Old 04-08-2013, 02:54 AM   #1
eckoflyte
Drives: Toyota 86 GTS
Extended studs with stock setup
Guys, planning on getting ARP extended studs for the front (Have a set of rays wheels which may need a 2-3mm spacer to clear the sprint kit).
If at some point in the future I wish to sell the car and return it to stock, will the OEM lug nuts and stock wheels fit over the extended studs?
eckoflyte is offline   Reply With Quote
Old 04-08-2013, 02:57 AM   #2
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
Not likely. The OEM lugs are closed types, so they'll only thread on so far before bottoming out on the stud. with extended studs, that is not likely to be far enough to actually get the wheel tight.
Old 04-08-2013, 04:24 AM   #3
eckoflyte
fair enough but without any actual measurements i suppose its just speculation. if someone can confirm that would be greatly appreciated.
Old 04-08-2013, 04:26 AM   #4
EarlQHan
Drives: Subarus
how much longer are the arp studs? oem studs are fairly cheap so you can always press out the arp ones and put in new oem ones.
EarlQHan is offline   Reply With Quote
Old 04-08-2013, 04:31 AM   #5
eckoflyte
It is approximately 1" longer than stock subaru studs for 02+ WRX/Sti according to a website I found. Overall length 3"
Reference: http://www.licmotorsports.com/produc...rxsti_100-7716
@RedLeader is probably right but would like confirmation.
Here is a picture for comparison.
Old 04-08-2013, 04:41 AM   #6
EarlQHan
Drives: Subarus
oem lug nuts would not fit, but i believe you can get oem length studs for about 1.50 each. if you sell the car and want to use the oem lug nuts, just replace the studs. otherwise get open ended lug nuts, i doubt any second owner would notice/care.
Old 04-08-2013, 04:44 AM   #7
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I dont have any measurements either, but if you took a stock 86 and just removed a wheel nut, you'll see that the lenght of oem stud sticking out is pretty much the same as the depth of your oem nut. Now if you imagine the much longer ARP stud there, i'd say no way you're gonna fully tighten your factory wheel using the oem nut. Maybe if you can fit an appropriate sized hub-centric spacer behind the factory wheel it would work. Just my 2c.
Fizz is offline   Reply With Quote
Old 04-08-2013, 04:46 AM   #8
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
but you'd need to make sure you get flat faced open-ended nuts, not the concave faced aftermarket ones as these won't fit on the factory wheels.
Old 04-08-2013, 04:46 AM   #9
eckoflyte
Thanks mate. You're probably right. Don't plan on running anything over 3mm spacer. Its a consideration at the moment for future BBK install.
Ideally I'd like extended studs with a 3mm hubcentric spacer. But honestly I just hate the idea of spacers altogether.
Old 04-08-2013, 04:46 AM   #10
eckoflyte
The subaru oem wheels use tapered conical seat. So most aftermarket lug nuts will fit.
Old 04-08-2013, 04:55 AM   #11
EarlQHan
Drives: Subarus
that is correct. oem uses tapered lugs, not acorn
Old 04-08-2013, 02:33 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
No need to change studs just to run a 2-3mm spacer.
Old 04-08-2013, 08:49 PM   #13
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
ooh....didnt know that. i'd go get myself some yummy rays lug nuts then...hehe.
Old 05-10-2013, 09:13 AM   #14
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
any update on the rears?
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
MAX Spacer thickness for stock studs? FRSpdDmn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 06-09-2016 01:02 PM
Sunlight Silver & Semigloss black Rays 57Xtreme 18x9.5 square setup - IN STOCK! No Limit Motorsport Wheels and Tires 21 05-25-2013 03:42 PM
FS: 17x9 ET 30 White Rota Grids with Stock Michelling Tires and Extended Lugs whitefrs Wheels and Tires 30 12-27-2012 05:02 PM
extended DDPR stock FR-S Dyno testing Illusive Engine, Exhaust, Transmission 5 08-26-2012 10:20 AM
Going to track with stock setup good or bad idea? evasquez7 BRZ First-Gen (2012+) — General Topics 11 08-21-2012 02:33 PM
