Old 06-09-2014, 11:41 AM   #29
gymratter
Drives: BMW
OP, you may find some help on here.
http://club4ag.com/forums/viewtopic.php?t=4428&p=26102
me like this
gymratter is offline   Reply With Quote
The Following 2 Users Say Thank You to gymratter For This Useful Post:
suaveflooder (06-09-2014), van_fc3s (06-10-2014)
Old 06-09-2014, 11:51 AM   #30
suaveflooder
me like this
I would never do this personally, but I don't think anyone can deny that this is pretty cool! Thanks for the link!
suaveflooder is offline   Reply With Quote
Old 06-09-2014, 02:13 PM   #31
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Just buy an is300 and do a NA-T build. You'll save yourself much more time and money AND have another awesome car like me.
MokSpeed is offline   Reply With Quote
Old 06-10-2014, 09:59 AM   #32
21_nola_05
21_nola_05's Avatar
Drives: 2014 scion FR-S
Originally Posted by fatoni View Post
its not the type of swap you would do if youre the kind of person who comes to a forum and asks how to swap it.
some ppl have money to do whatever and they come here for info to paysomeone to do it for them but i agree with you on having some knowledge of a swap lie that
21_nola_05 is offline   Reply With Quote
Old 06-10-2014, 11:41 AM   #33
vh_supra26
Site Moderator
Drives: Supra
Off topic, but here is what happens with a LSx and 2JZ RX-7 swap.
stock RX7 vs LS RX7 vs 2jz RX7 weight
This should be the definitive answer to how much swapping these cars throws off the weight/balance of the car. All 3 were weighed on the same precision scales with roughly half a tank of gas.
First off is a stock '93 R1. Well, stock on the inside at least - all the way down to the air pump.
Next up is a '94 LS powered touring model. No power steering and no ABS, but otherwise a full interior including A/C. Rear mounted battery.
Last we have a '93 2jz powered touring model. No A/C, but it does have full interior and a half cage in it. Rear mounted battery also.
All 3 cars are on coilover suspension, so corner balancing to get a perfect 50/50 isnt out of the question. The LS powered RX7 is making around 380whp. The 2jz is well over 700whp.
And for anyone curious here's all 3 with their drivers in them.
stock R1 -
LS powered -
2jz powered -
Hopefully this clears up the whole 'you swap out the 13b and ruin the 50/50 balance these cars have' debate.
http://www.houston-imports.com/forum...d.php?t=687486
vh_supra26 is offline   Reply With Quote
The Following User Says Thank You to vh_supra26 For This Useful Post:
PRORICAN (06-10-2014)
Old 06-10-2014, 12:36 PM   #34
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Decide if you're willing to spend a minimum $15k (stock w/ r154). If you can swallow that, then add for mods.
I just got my built motor from the machine shop last night and am in the process of mocking up parts and researching my custom harness.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 06-10-2014, 12:41 PM   #35
slicktop
Originally Posted by Draco-REX View Post
In general terms:
Custom "2JZ" engine
Custom oil pan
Custom engine mounts
Custom intake manifold
Custom exhaust manifold
Custom exhaust system
Custom ECU
Custom cooling solution
Custom transmission
Custom transmission tunnel
Custom firewall
Custom dashboard
Custom center console
Custom drive shaft
Custom rear subframe
Custom rear diff
Custom rear axles
Custom fuel system
And then there's all the other stuff you'll have to fabricate that you'll discover along the way.
A lot of that is not required.
-slicktop
2013 Scion FRS
Old 06-10-2014, 12:45 PM   #36
slicktop
Originally Posted by aznatama View Post
LOL
You would need to re-do pretty much the entire drivetrain, modify the firewall, tunnel, etc. Basically, since there doesn't appear to be enough room for the length of a 2jz, you'll be stripping the entire car down, cutting nearly the entire firewall and driveshaft tunnel up, fabricating a new enclosure...
You know what? it'll be cheaper to buy a supra and put a GT86 "body kit" on it...
The FRS engine bay is larger than the Supra. The firewall does not need to be modified. And have you looked at the trans tunnel? Here's a clue, it's fucking enormous.
The only custom work is:
Wiring harness
Engine mounts (already kits available)
Driveshaft
Radiator
Intercooler
Exhaust
CAN integration
The rest is relatively basic.
-slicktop
2013 Scion FRS
The Following User Says Thank You to slicktop For This Useful Post:
itdansharpe (06-11-2014)
Old 06-10-2014, 12:57 PM   #37
AznBRZer
Drives: 16 CBS WRX Limited
[ame="https://www.youtube.com/watch?v=pXhKzY0BKwY&feature=kp"]"Some motherfucker's always trying to ice skate uphill" - YouTube[/ame]
AznBRZer is offline   Reply With Quote
Old 06-10-2014, 03:18 PM   #38
fatoni
yeah, im aware of that. i just dont see the need to come ask here. if you have deep enough pockets to have someone do it, you dont need to know how its done. or better yet, just ask the people you would have do it.
Old 06-10-2014, 05:30 PM   #39
21_nola_05
21_nola_05's Avatar
very true
Old 06-11-2014, 01:52 PM   #40
gymratter
Drives: BMW
Originally Posted by Wise View Post
You'll get the torque and the power, but you'll also get the weight of the cast iron block effectively messing up the balance that makes this car special.
not sure about the FRS tho, but that doesn't seem to be true on the FD swap.
Old 06-11-2014, 02:10 PM   #41
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
I think Wise was referring to the 2jz... Actually, why stop at a 2jz when you can swap in a big block Hemi?
Actually, if you want to go to an enormous V8, an aluminum block LS is lighter than a 2jz if I remember the numbers right (and probably more compact too)...
chrisl is offline   Reply With Quote
Old 06-11-2014, 02:17 PM   #42
gymratter
Drives: BMW
if you are looking to make lots of power, i would go with an iron block over an aluminum block.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
2JZ swap? jordydiaz Engine Swaps 44 05-21-2015 11:19 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 08:59 PM
2UR-GSE Swap czar07 Engine Swaps 9 08-29-2012 02:43 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
