able to have nearly as much timing added with the 91 as you obviously know.
Yes, You will need to have a complete tune performed as the pulley will change the powerband overall and you'll need to have the parameters set to recognize the 2.5bar as opposed to factory or the OE Denso we include in the base kit.
KraftWerks is offline   Reply With Quote
Old 09-23-2014, 06:53 PM   #22
KraftWerks
KraftWerks's Avatar
Originally Posted by sw20kosh View Post
LOL @CSG Mike 315 whp on 91 pump gas.
Originally Posted by SmsAlSuwaidi View Post
Lol 315whp on 91 ?
Customer's kit at Church Automotive with both a 91 and E85 Graph.
That 315 on Pump Gas is entirely possible. =D
DPS Kraftwerks Scion FRS - KW / Invidia / Kraftwerks / Enkei rickspecd Member's Car Journals 40 06-26-2014 12:42 PM
I need help choosing rims... barabia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 03-03-2014 10:42 AM
Need help choosing kit DannyFRS Forced Induction 16 11-15-2013 02:49 PM
Choosing the Right Color gonzalj1 BRZ First-Gen (2012+) — General Topics 58 11-06-2013 11:46 AM
Need help choosing... ap5512 Other Vehicles & General Automotive Discussions 23 09-18-2012 06:24 PM
