Old 07-29-2014, 10:08 AM   #225
CaptainSlow
CaptainSlow's Avatar
Originally Posted by Venator View Post
What tune are you on now?
2.01
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 07-29-2014, 10:13 AM   #226
lucid215
Originally Posted by driftu View Post
Bought my OFT a few weeks ago. Came with A01C files installed. Yet OFM indicates CAL ZA1JA00C. The v2.01 Beta only accepts A00C files to the tablet. A01C and all others are not compatible. This is all new for me so forgive my ignorance. Any insight would be much appreciated. Thanks
the A01C are default roms installed in the OFT. your ecu is a A00C and the OFT will only let you upload those roms into the OFT. I noticed the same thing when i first got mine and asked the same thing. The OFT wont let you upload the wrong rom
lucid215 is offline   Reply With Quote
The Following User Says Thank You to lucid215 For This Useful Post:
driftu (07-29-2014)
Old 07-29-2014, 10:15 AM   #227
SilverFoxBRZ
BRZ Jockey
Drives: 2013 BRZ LTD 6MT Sterling Silver
that code is for faulty fuel level sensor for fuel tank gauge. Does not appear to be related to tune.
Is you fuel gauge reading correctly ?
Seems to be reading accurately. Might be an odd coincidence that this tank of E85 coupled with the new map is when it chose to show up. I need to burn through this tank and go back to 93 and see if it persists. If this is recurring with E85, no more corn juice for me until I get some hard data as to whether or not this is a nuisance code or a real problem.
SilverFoxBRZ is offline   Reply With Quote
Old 07-29-2014, 10:20 AM   #228
bfrank1972
Drives: 2013 FR-S Argento
Just to add to the list of reviews, I upgraded to 2.01 from uhh I think 1.3x, can't remember but it's been a while. I gave it a couple days to settle in, quite a noticable difference. It's really hard to say if it's actually faster or not (butt dyno while fun is horribly inaccurate), but a really significant improvement in refinement.
- It seems like the torque dip, while improved in the older tune I had, is even better now. It seems to be much flatter until about 4K where it picks up in a smooth surge.
- Induction noise during the torque dip is much less - I got used to the noise but now that it is gone I'm happier.
-Idle is smoother.
-Just running through the gears sounds and feels smoother.
No logs yet, but watched real time display and IAM is flat at 1 (I'm running the 93 tune on 93).
Great OTS tune Shiv, to anyone who hasn't done this yet, do it. Car is even more fun to drive now.
Old 07-29-2014, 10:31 AM   #229
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Originally Posted by Shiv@Openflash View Post
Instead of making releasing another 132 maps for BPB use, I'm post a thread this week on how to convert any map into a BPB version of that map. Long story short, it just involves making some changes to a couple ignition timing related maps. Very simple and anyone can do it through ROM Raider. It's just gotten to the point were we have so many maps for so many different set-ups that doubling the amount of maps isn't quite prudent (for my sanity!)
Cheers,
shiv
Going on a 400 mile road trip on Thursday, I'd love to use it to road test the new update! Pleaseeeeeeeeee @Shiv@Openflash show me the way!
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 07-29-2014, 11:49 AM   #230
wparsons
wparsons's Avatar
If you see CAL of A00C in the OFM, that's because that's the appropriate CAL ID for your car/ECU. Regardless of what the tune is based off, you have to choose the matching CAL ID for your car/ECU.
Mine is 700C, but I'm running the newest tune which is based on B01C.
flickr
Old 07-29-2014, 11:50 AM   #231
driftu
driftu's Avatar
Drives: 13 FR-S: Raven
Thank you
Thanks for the info. The OFT really is idiot proof. Well, maybe not always in my case :/ Looking forward to flashing the updated EL E85 map today
driftu is offline   Reply With Quote
The Following User Says Thank You to driftu For This Useful Post:
lucid215 (07-30-2014)
Old 07-29-2014, 11:54 AM   #232
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
Not sure if it's just me or what, but after updating to the newer version my car seems slower and I am making less hp by about 10 I was sitting around 190 and now I'm not even making 180 to the wheels and I have a full exhaust and intake just so y'all know
Scavanger is offline   Reply With Quote
Old 07-29-2014, 11:59 AM   #233
Silver Ignition
APEXHNTR
How is this being measured?
#1867 of 2500
The Following User Says Thank You to Silver Ignition For This Useful Post:
CaptainSlow (07-29-2014)
Old 07-29-2014, 12:04 PM   #234
Scavanger
Scavanger's Avatar
Dynojet dyno
Old 07-29-2014, 12:06 PM   #235
wparsons
wparsons's Avatar
Similar weather conditions? Same gas? Same dyno?
Any logs to see what the AFR's, knock, etc were on both pulls?
What MAP in both cases? (ie 1.59 stage 2 UEL)
flickr
Old 07-29-2014, 12:16 PM   #236
Scavanger
Scavanger's Avatar
I went from v1.59 el stage 2 tune to v2.0 el stage 2 tune and no I haven't done logs but same dyno same temps same time of day same humidity and all, with the new update low end I was running rich and top end I was running lean, always use the same gas from the same station and I run 93
Old 07-29-2014, 12:58 PM   #237
R2
Originally Posted by SilverFoxBRZ View Post
OK, Stg 2 EL E85 A01C flashed, some noticeable improvements and refinements buuuut...now I am getting a P0463 CEL. Reset it and it just comes back. Did not happen with previous tanks of E85 and OFT OTS tunes. Shiv? Anyone? Buehler?
About four weeks ago I saw this exact code pop up. Interestingly, it happened immediately after plugging in the OFT for some logging. I cleared the code and have never seen it again.
R2 is offline   Reply With Quote
The Following User Says Thank You to R2 For This Useful Post:
SilverFoxBRZ (07-29-2014)
Old 07-29-2014, 01:27 PM   #238
CaptainSlow
Dynojet dyno
I'd also imagine that you need to give the tune a bit of time to settle in...similar to the throttle position, I'm sure things run a little on the safe side before it relearns everything. How many miles did you put on before testing on the dyno? Also, did you just look at peak power or power under the curve?
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
