Old 07-22-2014, 11:20 PM   #43
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Originally Posted by Cliu91 View Post
How is it not an issue? Just because it is a sound it isn't considered an issue?
Then why do some cars have it, and some cars don't? Just because it doesn't have a performance, or actual impact on the car, it can affect the driver's experience - which is a fundamental component of the 86. I consider it an issue as do many others.
They're called manufacturing tolerances. Every part has a range of dimensions. The ranges may be thousandths of an inch but sometimes that makes all the difference. When you're dealing with fuel at hundreds to thousands of PSI it can make a huge difference. That's why some have them and some don't, but they can all still meet specifications. I deal with this same type of stuff literally every day I'm at work. It can be very frustrating but machining and manufacturing are inherently imperfect because the tools that are used to do them and the people who operate them and the world they're operated in are all inherently imperfect.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
Sportsguy83 (07-23-2014)
Old 07-23-2014, 02:28 PM   #44
Toca
Drives: 2015 Series.Blue BRZ
Originally Posted by N1rve View Post
There is currently no fix for this. Other people tried the ashless whatever and Upper Cylinder lube. Some state it worked for them, some state it didn't.
I have my original fuel pump in my 2013 FRS. I occasionally get chirps but they never last. I live in California, so I get the same fuel as you do. What I've concluded from my own observation is that Ethanol doesn't cause it, or else people with E85 would be chirping all day everyday.
For my car, when I get lower than half tank, the chirps come. However, I fill up at Costco and never at other gas stations.
No failures.
I'm just starting to notice some chirping at idle on mine and it's only around ~500 miles. The gas tank is full too...so I'm not experiencing your issue with lower than half a tank of gas. Although sometimes when I drive it around a bit and stop, it wouldn't make any noise. Seems pretty random.
Toca is offline   Reply With Quote
Old 07-23-2014, 02:34 PM   #45
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Has anyone tried swapping in a hyundai hpfp?
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 07-23-2014, 02:41 PM   #46
Erci
Erci's Avatar
Drives: 2018 BRZ Limited
Originally Posted by dwx View Post
My advice is turn up the radio. After 2+ years of chirps I've pretty much tuned it out.
+1! I've heard it for the first time today in my 2015 WRB.. only have 250 miles on the car. If that's the only *issue* I need to live with, I'll hapily keep this thing for 10 years
Erci is offline   Reply With Quote
Old 07-23-2014, 05:28 PM   #47
blackhawkdown
Old 07-23-2014, 07:46 PM   #48
W2
W2's Avatar
Drives: Firestorm FR-S
I was curious if the people with 2015 WRX's would experience this problem. My understanding is the DI setup is all Subaru but I bet the fuel system is very similar to the FRS/BRZ. I guess you saved me some searching through part numbers to see if the WRX pump was the same!
W2 is offline   Reply With Quote
Old 07-24-2014, 02:39 AM   #49
blackhawkdown
Old 07-24-2014, 11:57 AM   #50
Erci
Erci's Avatar
No no.. I said WRB .. meaning WR Blue BRZ. Sorry to confuse you. No idea if WRX does the same thing.
Old 07-24-2014, 01:19 PM   #51
W2
W2's Avatar
Ahhh.. I can't read.
Old 04-06-2015, 11:15 PM   #52
elyugi1
Drives: raven black
I drive a 2015 black raven FRS and chirpa comes and goes i have 700miles but wen it chirps its loud i luv my car
elyugi1 is offline   Reply With Quote
Old 04-07-2015, 01:04 AM   #53
kch
Senior Misanthrope
kch's Avatar
k
Old 04-07-2015, 01:24 AM   #54
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I never kick my clutch, but when I do I stall.
Old 04-07-2015, 02:06 AM   #55
elyugi1
Drives: raven black
Talking
Test drove manual and auto i luv auto with paddle shifters .so i dont have a clutch
Old 07-06-2015, 04:20 PM   #56
DCdesign2000
DCdesign2000's Avatar
Drives: Civic Hyb, RS6, BRZ SeriesBlue
Did someone say aftermarket fuel pump?
Check this out: http://www.brz-parts.com/9-307-1010.html
It's DEATSCHWERKS DW300C DROP IN FUEL PUMP- 13+ SUBARU BRZ & SCION FR-S
Has anyone tried it? I hope this is the light we all hope to see at the end of the tunnel.
Angelic Holy music please~
DCdesign2000 is offline   Reply With Quote
2015 Series.Blue BRZ fungizmos BRZ First-Gen (2012+) — General Topics 572 01-27-2016 03:54 AM
Subaru USA's New 2015 BRZ Series Blue with STI Parts has a Placebo Effect…. vh_supra26 BRZ First-Gen (2012+) — General Topics 393 07-30-2014 01:27 AM
10 series vs. 2015 fr-s initialrt Scion FR-S / Toyota 86 GT86 General Forum 33 06-28-2014 10:40 PM
Random Chirp while moving. NOT idle chirp. Stephens Issues | Warranty | Recalls / TSB 18 08-14-2013 01:02 PM
