Old 04-09-2014, 12:53 PM   #1
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Can someone check their engine for me?
I uploaded a video a few days ago regarding a ticking sound I been having after installing my headers and FP/OP. Frs: [ame]http://youtu.be/xoNSVgxRq2U[/ame]
A coworker checked to see where the sound was coming from and he believes it's coming right below the alternator. Not sure what that part is called but it does vibrate and thinks a screw is missing. Can anyone confirm that?
Carlitoz3 is offline   Reply With Quote
Old 04-09-2014, 03:56 PM   #2
Createddeleted
Drives: 2014 BRZ - 2004 GLI
There's no screw there on mine. Just a plastic insert that goes into thin air.
Createddeleted is offline   Reply With Quote
The Following User Says Thank You to Createddeleted For This Useful Post:
Carlitoz3 (04-10-2014)
Old 04-09-2014, 03:58 PM   #3
Createddeleted
What kind I headers did you buy? Any leaks?
Old 04-09-2014, 03:58 PM   #4
frslee
Just drive it
Drives: 13' FR-S
Did you check any exhaust leaks?
Before cold start, spray soapy water on each gaskets and start the engine. It sounds like exhaust leak for me if these happened right after installing all those aftermarket parts.
frslee is offline   Reply With Quote
Old 04-09-2014, 04:45 PM   #5
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
What you have circled is part of the automatic tensioner for the serpentine belt setup. The sound you have is due to exhaust leaks. Buy new gaskets for all connections (although it sounds like it's at the head/header because one pulse sounds louder, rather than a constant hiss), reinstall everything, and torque to factory specs.
Travisty75 is offline   Reply With Quote
The Following User Says Thank You to Travisty75 For This Useful Post:
Old 04-09-2014, 05:19 PM   #6
JB86'd
JB86'd's Avatar
Drives: JAWS
you could try driving it for a few days, then retorquing all of the bolts. The expansion and contraction of the metals and retorquing might help.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Old 04-10-2014, 12:38 AM   #7
It almost sounds like you forgot to put the manifold gaskets on....
Old 04-10-2014, 01:11 AM   #8
ABR
Drives: 2013 FR-S Firestorm
Here's mine acting normally.
[ame="http://youtu.be/ZE8xBtMEtoU"]http://youtu.be/ZE8xBtMEtoU[/ame]
ABR is offline   Reply With Quote
The Following User Says Thank You to ABR For This Useful Post:
Old 04-10-2014, 03:11 AM   #9
Carlitoz3
Carlitoz3's Avatar
I did buy new oem gaskets forcthe new headers unless if I installed them upside down or something. What tool do you recommend for tightening that ONE screw from the header on passanger side. I'm sure that ONE isn't fully tight.
I didn't see any leaks when I left the car on after a few minutes.
Nameless
Old 04-10-2014, 03:12 AM   #10
Carlitoz3
Carlitoz3's Avatar
Thank you, just curious, does your crank pully move when the car is on?
Old 04-10-2014, 03:14 AM   #11
Carlitoz3
Carlitoz3's Avatar
Been likecthis for a week. Going under the car this weekend and giving that a try.
Old 04-10-2014, 03:19 AM   #12
nelsmar
Holy exhaust leak!
1) Buy welding leathers (to shield from heat in later steps)
2) Buy Any tools needed to get you as far as possible from header for installation
3) Jack up car
4) Give slight torque to bolts on header on all flanges. Loosen all exhaust flanges and tighten header <-> engine flanges first. Torque to spec
5) Start car. Let idle for 2-5 minutes (until warm)
6) Re-torque starting at header flanges. Heads will physically shift place causing the headers to shift placement, possibly loosening.
7) Let things cool verify they are still within spec. Let it cool down, start car and feel for exhaust leaks (do so with caution).
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Old 04-10-2014, 10:52 AM   #13
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Sound like a bad exhaust leak:[ame="http://www.youtube.com/watch?v=CtK75-HWeHE"]Exhaust leak noise - YouTube[/ame]
(keep in mind it doesn't just happen under throttle that was just this guy on the videos case lol)
Old 04-10-2014, 03:10 PM   #14
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
yeah re-install form header to back again. that's really bad
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
What does it mean when tractions off and check engine come on? Frs32907 Issues | Warranty | Recalls / TSB 8 01-24-2014 09:33 AM
Check engine light? czar07 AUSTRALIA 0 09-01-2012 02:50 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 09:50 PM
