Old 11-14-2013, 05:48 PM   #1
DannyFRS
Drives: White out FRS
Need help choosing kit
I'm finally ready to purchase my FI kit. Narrowed it down to two kits the vortech supercharger and the avo turbo kit. Don't really have a preference for ether turbo or supercharger my only goal is to get as close to 300- 350whp as possible with 91 pump gas. I know I can't get that with the kits on there own I know I'll have to get other bolt ons. I just need help with what kit can get me the closest to my goal. Not interested in other kits. OEM look is a must for me. Idk why just really like the clean OEM look. Thanks in advance.
DannyFRS is offline   Reply With Quote
Old 11-14-2013, 05:51 PM   #2
Noob4Life
86 Noob
Drives: Firestorm FR-S
The avo kit should get you there with some custom tuning and fuel mods. Plus it looks very oem. Don't think the vortec will get you there on 91.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Noob4Life is offline   Reply With Quote
Old 11-15-2013, 02:03 AM   #3
pmccut
Drives: Blue Subarus
I don't think it's realistic to hit 300whp on the AVO kit with 91. That's hard to hit on the larger turbo kits with 93 or E85. Look through the FI dyno thread / AVO owners thread to get a better idea.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 11-15-2013, 02:08 AM   #4
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
I haven't had the avo kit very long but the power is good. It boost quick and makes a day and night difference.
Just read through the thread and pick up some install notes from there if you're doing the install yourself.
h4nh is offline   Reply With Quote
Old 11-15-2013, 02:32 AM   #5
DAMotorsports
Drives: 2013 Scion FRS "Raven"
The AVO kit can make 300 on 91. You will need a few supporting mods but nothing major. The base kit with no mods will make 240 all Day long at 5psi.
DAMotorsports is offline   Reply With Quote
Old 11-15-2013, 02:40 AM   #6
DannyFRS
I've looked into the current avo threads and they seam to get pretty close I know I'll need full exhaust. Forgot to mention looking at a 2.5 inch rather then a 3" exhaust do to noise don't want it to be extremely loud. Will injectors and fuel pump help with whp at these levels or is it more of a safety thing to make sure the stock ones aren't maxed out?
And what about the vortech? Would it be that hard with some good headers all other bolt ons?
Old 11-15-2013, 03:19 AM   #7
Indestruct
Drives: 2013 SWP Limited BRZ, MT
Since you're in California Vortech is C.A.R.B legal...
Indestruct is offline   Reply With Quote
Old 11-15-2013, 03:32 AM   #8
husker741
Does peak whp really mean that much to you? Just because it can hit a certain number doesn't mean it'll be the power delivery you are looking for. There's a difference between the type of power you will see from the turbo or SC.
husker741 is offline   Reply With Quote
Old 11-15-2013, 10:27 AM   #9
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Your exhaust size has very little to do with how loud it will be. The turbo acts as a muffler so a turbo setup will be quiter when compared to a supercharger with the same exhaust.
Old 11-15-2013, 10:42 AM   #10
jamesm
neither of those kits will make 300-350whp easily and reliably on pump gas. if you're on cali gas, you'd probably want to go with the ptuning kit with it's larger turbo (gt30). other kits offer turbo upgrades, but i'd stay away from the oil-cooled journal bearing turbos (50-trim, 60-trim, etc.) and by the time you add a gt30 to any of the other kits it pushes the price up to near that of the ptuning kit, which appears to be of far higher quality than others currently available in that sort of configuration.
and king tut is correct, a turbo is the best muffler you'll ever find.
Old 11-15-2013, 11:02 AM   #11
nonicname returns
Drives: 4 wheels
Just move to a normal state
nonicname returns is offline   Reply With Quote
Old 11-15-2013, 11:23 AM   #12
DannyFRS
Peak power isn't the most important thing to me but it does matter this will be more of a street car then track and from my experience on the street your more ok the higher end of the revs. Yea I understand the power deliver is different but like I stated I don't have a preference on turbo or supercharger as long as I get to my goal. So if I can't get to 300whp on these kits then how close can I get I mean I wouldn't be happy with any less but I'd be content with like 285whp and up.
And thanx again for the help.
Old 11-15-2013, 12:33 PM   #13
jamesm
the hp numbers should be the least of your concern, really. as long as the kit has a compressor that can meet your needs, that's really all that's guaranteed. it's not like you buy a kit and bolt it on and suddenly have 300whp exactly all the time. it's a fluid thing, and has more to do with the tune than which kit you bought (compressor capabilities being equal).
for instance, my 'pro tune' had me knocking my way to 260whp on a mustang. my new tune is at least 20-30whp up on that with no serious knock in sight at the same boost level. nothing else on the car has changed. my car probably picked up another 10-20whp (and 1.5psi of boost) just from the temperature dropping here recently. so just because your car makes 285whp one day on one dyno doesn't really mean anything.
i guess the point of my rant here is that you don't buy a kit for the purpose of reaching some particular number, because anyone can make a number on a dyno, that's the easy part. the hard part is making it drive like a stock car the other 99% of the time, not fall apart, etc. the important things are consistency, drivability, ease of ownership, component quality, and price.
buy the kit that fits your needs in those areas. i can make a dyno show you whatever number you want .
Old 11-15-2013, 12:40 PM   #14
SnapOv3st3r
Drives: 400whp Scion tC
PTuning is hitting those numbers with every kit they have sold thus far. On a Dyno Dynamics nonetheless.
SnapOv3st3r is offline   Reply With Quote
Choosing the Right Color gonzalj1 BRZ First-Gen (2012+) — General Topics 58 11-06-2013 11:46 AM
If you could get your BRZ in any color of your choosing...which would it be? gt8613 BRZ First-Gen (2012+) — General Topics 41 08-21-2013 05:17 AM
Need help choosing a steering wheel Jhon19lopez Cosmetic Modification (Interior/Exterior/Lighting) 0 06-29-2013 10:23 PM
Need help choosing... ap5512 Other Vehicles & General Automotive Discussions 23 09-18-2012 06:24 PM
Need some help choosing an exhaust Apollo_1092 Engine, Exhaust, Transmission 9 08-24-2012 05:28 PM
