Old 07-28-2014, 05:58 PM   #197
CaptainSlow
CaptainSlow's Avatar
Originally Posted by Readytoxplod View Post
downloaded 93oct A00c from beta 2.01, and launch control is active, how to I activate flat-foot shift? I tried it (shifting while on the accelerator without lifting fore shift) and it just revved to the limiter. How do I activate it?
You have to reset the value to what you want...I think by default the FFS set point is right at the rev limiter (delta=0). In RomRaider open that value and reset it for about 600 or so...remember that it is a delta value, meaning the actual set point will be the rev limit (7600) minus your delta value. So, an input of delta=600 will give you a FFS set point of 7000 rpm
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following User Says Thank You to CaptainSlow For This Useful Post:
Readytoxplod (07-28-2014)
Old 07-28-2014, 05:59 PM   #198
Venator
Venator's Avatar
Drives: Asphalt FR-S
@Shiv@Openflash I have flashed the 1.5x tune stage one on my FRS, and especially in 3rd gear, when I hit ~4k RPM there is a loud noise almost like a vibration somewhere but I see nothing that is vibrating. Please help! I am flashing it back to stock until I hear from you. Definitely a bad sound...
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 07-28-2014, 06:15 PM   #199
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Any chance you're hearing the VVT kicking in?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 07-28-2014, 06:17 PM   #200
Venator
Venator's Avatar
That was my thought too but it was loud!
Old 07-28-2014, 06:24 PM   #201
Venator
Venator's Avatar
I had a 2001 Celica GTS and its VVT-Li was loud but this was much louder almost sounded like a knock. The sound would go away after ~4.5k so it wasn't loud for long, but it scared me. lol
Old 07-28-2014, 06:25 PM   #202
CaptainSlow
Yeah it was loud on that tune...much quieter now
Old 07-28-2014, 06:28 PM   #203
Venator
Venator's Avatar
What tune are you on now?
Old 07-28-2014, 06:28 PM   #204
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
+1
I don't typically use FFS myself. But when I do, I set the value to 1000rpm. This means that whenever the clutch is pressed the fuel is cut until revs fall below 7600 (rev limit) - 1000 or 6600rpm. This means that you need to shift well above 6600rpm for this to work properly. Which make sense since you are looking for max acceleration when using FFS. So shift around 7500rpm and you will be happy with the result.
If you set the FFS RPM value to big, it may start to interfere with normal driving because all it takes is a little pressure on the clutch to enable the switch.
Cheers
shiv
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Old 07-28-2014, 06:31 PM   #205
wparsons
wparsons's Avatar
That's intake resonance, and has been discussed at great length in other threads. It's not damaging anything, and is fine.
flickr
Old 07-28-2014, 06:39 PM   #206
Venator
Venator's Avatar
Oh! ok is it specific to this tune or just an all around thing? Will switching to the beta tune fix it? Also I am on the stock air box. If you know off the top of your head what thread would be awesome to check I would appreciate it!!
Old 07-28-2014, 07:14 PM   #207
Venator
Venator's Avatar
This seems common if you have the sound tube, but I don't. Any other thoughts?
Old 07-28-2014, 08:07 PM   #208
wparsons
wparsons's Avatar
It took me two seconds to find it by searching this section for intake noise...
http://www.ft86club.com/forums/showt...t=intake+noise
There's nothing to fix, so the beta tune won't "fix" anything. The noise is just resonance in the intake tract, and isn't anything bad. The stock tune makes the same noise, just not as pronounced.
flickr
Venator (07-28-2014)
Old 07-28-2014, 08:52 PM   #209
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I wish there was a way to compare the older roms to the new one with different .xml in romraider. I've spent many many hours tweaking some of the tables with the old xml. Wish I could just copy and paste in the new v2.01b.
Old 07-28-2014, 09:21 PM   #210
MstrSHAKE
MstrSHAKE's Avatar
Drives: 2014 SWP BRZ
So far so good. I hate the dead pedal feel for a while.
MstrSHAKE is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
