Old 06-08-2014, 10:53 AM   #15
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
The have a flexplate that the torque converter bolt too
Old 06-08-2014, 11:36 AM   #16
xwd
Originally Posted by Admired View Post
What?! Why not? The transmission should be irrelevant.
Advertisement but gives you an idea of how autos work versus manuals. Autos have a torque converter and flex plate, manuals have a flywheel and clutch. Not counting the fancy new dual clutch gearboxes and whatnot, which the BRZ/FR-S doesn't have.
[ame="https://www.youtube.com/watch?v=qmuDtGZxuDc"]Flexplate - How Flexplates Work vs Flywheel - YouTube[/ame]
Old 06-08-2014, 11:50 AM   #17
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Exedy stage One organic clutch and chromoly flywheel
Helped @bjun install the Exedy parts in his BRZ before he had PTuning install his turbo kit. Very nice manners on the street immediately after install. He's still way liking the combination. When I go FI the carbon driveshaft and Exedy parts are going in too!
BJun hasn't put in a carbon driveshaft yet (as of today anyway 6/8/2014), but I think the combo will be a hoot!
Brzzee is offline   Reply With Quote
Old 06-08-2014, 11:55 AM   #18
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Originally Posted by Reaper View Post
Go with the streetlite! The protlite is too light for the street and extremely difficult to drive. Even the streetlite is pretty noisy and chatters alot at idle with the ac on. Are you going 6 puck?
I DD the prolite, it's fine. Bump up your idle to 900-1000rpm and everything works fine. It's easy to drive and doesn't chatter nearly as bad with an increased idle. The alum driveshaft makes a lot of noise from 2000-3200rpm but it's just race car noises. It's drivetrain decel noises which I'm ok with.
Driving a stock brz feels weird to me now. Rev hang is just ridiculous and it feels very disconnected compared to mine.
industrial is offline   Reply With Quote
Old 06-08-2014, 01:09 PM   #19
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
A flywheel will not cause any change in vibration. The Driveshaft might, I didn't notice it but then again our car isn't really daily driven.
FT-86 SpeedFactory is offline   Reply With Quote
Old 06-08-2014, 01:17 PM   #20
wootwoot
Drives: FRS
I thought any time you went from a dual mass flywheel (stock) to a single mass flywheel (aftermarket) you were going to gain at least some additional drivetrain noise. The lighter you go, the more noise you are likely to incur. Several people have reported this on the forum. Search around and you can find more detailed feedback.
Old 06-08-2014, 01:58 PM   #21
Reaper
Reaper's Avatar
Drives: violent
Our flywheel is not dual mass
The Following User Says Thank You to Reaper For This Useful Post:
kiichiro (06-09-2014)
Old 06-08-2014, 03:08 PM   #22
carlitosway6891
Drives: white out project fr-s
ive got the streetlite flywheel, 6 puk ACT combo and as mentioned earlier, at warm idle with AC on, the chatter is almost embarrasing. ill have to look into raising the idle maybe 200rpm or so.
when shifting gears, the revs drop a lot faster so thats a plus.
i dont have the drifeshaft upgrade tho
carlitosway6891 is offline   Reply With Quote
Old 06-08-2014, 04:28 PM   #23
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I find it seriously annoying to drive a puck clutch for a DD. If your running an S/C setup or AVO kit then the exedy stage 1 will be fine, anything more than 350 to the wheels I'd go with clutchmasters. If you have more than that then id start looking at a TD from either Exedy or CM.
I'm guessing lighter weight flywheels will be less chattery if ran with a full faced clutch.
Old 06-08-2014, 04:30 PM   #24
Kostamojen
Oh... my.... god...
The Following 2 Users Say Thank You to Kostamojen For This Useful Post:
kiichiro (06-09-2014), wparsons (06-09-2014)
Old 06-08-2014, 04:34 PM   #25
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Yes, but I'm not sure if the stock flywheel is a DMF one. I wonder does anyone make a lightweight DMF for this car?
Old 06-08-2014, 05:08 PM   #26
litemup
Drives: around
Originally Posted by Kostamojen View Post
Oh... my.... god...
Be nice. Auto tranmissions are irrelevant.
litemup is offline   Reply With Quote
The Following 2 Users Say Thank You to litemup For This Useful Post:
kiichiro (06-09-2014), wootwoot (06-08-2014)
Old 06-08-2014, 05:43 PM   #27
Poodles
Drives: 2015 Series.Blue
Really? I have an Auto so it won't be difficult to drive like a manual. Do they make clutch packs for autos?
The real mass is in the torque converter (and the fluid it's filled with) and you're not going to notice any difference with a driveshaft either because you have a fluid coupling to the wheels.
Spend your money elsewhere.
Old 06-08-2014, 05:48 PM   #28
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Not to those people who have them.
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
FS: Driveshaft Shop (DSS) aluminum driveshaft (for AT only) $350 dp1 Transmission and Driveline 8 06-18-2014 04:16 PM
6 MT Swap, Complete: Transmission,Starter, Flywheel, Clutch, Driveshaft, Pedals, Hydr ecda Transmission and Driveline 2 01-30-2014 10:45 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
WTB: Driveshaft Shop (or lighter) driveshaft Anthony Want-To-Buy Requests 8 08-27-2013 12:30 PM
