Old 07-22-2014, 12:16 AM   #1
jdpuopolo7k
jdpuopolo7k's Avatar
Drives: 2015 Subaru BRZ Blue.Series
2015 brz blue series engine chirp
So I'm still in the break in period for my blue series and I've read about the chirp that emits from the engine. I'm under 700 miles right now and the chirp is insanely loud at idle. Should I bring this thing in for them to fix it or is it something I should just take with a grain of salt? Thanks for the help!
jdpuopolo7k is offline   Reply With Quote
Old 07-22-2014, 01:15 AM   #2
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
It's not fixable. The chip comes from using gas with ethanol in it. Use ethanol free gas (search internet to find them) and the issue goes away. The dealer will replace your fuel pump but the chirp immediately comes back so there's no point in letting a dealer touch your car and more than likely screw something else up in the process like some people that have taken their cars to the dealers.
stockysnail is offline   Reply With Quote
Old 07-22-2014, 01:18 AM   #3
WesleyG
Drives: 2014 Satin White Pearl GTS auto
It can't be based on ethanol fuel only because I got the chirp after a refuel and we don't have ethanol fuel in South Africa. However it seems to have gone away after 3/4 of the tank is used up
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 07-22-2014, 01:36 AM   #4
jdpuopolo7k
There is only one place in my area( San Jose, California) that sells ethanol free gas and it's 100 octane which runs almost twice as much as normal 91 gas prices. Guess I'll deal with the "cricket" noise if that's the case. Kind of lame considering the car is new and sounds like an old civic with 300k on the motor....
Old 07-22-2014, 02:08 AM   #5
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Read this entire thread.
http://www.ft86club.com/forums/showt...ghlight=stroke
tl:dr; add some ashless two-stroke lubricating oil before you fill up at the gas station and it should get quieter. disclaimer: read the thread, and make your own decision.
aegisdrgn is offline   Reply With Quote
Old 07-22-2014, 02:18 AM   #6
WesleyG
I asked this in a other thread, is this just an annoyance or has there been reported failures or issues arising from it?
2014 37J 86 Auto
Old 07-22-2014, 02:21 AM   #7
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Try running e85, and tell me how it sounds..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 07-22-2014, 02:31 AM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
There is currently no fix for this. Other people tried the ashless whatever and Upper Cylinder lube. Some state it worked for them, some state it didn't.
I have my original fuel pump in my 2013 FRS. I occasionally get chirps but they never last. I live in California, so I get the same fuel as you do. What I've concluded from my own observation is that Ethanol doesn't cause it, or else people with E85 would be chirping all day everyday.
For my car, when I get lower than half tank, the chirps come. However, I fill up at Costco and never at other gas stations.
No failures.
N1rve
Old 07-22-2014, 03:37 AM   #9
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I dealt with the same thing whether I was running 91 or E85. Adding 2-stroke oil (specifically TCW3) helped a lot. Crickets are now either much quieter, don't last as long, or aren't there as often.
It's very cheap, and I'm satisfied with how it is now. As background, I work at a Toyota dealership and the old high pressure fuel pump number was superseded sometime late last year (Nov-Dec 2013). People have gotten it replaced with the updated unit, only for it to come back within 1,000 miles. You'll find some people even had it replaced 2-3 times, it always comes back.
There are a few reports of cars with higher mileage (~20k+) where the crickets just disappeared. I doubt Toyota/Subaru is working on any new fixes.
2-stroke oil additive thread:
http://www.ft86club.com/forums/showthread.php?t=21980
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 07-22-2014, 03:50 AM   #10
suaveflooder
wellcome to the 86
suaveflooder is offline   Reply With Quote
Old 07-22-2014, 03:57 AM   #11
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Has anyone tried swapping it or with a sti fuel pump?
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 07-22-2014, 04:01 AM   #12
N1rve
N1rve's Avatar
I don't think STi makes HPFP. AFAIK, there is no aftermarket HPFP.
N1rve
Old 07-22-2014, 05:56 AM   #13
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
The ethanol free gas is a myth, it may work for some, but I've used nothing but ethanol free gas from day 1 and I have chirping.
FiRStsc10n is offline   Reply With Quote
Old 07-22-2014, 08:19 AM   #14
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
I think it has something to do with the additives package that they add to gas. Here in North Carolina, virtually all of the gas that is sold regardless of brand comes from the Colonial Pipeline. Yet many folks have said that certain gas stations/brands give them the crickets while others don't. Since it is the exact same gas, the only difference would be in the additives that each brand uses. I guess it is also possible that the age of the gas you buy could have an effect since it is known that ethanol will readily absorb water.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
2015 Series.Blue BRZ fungizmos BRZ First-Gen (2012+) — General Topics 572 01-27-2016 02:54 AM
Subaru USA's New 2015 BRZ Series Blue with STI Parts has a Placebo Effect…. vh_supra26 BRZ First-Gen (2012+) — General Topics 393 07-30-2014 12:27 AM
10 series vs. 2015 fr-s initialrt Scion FR-S / Toyota 86 GT86 General Forum 33 06-28-2014 09:40 PM
Random Chirp while moving. NOT idle chirp. Stephens Issues | Warranty | Recalls / TSB 18 08-14-2013 12:02 PM
