Old 06-07-2014, 11:33 PM   #15
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I'm doing a 2jz swap
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
gymratter (06-09-2014)
Old 06-07-2014, 11:38 PM   #16
brzadrian
I'm Batman
brzadrian's Avatar
Drives: 2013 Subaru BRZ aka Sally
THE TITLE OF THIS THREAD IS MISLEADING
LAME POST
brzadrian is offline   Reply With Quote
Old 06-08-2014, 12:11 AM   #17
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
In general terms:
Custom "2JZ" engine
Custom oil pan
Custom engine mounts
Custom intake manifold
Custom exhaust manifold
Custom exhaust system
Custom ECU
Custom cooling solution
Custom transmission
Custom transmission tunnel
Custom firewall
Custom dashboard
Custom center console
Custom drive shaft
Custom rear subframe
Custom rear diff
Custom rear axles
Custom fuel system
And then there's all the other stuff you'll have to fabricate that you'll discover along the way.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
Basket Case (06-08-2014), Jrryjms07 (06-08-2014)
Old 06-08-2014, 12:31 AM   #18
kALMIGHTY
Drives: TRD Ultramarine '13
This is really all you need. Slap it on your FA20 and you're good to go!
Name:  Screen Shot 2014-06-07 at 10.30.57 PM.png
The Following 3 Users Say Thank You to kALMIGHTY For This Useful Post:
continuecrushing (06-11-2014), Jrryjms07 (06-08-2014), Maowc (06-08-2014)
Old 06-08-2014, 12:40 AM   #19
Originally Posted by p3raltaboi View Post
im thinking about doing a 2jz swap on my fr-s and i was wondering what i need to do the swap succesfully. any list that you guys can give?
Well, p3raltaboi ...... the first thing I would suggest that you do is to re-think your idea about an engine swap ......
Old 06-08-2014, 02:32 AM   #20
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
LOL
You would need to re-do pretty much the entire drivetrain, modify the firewall, tunnel, etc. Basically, since there doesn't appear to be enough room for the length of a 2jz, you'll be stripping the entire car down, cutting nearly the entire firewall and driveshaft tunnel up, fabricating a new enclosure...
You know what? it'll be cheaper to buy a supra and put a GT86 "body kit" on it...
aznatama is offline   Reply With Quote
Old 06-08-2014, 03:42 AM   #21
P86RAVES
Drives: 08 WRB WRX STi / NA Miata
Get in contact with Ken Gushi's guys or these guys:
http://www.speedhunters.com/2012/07/...t-oil-the-86x/
P86RAVES is offline   Reply With Quote
Old 06-08-2014, 03:49 AM   #22
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
I would seriously look into swapping the 20 valve 4AGE big port engine into your car
Sent from my GT-N5110 using Tapatalk
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 06-08-2014, 05:16 AM   #23
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
You'll get the torque and the power, but you'll also get the weight of the cast iron block effectively messing up the balance that makes this car special.
Wise is offline   Reply With Quote
Old 06-08-2014, 10:07 AM   #24
blackhawkdown
4age isn't an iron block last time I check. I could be wrong.
Old 06-08-2014, 10:29 AM   #25
aznatama
aznatama's Avatar
I think Wise was referring to the 2jz... Actually, why stop at a 2jz when you can swap in a big block Hemi? To offset the weight balance, put lead weights in the trunk!
Sent from my D6503 using Tapatalk
'14 BRZ LTD MT DGM
Old 06-08-2014, 12:10 PM   #26
fatoni
I think they are.
Old 06-08-2014, 12:45 PM   #27
blackhawkdown
I think they are.
you are right, cast iron alloy
Old 06-08-2014, 03:03 PM   #28
e-d.
Drives: Scion FR-S 13
2jz the dream
e-d. is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
2JZ swap? jordydiaz Engine Swaps 44 05-21-2015 10:19 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 07:59 PM
2UR-GSE Swap czar07 Engine Swaps 9 08-29-2012 01:43 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
