Old 05-27-2014, 05:54 PM   #5741
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Winjr View Post
I thought the car's ECU needs to "cycle" through its complete analysis, which varies by car and is usually 20-30 miles worth of driving. Which means that the CEL won't light again immediately after start up, depending upon the problem, but will once the ECU completes its cycle. No?
It takes that long for the ECU to decide to clear a cel on its own. It can decide to trip one pretty much instantly. It does the driver no good to learn of a potential problem long after the damage is done.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 05-27-2014, 06:05 PM   #5742
shif7i7down
Erected Member
Drives: frs
http://datazap.me/u/shif7i7down9188/...1-3-7-10-11-12
log of my 4th gear pull , does it look weird
shif7i7down is offline   Reply With Quote
Old 05-27-2014, 06:18 PM   #5743
Robftss
Drives: VW
Boost/AFR look spot on.
Robftss is offline   Reply With Quote
Old 05-27-2014, 06:38 PM   #5744
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by robwbright View Post
Here's a log from today with 2nd and 3rd gear pulls.
http://datazap.me/u/robwbright/esc-l...log=0&data=1-7
How's it look?
What's up with my boost? It never reaches 4.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 05-27-2014, 06:39 PM   #5745
shif7i7down
Erected Member
Drives: frs
The car feels awesome even with the cel. I wouldn't mind it if i could just have it deleted so it won't show up <-but I'm not sure if that's the best solution.
Old 05-27-2014, 06:50 PM   #5746
fenton
I want to rule out Any possible mistake that i may have done to get the P0108 cel.
That rubber tube that connects to the aluminum peice"brass fitting" connects to the little black nub that is sticking out of the controller right?
If all else fails should i buy a new map sensor?
I'll also do some loggs later today
Make sure everything is tight?
Also you will probably get above 4 below 3000 rpm.
What is your altitude?
fenton is offline   Reply With Quote
Old 05-27-2014, 06:53 PM   #5747
shif7i7down
Erected Member
Drives: frs
Altitude is About 600ft.
Old 05-27-2014, 06:54 PM   #5748
Robftss
Drives: VW
(ROB) RPM PSI (SHIF7) RPM PSI
N/A.... N/A_____ 3563 4.50
4016 3.92_____ 4280 3.92
5660 3.05_____ 5624 3.05
7063 1.82_____ 7104 1.89
They are the same.
Old 05-27-2014, 07:38 PM   #5749
robwbright
They are the same.
Got it - he just engaged at a lower rpm.
2006 Saab 9-3 2.0t
Old 05-27-2014, 08:00 PM   #5750
shif7i7down
Erected Member
Drives: frs
can someone check their Phantom tune with Romraider and tell me what their Manifold Pressure Sensor is set at for High and Low input.
I was just curious and took a look at the phantom tune and mines set at 3.91 for high and .61 for low,
I was thinking that maybe if i up my volts for the high to something like 4.91 to see if that'll help with the p0108 code i'm having.
Old 05-27-2014, 08:02 PM   #5751
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
@shiv@vishnu any help?
Installed Mods:
Old 05-27-2014, 08:02 PM   #5752
fenton
I'll check tonight. Can you link me to the software
Old 05-27-2014, 08:11 PM   #5753
shif7i7down
Erected Member
Drives: frs
the software and the frs xml are on the openflashtablet website under download section
I honestly think that 3.91v is too low for 5psi boost -_-..
UPDATE: P0108 cel code is solved with a higher voltage limit.. i set it to 4.91 and no more cel. yeeaahh me. ^_^
Old 05-27-2014, 08:53 PM   #5754
fenton
How come it was at so low?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
