Old 06-07-2014, 09:31 AM   #1
Admired
Drives: 2013 Scion FRS
Flywheel and Driveshaft
How much of a difference in terms of how the car behaves will a aluminum/cro-moly flywheel and aluminum driveshaft have on the car?
Admired is offline   Reply With Quote
Old 06-07-2014, 12:50 PM   #2
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
I can't speak specifically for this car, but for my previous car (Acura rsx type s) the lightened flywheel alone made a big difference. Nothing you can't get used to. I loved the acceleration after the install as the car felt much more responsive. I can only imagine the light flywheel paired with the aluminum driveshaft would do on this car
Sent from my HTC One using Tapatalk
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 06-07-2014, 12:52 PM   #3
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
It's a huge difference. We run both lightweight items and the car revs very quickly, ready to go. :-) wouldn't drive an frs again without those parts.
FT-86 SpeedFactory is offline   Reply With Quote
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Reggaeboyz (06-07-2014)
Old 06-07-2014, 06:45 PM   #4
Reggaeboyz
Drives: Mazdaspeed 3
Did this add any vibration or anything like that?
Reggaeboyz is offline   Reply With Quote
Old 06-07-2014, 10:26 PM   #5
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
^ +1
I have run a single piece aluminum shaft on my 240 for over 10 years, only hollow thunk sound when shifting some times.. but then I put on a fidanza aluminum flywheel, and the off throttle/engine braking vibration shakes the whole car and with windows down the echo off the houses sounds like my car is going to fall apart. The response went up, but not enough to make up for the noise/vibration.
Target70 is offline   Reply With Quote
The Following 2 Users Say Thank You to Target70 For This Useful Post:
funwheeldrive (08-09-2017), Mikem53 (06-09-2014)
Old 06-08-2014, 04:23 AM   #6
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
"Lightweight flywheel" come in different weights.
Old 06-08-2014, 06:58 AM   #7
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I've thought about doing this as well, but all the vibration stories have kept me from pulling the trigger.
kmbkk is offline   Reply With Quote
Old 06-08-2014, 08:01 AM   #8
Admired
I w s probably going to go with thr ACT Prolite which is 10.5 lbs
Old 06-08-2014, 10:14 AM   #9
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Go with the streetlite! The protlite is too light for the street and extremely difficult to drive. Even the streetlite is pretty noisy and chatters alot at idle with the ac on. Are you going 6 puck?
Old 06-08-2014, 10:14 AM   #10
xwd
When I had my WRX I didn't go with the absolute lightest weight flywheel and probably won't on the BRZ either. I've heard lots of bad things about aluminum propshafts but not nearly as many about CF ones, so I'm definitely going CF when the time comes.
I've been trying to purchase a Speedsport clutch for about a month now but no one seems to have them. They don't use that light of a flywheel and the clutch disks are all CF so there is some weight saved there as well.
Old 06-08-2014, 10:17 AM   #11
Admired
Really? I have an Auto so it won't be difficult to drive like a manual. Do they make clutch packs for autos?
Old 06-08-2014, 10:23 AM   #12
Reaper
Reaper's Avatar
Drives: violent
Umm...autos dont have a flywheel
Old 06-08-2014, 10:44 AM   #13
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
You want a torque converter with a lightweight case, not a flywheel. Dunno if such a thing exists for the twins yet. Had one for the 4L60E in my GTO and it was awesome though.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 06-08-2014, 10:51 AM   #14
Admired
What?! Why not? The transmission should be irrelevant.
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
FS: Driveshaft Shop (DSS) aluminum driveshaft (for AT only) $350 dp1 Transmission and Driveline 8 06-18-2014 04:16 PM
6 MT Swap, Complete: Transmission,Starter, Flywheel, Clutch, Driveshaft, Pedals, Hydr ecda Transmission and Driveline 2 01-30-2014 10:45 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
WTB: Driveshaft Shop (or lighter) driveshaft Anthony Want-To-Buy Requests 8 08-27-2013 12:30 PM
