Old 04-09-2014, 05:48 PM   #71
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Need help installing my avo turbo kit
Originally Posted by Astroboy View Post
No, maybe because I paid a lot less than the base price... I have an ecutek cable and a dondle but not a map
Base map is free.....
Email paul @AVOturboworld with your dongle Id
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
SkAsphalt (04-09-2014), Sportsguy83 (04-10-2014)
Old 04-09-2014, 06:04 PM   #72
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
That is exactly what I did. Got my tune the same day I asked for it.
The Following User Says Thank You to SkAsphalt For This Useful Post:
Astroboy (04-10-2014)
Old 04-10-2014, 02:49 PM   #73
Astroboy
Astroboy's Avatar
Drives: None
Ok
How about the vacuum hose that connected on the stock intake tube, it says I'm suppose to take it off completely I believe, or do I connect it on the avo intake tube that is connected to the air box? If not, what is suppose to be connected to that side of the inlet tube
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-10-2014, 02:52 PM   #74
protpibe
protpibe's Avatar
That's not a vacuum hose, it's a cramk case breather line if it's the one I think you're thinking of. It connects into the AVO intake line just after the airbox if that's the case.
Take a pic and post it to be sure.
Astroboy (04-10-2014), SkAsphalt (04-10-2014)
Old 04-10-2014, 03:31 PM   #75
Astroboy
Astroboy's Avatar
Drives: None
Here, it is.
Old 04-10-2014, 03:35 PM   #76
Astroboy
Astroboy's Avatar
Drives: None
And my other question is what do I do with this hose. I think the manual says to take it completely out, but what am I going to do with the end that connects to the engine?Name:  uploadfromtaptalk1397158524720.jpg
Old 04-10-2014, 03:36 PM   #77
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
And my other question is what do I do with this hose. I think the manual says to take it completely out, but what am I going to do with the end that connects to the engine?Attachment 73996
That is the line that you plug into the fitting coming out of the intake pipe that points toward the throttle body.
Protpibe taught me that one
protpibe (04-10-2014)
Old 04-10-2014, 03:39 PM   #78
protpibe
protpibe's Avatar
Good thing you posted those pics because the hose you posted is the one that plugs into the intake tract. If you meant the 3/8" hose coming off the oil reservoir, then yeah, that one also plugs into the intake tract pre-turbo. You'll need to use a tee fitting to splice them all together.
Old 04-10-2014, 10:29 PM   #79
Astroboy
Astroboy's Avatar
Drives: None
I never got the base tune
Old 04-10-2014, 10:33 PM   #80
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Attachment 73995
Here, it is.
Such proud, my engine bay making another cameo....
Just email Paul from AVO and je will get you a basemap.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Astroboy (04-11-2014)
Old 04-11-2014, 10:03 AM   #81
Astroboy
Astroboy's Avatar
Drives: None
SUCCESS!! Thanks a lot guys!
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 10:58 PM
Installing a hood for the fr-s? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-16-2013 11:06 AM
installing harness andrew5826 Cosmetic Modification (Interior/Exterior/Lighting) 16 07-25-2013 10:41 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
tips for installing amp and sub brichard0625 Electronics | Audio | NAV | Infotainment 4 05-19-2013 07:25 AM
