Old 04-17-2014, 12:55 AM   #29
Wyattkb
Drives: 2014 Whiteout FRS
He is sucking oil out, heavy particles will inevitably fall to lowest point so he is probably not getting everything out.
When you drain it, you work with gravity. Starting at the point where all the bad stuff accumulates (lowest point = plug).
Wyattkb is offline   Reply With Quote
Old 04-17-2014, 02:37 AM   #30
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It sticks out a lot, a branch at the wrong location and time could easily open that up or even break it off, metal debris?
You do realize Fumoto sells a clip to prevent precisely the scenario you're describing above, right?
But don't take my word for it.
Draw a straight line from the front radiator core support, across to the metal skid plate, and see what is in the line of fire. If something were to hit the oil drain plug, I'd be more worried about the rest of the car than the oil plug.
The only times I've been able to scrape the plate, was because I was not careful going over some absurdly large speed bumps.
-alex
OICU812 (04-17-2014)
Old 04-17-2014, 02:44 AM   #31
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You guys do know that doing it the old fashioned way is just as simple right?
... right?
ineedyourdiddly
86-tundra (04-18-2014)
Old 04-17-2014, 03:50 AM   #32
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
... right?
Absolutely just tad messy no big deal though all ways work.
Old 04-17-2014, 04:04 AM   #33
suaveflooder
You sir, have inspired me to try out the quik valve. I have about 3k more miles until the next oil change but will install then! I can't wait!
suaveflooder is offline   Reply With Quote
Old 04-17-2014, 04:12 AM   #34
OICU812
Just a dude
OICU812's Avatar
Well they work. You thread them in (once) for the lifetime of the car. There are 2 versions. The short nipple version is one you want. As Mav mentioned for like a buck if you're worried get the clip that's an extra feature but without it the lever never can come loose or move as it's spring loaded.
Reason I went with the fumoto is simply cause I can quickly jack up front drain into an old milk jug without a drop of oil anywhere. All while not touching a single tool etc.
The Following User Says Thank You to OICU812 For This Useful Post:
suaveflooder (04-17-2014)
Old 04-17-2014, 08:25 AM   #35
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Originally Posted by M3_Dust View Post
so it's the fault of the oil drain plug that you lowered your car and now you can't fit a jack under it? am I really going to have to deal with these types of posts on this forum? bud, get yourself some ramps or an ultra-low lift point floor jack, the right tools make any job easier.
you obviously missed my sarcasm. KTHXBAI
supramkivtt2jz is offline   Reply With Quote
Old 04-17-2014, 10:20 AM   #36
jarviz
jarviz's Avatar
Drives: Raven FRS MT
As easy (relatively) as it is to change the oil in this car, does anybody else find it's more worth it to just take it to a local mechanic? I'm paying about 10 bucks for the labor.
Maybe it's my lack of a garage and NYC weather that makes it such a pain.
jarviz is offline   Reply With Quote
Old 04-17-2014, 10:23 AM   #37
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I only trust myself to perform basic maintenance
Old 04-17-2014, 10:38 AM   #38
TM
TM's Avatar
Drives: DGM BRZ 6MT
Our cars our low, i take many things into considerations. Water, random objects in highways, branches, etc.
I don't think it sticks out that much. Highly unlikely, that you'll drive over something that'll knock it out, but I won't discount the possibility of that happening. I've seen some unlikely things getting stuck at unlikely locations. So I respect your opinion and your choice to stick with the OEM drain plug. Either way, it's still easy.
... right?
Agreed. Just less mess with the quick valve.
The last time I brought my car in to the Subaru dealer for an oil change, it came back to me with a rash on the steering wheel. My guess is that it was too low and the service guy's jeans must've rubbed against it trying to get in or out. If I ever need to take my car to the dealer again, I will also put my steering wheel to the highest position from now on.
TM is offline   Reply With Quote
Old 04-17-2014, 10:49 AM   #39
bdbx18
Drives: Present MDX, Civic Hybrid, BRZ
Yeah I used to do the topside dipstick method with my Bimmers which I'm told it is SOP. So when I had a longer commute and got a Civic Hybrid, I carried it over to that car which now has a roughly 5 inch piece of tubing left in the oil pan. Some cars have a kink or an edge or something that would make it a bit difficult to pull the entire tube straight out. Much gentle cajoling and massaging transitioned to full out anger after about an hour thereby a full power yank which left a piece lodged in there. Dipstick still works so it must have fallen into the pan.
I have the fumoto valve on my BRZL. Only problem I have is that once you've warmed up the engine (like we supposed to), like the regular bolt, the oil gets warm/hot and you have to get out of the way quick. The safety catch requires at least two fingers so gloves help. I never bothered with the tubing on mine as I removed the plastic nipple long ago and I can't find it now.
Current: 07 MDX, 06 Civic Hybrid, 13 BRZL
Past: 03 M3 SMG, 99 540i, 01 X5 4.4, 01 X5 3.0, 03 MDX, 92 NSX, 89 Maxima, 86 Integra, 88 Odyssey, 88 Legend, Supra, MR2T, Pathfinder, MirageT, Accord
bdbx18 is offline   Reply With Quote
Old 04-17-2014, 10:57 AM   #40
tennisfreak
Drives: 2018 BMW M240i
Wow never saw one of the fumoto valves before.
After my free services from the dealer I will be installing one of these little fellas and doing oil changes lift free in my garage!!
Regardless of how good my service center is I still dont trust other people handling my car. There is always an inherent lack of concern for something the is not yours and unintentional things happen.
Old 04-17-2014, 01:13 PM   #41
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by roddy View Post
Lucky dog got a magnetic drain plug with his car...must be a 10 series thing.
Maybe, it glows blue when you're near it.
Must be thinking of my FJ, I changed both of them last week and guess it was only one with the magnetic plug.
Think I'll order one somewhere, maybe an FJ plug from the dealer if it works.
torqdork is offline   Reply With Quote
Old 04-17-2014, 02:48 PM   #42
reeves
Originally Posted by wheelhaus View Post
Fumotos are extremely reliable, they're just an easy target for paranoia. Another benefit is that they are installed once and can be left in place. I've seen far more problems with standard bolts being cross threaded, leaking, overtorqued, broken, forgotten, etc.
I've seen more people (and idiot dealership mechanics) having problems with the standard drain plug too (cross-thread, over-tighten, re-used/wrong washer, etc.) than they do with a Fumoto valve lol.
easiest color to keep looking clean? fatoni Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 10-10-2013 07:21 PM
Easiest way to get to the over-pipe? Doing an install... seven Engine, Exhaust, Transmission 7 02-03-2013 07:38 AM
Colors easiest to keep clean yet looks good fitcious Scion FR-S / Toyota 86 GT86 General Forum 31 01-16-2013 02:22 PM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
