Old 07-15-2014, 11:40 AM   #1
Ray_32
Ray_32's Avatar
Drives: '12 Toyota 86 (RED) MT
DriveShaftShop Carbon DS - Vibration!
I just had my new carbon drive shaft by DSS installed on my RHD Toyota 86 (or FR-S). Had a test run earlier and I noticed that there was some vibration throughout the entire cabin at certain speeds. So these are what I felt:
1) Everything is ok below 100km/h (62mph). No noticeable vibrations. Exhaust seems a bit louder).
2) Between 100km/h (62mph) and 145km/h (90mph), I notice that there are vibrations within the cabin. It is VERY noticeable, especially on my butt and steering wheel. The plastics inside the cabin rattle throughout, whereas it wouldn't previously. Takes away a bit of the confidence.
3) Go faster than 150km/h (90+mph) and the vibration goes away. Drives like normal above that speed, albeit slightly louder exhaust notes. Strange?
4) The vibration becomes more apparent the harder I step on the accelerator (between 100-145km/h). If i press the clutch in, the vibration goes away completely so I assume that this vibration is very likely to be from the new drive shaft.
5) Car responses are a lot better despite the vibration. Feels like it really wants to go, but the vibration is putting me off.
I'm not really sure what is going on here but I suspect it could be a problem with the balancing or that the drive shaft itself is warped. I'm really worried about the reliability of this thing given these vibrations and how it could affect the drivetrain if I keep with it.
What do you guys think? Could it be a problem with the installation? Thanks in advance.
Ray_32 is offline   Reply With Quote
The Following User Says Thank You to Ray_32 For This Useful Post:
unsurety (07-18-2014)
Old 07-15-2014, 11:51 AM   #2
JasperNoone
Drives: Car
What driveline mods? Bushings?
JasperNoone is offline   Reply With Quote
Old 07-15-2014, 11:51 AM   #3
Lonewolf
Lonewolf's Avatar
Drives: Moped
Contact Driveshaft Shop, see what they recommend.
I know that some people have gotten rid of their excess vibration by rotating the driveshaft and that got rid of the harshness.
The Following User Says Thank You to Lonewolf For This Useful Post:
G-Man (07-15-2014)
Old 07-15-2014, 12:10 PM   #4
Model Citizen
Lacking brains
Drives: frz
Did you rotate?
Mines been on about 25k miles. Has been flawless, has seen 110+mph on track
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 07-15-2014, 12:47 PM   #5
Ray_32
Ray_32's Avatar
No bushing mods. Pretty much stock engine and drivetrain-wise, except for the Crawford BPB, air filter and a full exhaust system.
Still waiting for a reply from DriveShaftShop, so let's see how that goes.
I'll try having it rotated tomorrow at the workshop and see if that makes a difference. Hopefully it does. Thanks!
Old 07-15-2014, 01:42 PM   #6
Squishy
Drives: 2013 WRB BRZ
I got lucky with carbon fiber drive shaft installation - worked perfect first try.
However many state that it can be hit or miss with the balancing. Unbolting the drive shaft from the diff and rotating 90 degrees until you no longer see the vibration should do the trick.
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
Old 07-15-2014, 01:54 PM   #7
wootwoot
Drives: FRS
Yup. Standard procedure with theses shafts it seems....
Old 07-15-2014, 02:29 PM   #8
Boxer486
Drives: small
Keep us posted. People should keep in mind that the factory shaft is a two piece design. Something to think about for potential buyers.
Boxer486 is offline   Reply With Quote
Old 07-15-2014, 03:12 PM   #9
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I have the aluminum shaft. Rotated it 3 times... still vibrates at 60mph. I want to throw the thing in the trash.
post_break is offline   Reply With Quote
Old 07-15-2014, 07:20 PM   #10
wooly35
Drives: 2014 Scion FR-S LS3
just installed my aluminum drive shaft last week. All is well. No vibrations like OP is speaking of.
wooly35 is offline   Reply With Quote
Old 07-15-2014, 08:03 PM   #11
Turdinator
Señor Member
Turdinator's Avatar
You do know that there are places that will balance it for you? But i would be emailing the manufacturer if it were me.
OP, the turning the shaft 90* has always worked for me on previous cars. If you have the tools it would be quicker andd easier to do it yourself than take it to a shop.
1974 TA22 Celica
2013 86 GT
Old 07-15-2014, 08:18 PM   #12
post_break
post_break's Avatar
Yeah and I bet they are only open 8-5 m-f and shipping the shaft back will cost a fortune.
Old 07-15-2014, 08:37 PM   #13
Turdinator
Señor Member
Turdinator's Avatar
Maybe. Emails are free to send though...
1974 TA22 Celica
2013 86 GT
Old 07-16-2014, 08:09 AM   #14
Ray_32
Ray_32's Avatar
Just rotated it 180 degrees today at a shop. Unfortunately I wouldn't be able to do it myself as I do not have any equipment at home. Will try it out later to see how it fares, unfortunately the traffic was too bad earlier and I didn't have the chance to go past 40mph. I'd rather not do any shipping yet as I'm based in South East Asia and it will be a bit of a pain.
rattle and vibration when braking? dokterdewe Issues | Warranty | Recalls / TSB 19 09-01-2019 08:44 AM
2600rpm vibration stueck9356 Issues | Warranty | Recalls / TSB 3 03-06-2014 12:06 PM
Speaker Vibration JayNutter Electronics | Audio | NAV | Infotainment 12 07-31-2013 12:24 AM
Droning/vibration at and around 3k rpms.. _F-R-S_ Issues | Warranty | Recalls / TSB 5 01-11-2013 03:24 AM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
