Old 06-14-2013, 04:44 PM   #1
Stephens
Stephens's Avatar
Drives: 2013 Scion FR-S - MT - Asphalt
Random Chirp while moving. NOT idle chirp.
So I've just turned 1000 miles and I've started to notice that every now and then I get a random chirp noise. It is very sporadic. I haven't been able to figure out the conditions that make it happen. I usuallu can only hear it if the windows are done or I am not moving too fast and there isn't wind noise
It is definitely coming from the bay. I'm not worried about it as it hasn't gotten worse or affected driving. I'm just curious if anyone else has noticed this.
Again, this is not in regard to idle chirp. Though the noise is similar, but it's just one chirp.
EDIT :
*** http://www.ft86club.com/forums/showthread.php?t=13173 ***
A/C Clutch - I shoulda searched.
To succeed in life, one must go through it with a tenacious fiery spirit of twerk.
Stephens is offline   Reply With Quote
Old 06-14-2013, 05:13 PM   #2
Carwhisperer
Drives: A lot of supercars.
Ive noticed this for thousands of miles now. No idea. Dealer said it was "normal". From what I can tell anyone else who is wondering what it sounds like, put your car in any gear 2nd, 3rd, start to move and turn on the AC and you'll hear the noise that is happening randomly to me. Usually when I let out the clutch, but it can be during acceleration or braking as well.
Carwhisperer is offline   Reply With Quote
Old 06-14-2013, 05:43 PM   #3
Stephens
Stephens's Avatar
As far as I can tell, mine usually occurs in the 2800-4000 rpm window. I haven't even taken it to the dealer because I knew that would say it was '' normal''
Old 06-14-2013, 05:55 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
It sounds like marbles rolling? This was discussed for quite sometime previously .. Conclusion was its normal
tap'd
mashal is offline   Reply With Quote
Old 06-14-2013, 06:13 PM   #5
Carwhisperer
tap'd
Uh no. Idk where you got "marbles rolling" from a random chirp, which has nothing to do with the AC if you say its that next.
Old 06-14-2013, 07:08 PM   #6
Stephens
Stephens's Avatar
No. This is not the under car rattles. I have those too. This is something different. It's quite a distinct chirp from the engine bay area. Mine sounds like it's coming from the driver's side, but that's where I sit so I may be biased.
If I'm not mistaken it was deduced that the jar of marbles sound was transmission/clutch related and that other cars with similar Aisin transmissions do the same thing.
Edit: I just drove the car with the AC off (Alabama summertime, thought I was going to die) and the car doesn't do it. I guess it's AC related like Carwhisperer said.
Old 06-14-2013, 08:41 PM   #7
br_z1Lch
br_z1Lch's Avatar
Drives: 2013 BRZ(swp) Limited
It's the A/C clutch. I took mine in and had it looked at, and they said it was "normal", even if it is crazy annoying.
br_z1Lch is offline   Reply With Quote
Old 06-14-2013, 09:13 PM   #8
Carwhisperer
I don't have to have my AC on or any air on for it to chirp. Its not AC related dude. Mine does it all the time with all the air off.
Old 06-14-2013, 09:18 PM   #9
Carwhisperer
I meant that the sound I'm getting when I turn the AC on is quite similar to the random high pitch "tink" I get with the AC off. Has nothing to do with my AC when its completely turned off when I still hear the noise under heavy load, letting out the clutch, braking. Its something else.
Old 06-14-2013, 10:19 PM   #10
Stephens
Stephens's Avatar
My bad. I misunderstood. Mine doesn't seem to do it with AC off. I haven't really checked all that much except for today. Nonetheless I'm not worried.
It just seems that these cars are crazy audible.
Old 06-14-2013, 10:53 PM   #11
Carwhisperer
yeah they do make a lot of different noises for a 2013 vehicle.
Old 06-15-2013, 01:34 AM   #12
frslee
Just drive it
Drives: 13' FR-S
Search tweet sound and you'll get the answer to the noise. It's related to fan component. It seems like the noise is present with just the fan on.
frslee is offline   Reply With Quote
Old 06-15-2013, 03:02 AM   #13
Kefuddle
Drives: Blue manual Toyota GT86
Agree with the others regarding the noise being A/C. I only get the noise with the A/C on. I don't get the noise with the fan on and the A/C off. I presume it is the compressor. Switching the A/C on will usually induce the noise.
Kefuddle is offline   Reply With Quote
Old 06-15-2013, 12:12 PM   #14
foxhu
don't fan comes on sometime even when the a/c is not on? just to blow the hot air out of the engine bay. no??
foxhu is offline   Reply With Quote
Help me ID this chirp nix Issues | Warranty | Recalls / TSB 3 02-07-2013 08:00 AM
Chirp (Video Inside) StOpNG0x Issues | Warranty | Recalls / TSB 17 12-13-2012 09:06 AM
Chirp at 70mph markitect Issues | Warranty | Recalls / TSB 15 12-05-2012 08:30 PM
With all these CEL/idle, chirp issues, should I postpone buying? Iixii Issues | Warranty | Recalls / TSB 31 10-11-2012 04:18 PM
Those running e85...do you have idle chirp? jeebus Engine, Exhaust, Transmission 6 09-22-2012 10:39 PM
