| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#57 |
Drives: Strangely.
#58 |
When In Doubt...
Drives: Slowww
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
| The Following 3 Users Say Thank You to Laika For This Useful Post: |
#59 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Question for the guys that broke their stock studs. Was this while the whole wheel assembly was warm/hot(after say a 20min drive) or when the wheel assembly was cold?
I might be OCD but I make a point to never swap wheels out if they are very warm due to different thermal expansion between the materials of the stud and nut. Also I spray a tiny bit of brake cleaner wire brush each stud whenever a wheel comes off. |
#60 |
Member of the year - 2016
Drives: Scion FRS
I had the longest laughing/coughing fit thanks to you.
| The Following User Says Thank You to dem00n For This Useful Post: | Laika (06-24-2014) |
#61 |
Drives: ‘16 4Runner, ‘19 Corolla HB
Make sure that you don't have grease/muck on the tapered faces of the lug nuts or the wheels. That lubricant will throw off your torque readings by a significant degree. If you are sloppy with anti-seize, you could be getting it on that friction surface.
#62 |
Frosty Carrot
Drives: The Atomic Carrot
For those with ARP wheel studs... I'm taking the plunge.
Did you have to do anything special to make them fit? This thread on NASIOC indicates that you need to grind the head slightly, if you plan to insert them without removing the hub. They used the ABS wheel speed sensor hole. Link to Thread
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
#63 | |
I Love custom Turbo kits
Drives: Limited BRZ
I then got the real deal Kicks R40 and they are GREAT. Very sturdy.
#64 | |
Drives: 2005 Toyota Camry
-alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Sportsguy83 (08-26-2014) |
#65 | |
Frosty Carrot
My license for "ballin out of control" has been revoked... but I still got Muteki SR48 lug nuts. The materials seem to be appropriate (AISI 50BV30 B steel). It's a Chromoly steel, but a bit more mild (less carbon and alloying elements). Relatively happy with the materials and tolerances. They spin on effortlessly, and only a tiny bit of slop when seated.
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club Last edited by Shankenstein; 08-26-2014 at 04:58 PM. |
| The Following User Says Thank You to Shankenstein For This Useful Post: | Sportsguy83 (08-26-2014) |
#66 | |
#67 |
Drives: Toyota 86 TRD Version AT
I recently changed to ARP lugs and now using the muteki open nuts. In this short time, I have two instances of the lug nuts seizing and be a pain to take off. The two instances led to cross threading of the studs. The muteki screw in fine, but there seems to be a problem when taking them out for some reason.
#68 |
Engineering Student
Drives: Scion FR-S 2015
How do you fix this?
Don't you have to take the hub out o.o, because of the splash guard for the brakes?
There’s no time to stop for gas, we’re already late
#69 |
Drives: 2015 BRZ Limited
Same problem
Ive run into this problem as well with the Muteki SR48 lug nuts. When I was taking wheels off lug nuts seized up when half way off on one wheel. Ended up trashing 5 studs. Replaced with new studs and nuts and new ones started to do the same thing. Lugs do not run on easily. Ended up running on and off a few times to wear them in. They seem to be ok now, will see when I pull them back off.
#70 |
Drives: '22 BRZ
All these issues with the Muteki lugs.
I guess I'll just keep using OEM stuff for now and make sure to wire brush the studs clean every time...
| MAX Spacer thickness for stock studs? | FRSpdDmn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 06-09-2016 01:02 PM |
| HELP! Lug nut and wheel stud stripped! | jaydee_do_work | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 07-26-2015 01:50 PM |
| spacers and stock studs | abutterman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 07-17-2013 10:55 PM |
| Extended studs with stock setup | eckoflyte | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 05-10-2013 09:13 AM |
| flush with stock wheels. with Stud installation. | adamturbo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 12-10-2012 04:30 AM |
